Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Hi, as I said, I do not know Codemasters Proxy Server, but from a networcking point of view I think the various setups should be these:
  2. manzes82
    manzes82 New Member Gold Contributor
    - 91Coins
    I think your 3rd picture is wrong.
    The Proxy Server sends the Data to game Manager and game Manager sends it to the 2nd PC.
    Or Do i think completely wrong?
  3. manzes82
    - 91Coins
    Now i checked all possible ways.
    With Game Manager and Game Engine on the same PC it works with the proxy server, with the second entry the hardwareconfig.xml and with portforwarding via simcommander.
    After changing the ip in the Game Manager to the IP of the 2nd PC, no data incoming in game engine :-(
  4. ilbiga
    Network Engineer
    103Coins
    Okay, in that case then the scheme might be this.
    My only assumptions. Sorry if I did not help you :(
  5. manzes82
    - 91Coins
    Good idea. I will gives this a try. Thx
  6. Flashbrain
    Flashbrain New Member
    61Coins
    Hi, i tried to use game dash. But the plugin said in the Editor that dash is not included. Motion in GameEngine is ok.
    I tried
    Reinstall Dirt Rally
    Reinstall Simtools 2.1 and Plugins
    Reinstall gamedash 2.0
    Check Hardware.config
    Check options in GameManager Dash is enable. But Gamedash find not the starting Game.
    Ideas? Thank you
    151,516Coins
    +11,041 / 56 / -2
    Game Dash is not supported in the SimTools DIY license, but is with the Pro license.
  8. Flashbrain
    61Coins
    I have the Pro License. I use Gamedash in other games without problems
  9. manzes82
    - 91Coins
    On Page 22 is a plugin which is working
  10. Flashbrain
    61Coins
    I use this plugin on Page 22. No Connection to Gamedash
  11. Flashbrain
    61Coins
    Oh sorry, Plugin on Page 22 works great. GAMEDASH is OK now. Thank you
  12. dr.feelgood
    dr.feelgood Member Gold Contributor
    FINLAND
    478Coins
    So manzes82, did you get it to work (if you did, how)? I wish someone could point out solid solution.... I'm using 2 pc configuration and some other titles do work, but with this... no go at all...
    It is a bit confusing when some has problems with dash and some with game itself. So which parts of possible solution concerns only to get data to game engine?
  13. noorbeast
    151,516Coins
    +11,041 / 56 / -2
    Do you have a 32 or 64bit computer, as the patch path is different for each with Codemaster games. With 32bit you patch to the game install folder. With 64bit you patch to the /My Documents/Games/Dirt folder
  14. dr.feelgood
    FINLAND
    478Coins
    I got 64bit Win10 and i did patch \My Documents\... I saw patch making a backup of hardware.config-file. Tried to do all windows regional changes, video-settings on game, got fullscreen, did add upd-port-line to config-file, etc. But no luck.
  15. dr.feelgood
    FINLAND
    478Coins
    Still no luck with this.... I reinstalled game and did all tweaking i found from this thread... I have tried both (?) working plugins, but there is no output at udp-port 4123 from my gaming pc (checked with protocol analyzer). Any ideas how to debug this further?
    It sucks, because Dirt Rally was THE game why i built my rig after all..... :(
  16. noorbeast
    151,516Coins
    +11,041 / 56 / -2
    Make sure English local is the computer language settings: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
    What firewall or antivirus do you have?
  17. dr.feelgood
    FINLAND
    478Coins
    Hi!
    So my problem was to get any output from gaming pc (i have 2 pc configuration !!). I tried and tried all kind of settings in this threat, exept..
    Solution: After patching, edit line in hardware_settings_config.xml to match your game engine pc :
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="4123" delay="1" />
    to
    <udp enabled="true" extradata="3" ip="ip.of.your.game.engine.pc" port="4123" delay="1" />
    Thanks for u all, it is now were SWEET to drive Dirt Rally with motion.
  18. value1
    14,996Coins
    Only patch the game AFTER setting the IP address of GameEngine (of the second PC) .
    By that the
    hardware_settings_config-entry will be correct automatically.
    Tools
    Engine IP
    OK
    Enter the IP address of the 2nd PC where you run GameEngine
    Click on Tools again
    Patch the game
    • Informative Informative x 3
  19. dr.feelgood
    FINLAND
    478Coins
    Yap. I say that Dirt Rally patcher didn't work on my pc... it always put 127.0.0.1 on that file..... Dirt Rally was... i think 3rd game i patched in the beginning and all other worked straight away... I also deleted all files (in simtools also) according to DR few days ago, downloaded whole game via dead slow connection lasting about 10 hours, before could try again -> no go.
    It would have helped if i knew that destination address was the goal to put in that config-file (as i discovered from Dirt3 and Dirt4).
    But i am a very happy chappy now :D
    btw. Reps to you @noorbeast , U r a patient guy !!!
  20. Guilherme Bastian
    Guilherme Bastian New Member
    Brazil
    151Coins
    Still did not work for me. I inserted my IP on game manager and after that I patched the game. After that I edit the hardware_settings_config.xml to insert my IP number. When I run dirt rally game dash does not recognize the game and dont load its profile. Everything working in other games like assetto, rfactor 2, nolimits2, etc.
