Tutorial English Guide for SCN5 Interface
Discussion in 'SimTools DIY Version' started by nclabs, May 18, 2014.
  1. Rinus janssens
    Rinus janssens Active Member
    environmental construction
    Holland
    2,153Coins
    SCN5
    Or do you have the right game plugin ?
  2. yobuddy
    51,564Coins
    Could we see your interface settings from Game Engine?
    (You should have 2)
    When you start SimTools they should both center?
  3. Hicsy
    Hicsy New Member
    168Coins
    SCN6
    Hi, I haven't even used in a game, as unfortunately the Engine isn't controlling them yet.
    Oh, they don't move at all on startup. I do understand what you refer to though, as X-Sim does calibrate them.
    I also included the USB adapter photo. I don't know the manufacturer of the SCN5 microcontroller-box, they are sealed stainless-steel units with Red+Green status LED's on the side... not the white single-piece units as pictured in the config-diagram
  4. Hicsy
    Hicsy New Member
    168Coins
    SCN6
    This + steel controller-box + USB>232>485 adapter
  5. yobuddy
    51,564Coins
    That looks like a SCN6 to me?
    Which will be supported in the next version of SimTools
    • Dislike Dislike x 1
  6. yobuddy
    51,564Coins
    Yes, Only the SCN6's have a "steel controller-box".
    The SCN5's have it all built into the actuator itself.
    I believe you have a SCN6 there not a SCN5?
  7. Rinus janssens
    Holland
    2,153Coins
    SCN5
    That clears it all
  8. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    @yobuddy
    Why can't we create presets for SCN Interface? The button is greyed out, not clickable.
    I'm asking because I set my SCN speed and acceleration differently for racing games and another speed/acc for flight games, it would be great that presets could be made like they can for SER Output type..
  9. Hicsy
    Hicsy New Member
    168Coins
    SCN6
    By the way guys, make sure your COM ports are BELOW COM-10 or Simtools 0.1.3.0 WILL NOT talk to them. I understand that the outputs config lets you choose COM 10+ but it will simply IGNORE them!
  10. yobuddy
    51,564Coins
    @prodigy ,with SimTools 2.0 onward, all interfaces will have presets!
    Last week I finished a Interface plugin system (just like the game plugin system) but for interfaces!
    So anyone will be able to create a interface plugin for any interface they want to use with SimTools and share it.
    The system automatically threads the interface and allows for presets without the interface plugin creator having to deal with any of it in code.
    So now I can retune/edit a output interface without having to touch SimTools itself.
    Should make polishing any output interface much easier!
    I'm really happy with how its all shaping up!
  11. bberger
    bberger Member
    306Coins
    Please add to this useful posting that you have to have the actuator IDs set to zero!
  12. nclabs
    196Coins
    I know that there is that kind of issue, but I never had to do that, so in order to write a tutorial I would need to know what to write in it! If someone can give me the text to add I would be happy to add it.
  13. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    what values to put for scn6 40kg placed in the front of the simulator please
  14. yobuddy
    51,564Coins
    @long legs,
    It works fine with win10 64.
    And you can install SimTools 2.0 and it will run in demo mode until you enter a license.
    The 'live for speed' game demo is free also, and a great game! (the game the demo works with)
  15. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    hello any info about the thread size on a SNC6. any info about the power plug (male part) ref number to diy a connection (ref part for mouser for instance)
  16. yobuddy
    51,564Coins
  17. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    i got the info from mirai itself in toronto. I ll update for future reference...
  18. yobuddy
    51,564Coins
  19. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    SNC6 extra info : thread specs ar M14x1.5
    power connector for a diy plug (mouser.com ref):
    798-DF1B-24DES-2.5RC
    2.5MM DOUBLE ROW (this should work , i went by deduction)
    PIN for the power connector :
    798-DF1B-2022SC
    20-22AWG SKT CONTACT
    or
    798-DF1B-2428SC
    CRIMP FML CONTACT
    data connector to the controller RS485-USB (same as for the SNC5)
    571-172167-1
    4P PLUG HOUSING (that s the for the plug itself)
    and for the Pins:
    571-170365-1
    SKT 26-22 AWG BULK
