Tutorial How to write a Game Plugin for SimTools 2.0 - API documentation
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Sep 23, 2016.
  1. noorbeast
    152,391Coins
    +11,076 / 56 / -2
    152,391Coins
    +11,076 / 56 / -2
  3. yobuddy
    51,116Coins
    This is what you are looking for buddy.
    152,391Coins
    +11,076 / 56 / -2
    It is not which Game Engine that is used, but rather how the game is coded. What is the game you have in mind?
    152,391Coins
    +11,076 / 56 / -2
    Best you hit the Unreal 4 forums and tutorials @Wang.
  6. yobuddy
    51,116Coins
    @Wang,
    Once we know how you can send the telemetry values from the game, then which plugin to use will make more sense buddy.
    I would suggest sending data from the game thru UDP.
    And start with the UDP plugin.
    This approach works very well.
    152,391Coins
    +11,076 / 56 / -2
  8. Tim Armstrong
    Tim Armstrong New Member
    USA
    296Coins
    2DOF, 3DOF, Arduino
    Hello :)
    I am a UE4 developer that is new to motion sims and the SimTools software. I am in the process of making a vr game that will make use a motion platform and am trying to understand what data needs to be output and in what format.
    I have been looking over the Dirt 2 sample plugin and see the "Process_PacketRecieved(Text As String)" function as well as the "Outsim" structure that gets populated from the UDP string, but I have a few questions...
    1. What would be the IP and Port I would send to to get the packet to SimTools? Would IP just be localhost?
    2. I am a bit confused also on how the UDP string out of UE4 should be structured...
    - Should the time in milliseconds be how long the game has been running? Would that part of the string be something like "000000000255" = 255 milliseconds over four bytes?
    - I am guessing that the rest is just x,y,z info for the object being simulated...is that correct?
    - Any chance you could provide a sample string showing how the data should be formatted?
    Thanks so much for any help you can send my way! Sorry if these are noob questions...just trying to wrap my head around the data format :)
  9. Tim Armstrong
    USA
    296Coins
    2DOF, 3DOF, Arduino
    Sorry, I do see now in the game settings where you put the port number so please disregard that part. :)
    But still wondering about the IP....
  10. llluis
    Quebec
    1,631Coins
    There you go, the C# template for plugin development.
    Follow the exact same instructions as posted by @yobuddy in the first post.
    • Useful Useful x 2
  11. llluis
    Quebec
    1,631Coins
    @Tim Armstrong, you have to write both ends of the communication: your UE game and the Simtools plugin for it.
    So, you decide what the format, port, etc will be.
    Define an UDP structure in your game and send the data. Use the same structure in the plugin, get the info and send to Simtools.
    IP is provided by the Simtools interface and is the IP where the software is running. Usually localhost / 127.0.0.1.
    You have 9 options to provide motion data to simtools: pitch, roll, yaw, sway, surge, heave and 3 extra (user defined).
  12. yobuddy
    51,116Coins
    Updated the GameVibe section in the first post.
    To show the complete list of sound Names we can use with GameVibe.
  13. axenic
    axenic Member Gold Contributor
    IT engineer
    Brest
    - 17Coins
    Hi there ! I loaded the rollercoaster plugin example. I see in the debug options that there might be a Game_PlugIn_Tester.
    Is it the same thing as the PluginValidator, or is it something else ?
    As I am trying a lot of things at the same time, I would like to know if there was a tool to simulate a game start / stop and the game manager presence ?
  14. gianluca123
    gianluca123 New Member
    109Coins
    2DOF, DC motor, AC motor, Arduino, Motion platform
    Hi, I'm trying to use the plugin example that you provided. I want to send the data from Matlab to SimTool. Specifically, my idea is to send JSON string from Matlab and define the plugin so that it can extract values of both pitch and roll angles. I followed the procedure you posted and everything seemed to work fine, I was able to build and select the defined game from the SimTool GUI. The problem is that I've tried to send values of roll and pitch angles from Matlab and visualize them through the virtual axis in SimTool, and I was not able to see any of the values sent. Here is a picture of the modified code. Thank you for your help!
  15. yobuddy
    51,116Coins
    I would copy the code you pasted there and start a new vb.net app (as a test app).
    Then see if that code grabs the data you need, because the code is not in a dll, it can be easier to see what's going on.
    Once you have the code working, simply paste it into the plugin you built and you should be good to go!
    Hope that helps man,
  16. gianluca123
    109Coins
    Hey! I've tried to develop a vb.net app. Everything seems to work correctly! I have been able to see the data sent through the console. However when I copy and paste the code nothing shows up. I am wondering if the plugin has been correctly uploaded into SimTool, and also if using output testing>>virtual axis is the correct way to test if my plugin is working correctly.
    Here is what I've tried lastly: I've just sent the two variables Pitch and Roll equal to a value 45 degree. I was expecting to have the value displayed here. However, nothing shows up again.
    Also, I've realized that after selecting the game from the engine game, this pops up:
    Shouldn't be showing my name instead of yobuddy?
    Thank you in advance again for your help.
  17. yobuddy
    51,116Coins
    Did you make a max min file for the plugin?
    Can you show me the tuning center buddy?
    Your making a game plugin, not a axis assignment plugin, so my tag name 'yobuddy' will still be present for the axis assignment plugin.
    take care,
  18. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Guys, how do you debug your plugins ? Is there a way todo that and to see (in debugger) if the values (e.g. for roll, pitch, ...) are correctly calculated ?
  19. yobuddy
    51,116Coins
    I usually just write a little app, and do all this there.
    Once I know how to get the data, I copy it into the plugin and I'm off to the races.
  20. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,042Coins
    Arduino, 4DOF
    Same here. A simple stand-alone app that also allows to generate CSV files and validate the calculation/process. Then as yobuddy mentions, a simple copy/paste and here you go !
