simple 2 dof wiper sim
Discussion in 'DIY Motion Simulator Projects' started by Arunas, Apr 1, 2017.
  1. Arunas
    Arunas Member
    Lithuania
    2Coins
    I ordered these 2 pcs motors. They are
    150/160 rpm 25:1 ratio.
    http://www.ebay.com/itm/351066992384?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    or better i needed these? Thank you for your advise.
    75-80RPM 50:1
    http://www.ebay.com/itm/GEAR-MOTOR-...L-FEED-SIMULATOR-75-80RPM-50-1-/371596157992?
    153,722Coins
  3. Arunas
    Arunas Member
    Lithuania
    2Coins
    My one of 2 monstermoto has died. I ordered 2 pcs. 43A IBT-2 found on ebay ( now think needed more ). If something wrong with one IBT-2 Is it possible to use one monstermoto and one IBT-2 with the same arduino uno? I think it is possible to wire but will not be any mismatch?
  4. Arunas
    Arunas Member
    Lithuania
    2Coins
    My new motors arrived. Continue my project.
    Used polymorph ( ) to fitt hall sensor on motors. It is more accurate because hall sensor has no mehanical conections with magnets. Some photos.
    153,722Coins
    Nice progress @Arunas.
    I suspect the levers are a little long, somewhere in the 30-40mm CTC will likely be the zone to drive what is a pretty compact design.
  6. Arunas
    Arunas Member
    Lithuania
    2Coins
    Its alive. My sim is working. :D
    I made a little video of my 2 dof with SMC3 and LFS. Sorry for bad quality.
  7. Arunas
    Arunas Member
    Lithuania
    2Coins
    I have a question? Does my project meet the conditions to ask a fee DIY Simtools license? I would like to try it with DCS.
    153,722Coins
    Yes it would qualify.
  9. Arunas
    Arunas Member
    Lithuania
    2Coins
    Thank for help to everybody in this forum and especially for you for your help. Great forum. I will try DCS and will make video.
  10. Arunas
    Arunas Member
    Lithuania
    2Coins
    Very sad but from all 4 pcs motomonsters and 2 pcs IBT-2 not working. only one motomonster. Wanted to save a little money. :D. Ordered Sabertooth 2x32. Now long wait again from USA.
    Question is Sabertooth 2x32 is better quality?
    153,722Coins
    Sabertooths are quality boards, but can you explain a bit more about what exactly is the problem you had?
  12. Arunas
    Arunas Member
    Lithuania
    2Coins
    One of motormonster burned yesterday and 4 pcs motormonsters and 2 pcs IBT-2 all new I ordered earlier not working at all. Bad Chinese copies. :D Now I have only one working monstermoto. No more Chinese copies because it is waist of time and money i think. I will wait 1.5 month my Sabertooth from USA. :D
  13. Arunas
    Arunas Member
    Lithuania
    2Coins
  14. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    Yes that works. Do not forget to enter "Mode 2" in the ArduinoCode. That happened to me. :rolleyes:
    // Set to MODE1 for use with a typical H-Bride that requires PWM and 1 or 2 direction inputs
    // Set to MODE2 for a 43A "Chinese" IBT-2 H-Bridge from e-bay or equiv
    #define MODE2
  15. Arunas
    Arunas Member
    Lithuania
    2Coins
    Found :D . Made test. Both IBT-2 output to motor -6 V - +6 V. Will IBT2 43 A be good for my 12 v motors with 15 A ( 180 W ). 6v* 43 A - 258 W. They must be ok for my motors. Am i right?
      142.8 KB
      797
  16. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    Yes that's right. Mode 2.
    I'm still a beginner with this Sim technology. But the power should fit. Just test and observe the temperature of the IBT2 heat sink when using.
    Thanks for that polymorph information. I find it very interesting :thumbs
  17. Arunas
    Arunas Member
    Lithuania
    2Coins
    Thank you very much for free Simtools lisence and for game plugins. Made some video with Joystick plugin. :grin
  18. Arunas
    Arunas Member
    Lithuania
    2Coins
    Made a little video with DCS BF 109. Axis assigments for me is very good. I am very pleasd with my 2 dof seat. :D Thank you for advices if something not very good.
  19. Arunas
    Arunas Member
    Lithuania
    2Coins
    I think this was wrong axis configuration for sway. Sway must be opposit roll. Smoothing for roll and pitch 20 % :)
  20. Arunas
    Arunas Member
    Lithuania
    2Coins
    Hi all. I had to reinstall simtools. Deleted folders Simtools and Simtools license from c/user/name/Appdata/local/... Tried reinstall few times. [​IMG] [​IMG] [​IMG] Simtools DIY registration is ok. Please help. SimTools_2.2.5 version.
      908.7 KB
      699
      941.6 KB
      709
      992.7 KB
      666
