2000 watts server supply: DPS-2000BB (A)
Discussion in 'Electronic and hardware generally' started by Pit, Mar 25, 2015.
  1. Pit
    30,497Coins
    Daniel thanks for sharing your thoughts. As I have posted above I have no issues anymore. Sometimes I am going through the process as long as I can see there is some progress but now I will waste time for nothing. The DPS-2000B is a very powerful but sensitive psu. Bypassing the "intelligence" makes no sense to me. I am going to post more information in the new psu thread today. BTW not bad the power consumption of my two winches on a 220v line :
  2. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    Power factor could be better (can't do anything about that) but that current draw is a good indicator that the system isn't going to overload the wall socket.
  3. Pit
    30,497Coins
    I measured all again, I connected all gadgets (all motors including PSUs and ventialtors, speakers, 3 LED projectors, PC (i7 3.8 GHz, GTX 670 SLI), Notebook (Ard/MM), smartphone, T500RS wheel, bass shaker, butt kicker) to one wall socket and the powermeter as well.
    1. No driving, all gadgets on: ~950W, power factor 0.88 - 0.97, 4.2A
    2. Driving on Nordschleife: ~1200 W (~1450 W peak.), power factor 0.88 - 0.95, ~5.00 -6.00 A (9.4 A peak).
    IMO not too much I expected more. The peaks are coming from crashes.
  4. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,045Coins
    Arduino, 4DOF
    How was it setup before ? So it loosk good after all ?
    I'll get my power diodes and resistors tonight so I'll do some tests.
    I will start to assemble the motion rig probably in a couple of weeks. Getting the metal tomorrow :)
  5. Pit
    30,497Coins
    Before two winches one PSU.
    Great, I will follow your tests :)
    It looks very good!
  6. gigi
    gigi Active Member
    917Coins
    2DOF, JRK, 4DOF
  7. Nick Moxley
  8. gigi
    gigi Active Member
    917Coins
    2DOF, JRK, 4DOF
    Twoor three times happened a return of power from the motors to the psu.
  9. insanegr
    insanegr !N$@n€
    Athens
    16,724Coins
  10. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
    I've created and tested this "Capacitors power bank" of 24 caps of 10000uf/25v connected all together in parallel ... then used in parallel with a normal desktop PSU 12V that kept shutting down when using a big 70Amp burst current wiper before adding this beauty then worked like a charm ...
    2015-04-27_18.42.55[1].jpg 2015-04-27_18.43.27[1].jpg 20170313_023953[1].jpg
  11. vthinsel
    FRANCE
    6,045Coins
    Arduino, 4DOF
    Nice. You just missed a "0" in the text. The caps you use are 10 000uF, which makes more sense. Have you protected the "caps bank" by diodes or something else ?
  12. speedy
    Alexandria , Egypt
    7,944Coins
    Yes it's a 10000uf/25V "typo" ... corrected thanks :cheers
    No diodes here at all ... this power bank can absorb any feedback voltage/spikes ... and is connected and treated as if you have a car battery in parallel to the 12v charging line in parallel to the h-bridge supply lines ...
    protection diodes are actually used in the h-bridge circuit to direct any excessive voltage back to the power supply which is bad for the PSU ...
    The issue with some power supplies is that they cannot provide such huge amps at the start/reverse of a motors and that what causes many of us to select bigger PSUs ...
    So, Go for more caps enhancing the output stage of the PSU if you need .
    Caution : When done with playing .... you have to use a bleeding 35w filament lamp or 1/2w resistor for a good 2-3 seconds to make sure they are really empty "LED is not recommended as they will stay ON like forever " :grin .
    Huge difference at the motor starting torque with absolutely no shutdown protection to the PSU .:thumbs
  13. speedy
    Alexandria , Egypt
    7,944Coins
    Got the idea from here ... :D:D
  14. speedy
    Alexandria , Egypt
    7,944Coins
    Some information references ...
    http://physics.bu.edu/~duffy/py106/Capacitors.html
    Edit: [this paragraph is c/p from the next Sparkfun link ]
    Energy Storage and Supply
    It seems obvious that if a capacitor stores energy, one of it’s many applications would be supplying that energy to a circuit, just like a battery. The problem is capacitors have a much lower energy density than batteries; they just can’t pack as much energy as an equally sized chemical battery (but that gap is narrowing!).​
    The upside of capacitors is they usually lead longer lives than batteries, which makes them a better choice environmentally. They’re also capable of delivering energy much faster than a battery, which makes them good for applications which need a short, but high burst of power. A camera flash might get its power from a capacitor (which, in turn, was probably charged by a battery).​
    https://learn.sparkfun.com/tutorials/capacitors/application-examples
    So If me myself having a problem start/reverse a big DC motor from a normal power supply which keeps shutting down => Due to the short time , but high burst of power needed ...
    Then this is what I've made and what we might need and I confirm again it is working with these normal chemical capacitors ... :cool:
  15. Stefzouille
    Stefzouille Member
    595Coins
    2DOF, DC motor, 4DOF
    hello, interesting, the subject is a little dated if ever someone passes by to give me help in calculating this schottky diode? I think? I really wouldn't want it to catch fire, neither the house nor me on the simulator...
