  1. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,440Coins
    No SMC3 only has motor shutdown if they move beyond the max limits setup. It is most likely the IBT2 shutting down. They have a few protection modes that are fairly easy to trip when driven hard
  2. G3yang
    G3yang New Member
    中国
    - 11Coins
    SCN5
    SMC3 I have also encountered this problem, I am in mode 2, running Windows SMC3 utility software,
    The direction of movement, there is no negative direction to turn, have the same problem, how to solve? Thanks for all the friends' reply!
  3. Pit
    30,510Coins
    It does not help @G3yang if you repeat your questions without sharing more details about your configuration, settings etc.
  4. RufusDufus
    Adelaide Australia
    16,440Coins
    @G3yang, a short video and/or screenshots is often helpful... I don't understand what you are referring to?
  5. skiz
    skiz Member
    Software Engineer
    California
    387Coins
    @RufusDufus Thank you for your work on the SMC3 software, it's extremely useful.
    I was able to modify the latest version to support my Adafruit SPI based motor controller quite easily (mode 3!), and I'm wondering if you would be interested in open sourcing the sim tools along with SMC3 on github for collaboration.
    I simply just added some #ifdefs/#ifndef, included my library, and added my own motor run routine and it worked like a charm. However, that's not really scalable for N more boards or any updates in the future.
    I did in the end rewrite nearly all of SMC3.ino to remove the code duplication, extended the comments, structured axes, etc, and I would be happy to get an open source github project rolling that supports any number of community supported boards without extensive #ifdef sauce with your permission (and a suitable OSS license or course).
    Thanks, and here is my current build.
    Look forward to talking to you!
    • Useful Useful x 2
  6. skiz
    skiz Member
    Software Engineer
    California
    387Coins
    Sorry I meant SMC3 tools of course. ;)
  7. RufusDufus
    Adelaide Australia
    16,440Coins
    Sure, you are welcome to do that. It would be nice to have my name (Craig Hoffman) and a link to this thread added to the comments at the top :) but if you have re-written most then that's up to you. I can also add a link at the start of this thread to the github.
    The SMC3Utils will require a bit more effort, the computer I developed it on is packed away at the back of a cupboard somewhere.
  8. skiz
    skiz Member
    Software Engineer
    California
    387Coins
    Great! I set up a github organization and a repo, and will take care of the basics. Are you 'RufusDufus' on github? I'll add you as an owner, and will import the existing arduino code for now. I'm waiting on an OSS exception from work to release my rewrite and to continue with the project.
  9. RufusDufus
    Adelaide Australia
    16,440Coins
    I haven't used github before... just created an account but RufusDufus was already taken :(
    I used CraigHoffmann instead.
  10. fansofbeyond
    fansofbeyond New Member
    china
    150Coins
    This is video.
    I've been checking a lot of times to make sure the connection is correct.
  11. fansofbeyond
    china
    150Coins
    MODE2 The other motor runs perfectly
  12. RufusDufus
    Adelaide Australia
    16,440Coins
    @fansofbeyond have you tried swapping the POTs over to see if the problem is a faulty POT? It seems as though the POT is acting like a switch shorting to GND or +5V.
    You really need to supply more info. Have you looked at the SMC3Utils chart? Does the green line move when you turn the POT? What MODE are you using? What drivers are they?
    I can confirm the motor in the first video is not working as expected but can't tell you much else from the videos.
  13. fansofbeyond
    china
    150Coins
    Thank you very very much for your reply. After repeated testing, I have identified the cause of the problem. One of the IBT-2 has a problem and I have bought a new one. When receiving the goods I will test again.
    Thanks again! Hope everything goes well.
  14. luky_90
    luky_90 Member
    276Coins
    Hi guys, I was thinking of putting bigger engines, the engine cards I use are the single VNH5019 "https://www.pololu.com/product/1451" on the forum I found the schema for the same cards but the most model Great "https://www.pololu.com/product/2502" I have reproduced a scheme but my problem now and on the feed I'm not sure it's okay as I did, I attach a blank picture that someone can help me!!
    Thank you guys!!
  15. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,291Coins
    Hi guys,
    We did a test run on our actuator yesterday and it work, but, not as good as we would expect.
    Here is a video of it.
    The problem is that we do not have smooth mouvement on short distance (it stutter)
    Not shown in the video, with smc3, using the Sine motion also repro the problem.
    The green line seems to follow the blue line correctly.
    Can't post any more details of my smc3 configuration for now as I'm not home.
    Ibt-2 is the driver used.
    Pot is a 10k and seems to. Work correctly(via ohm meter)
    Fpwm=25khz
    Tested different pwm min/max/rev with no big difference.
    Ibt-2 tend to get a little hot even when there is very low amp on it. I suspect that it is eating the charge if the min pwm is not high enough to make the motor turn/turn fast enough.?
    Any suggestions are welcome
    EDIT: I fixed the issue. It was only my PWM min that were way too high.
  16. noorbeast
    153,703Coins
    You will need to post pictures of all of your settings @Wagnard and it would be best to do so on your own thread.
  17. evolaco
    evolaco Member
    Spain
    694Coins
    What difference is there in raising the value KP or PWM max? And the potentiometer to vary the total movement where it is connected?
  18. BlazinH
    16,688Coins
    Increasing kp makes the motor speed ramp up faster and pwm max sets its max speed.
  19. Wagnard
    Wagnardsoft
    5,291Coins
    Got a weird issue today with smc3 motor 1 the one I'm testing switched to off in smc3. no limit were passed , I'm fact I was mostly idle in the middle.
    anyone know what are the possible reasons for smc3 to turn off a motor except when we are passing the deadline limit?
    Edit: look like the POT did go out fo limit but it hasnt physically moved., I Guest Ill have to check for some sort of interference or a POT issue.
  20. evolaco
    evolaco Member
    Spain
    694Coins
    [CITA = "BlazinH, mensaje: 132.839, miembro de: 8,825"]. El aumento de kp hace que la velocidad del motor rampa más rápido y pwm max establece su velocidad máxima [/ QUOTE]
    Thanks for the reply, kp only affects speed? The force is the same? Does it always have the same amps at your disposal?
    I have a problem, testing my motors without load when I move the manual slider fast the motor line goes out of its place and the motor stops turning, only when I put the slider on again it responds again.
    Also I have problems with the rebounds that the connecting rod gives in the changes of direction, it is as if it were stopped of braking and then it has to make some movements to correct
