VR Motion Cancellation - Time to test!
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by noorbeast, May 6, 2017.
  1. BAER
    BAER New Member Gold Contributor
    washington
    137Coins
    If you already have the emulator just run the new hotfix. It worked for me, after they updated SteamVR.
  2. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,944Coins
    Many thanks. That fixed it straight away.
  3. matthew loomis
    matthew loomis Member
    rochester,ny
    603Coins
    Just wanted to drop in and say this worked perfect on my Vive and project cars.:D
  4. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    great !! This is what I was hoping !! test on VIVE !!
    151,479Coins
    +11,041 / 56 / -2
    A bit of an update from my original comments on the subject, based on owning the Rift and Vive, plus doing lots of public VR demos.
    Price is now a significant factor following the Oculus price reduction, but it is not necessarily a determining one.
    It makes sense to choose the Vive if your choice is driven by above average or large roomscale, robust tracking, not wanting USB cables snaking everywhere, you plan early adoption of eye tracking, wireless and tracked peripherals, are considering motion simulation and want native motion cancellation, wear glasses or need greater adjustability for eye issues, or if you have a philosophical concern about Facebook and user data.
    Choose Oculus if your choice is driven by lower price, included audio, refined design, slightly larger sweet spot and slightly less screen door effect and you want native freebie/exclusives, or if you never plan on using tracked controllers.
    The Rift really benefits from a third sensor for roomscale but be aware it does not play nice with all USB ports or cables, plus other USB peripherals like wheels, pedals and HOTAS may complicate the USB bandwidth issues.
    The Vive controllers are great at simulating things, such as guns and swords, while Touch is better at simulating hands. Personally I prefer the Vive haptics and Oculus positional audio, but their respective counterparts are fine and not a deal breaker.
    The Vive wands can also be used in creative ways, such as a joystick, wheel or virtually any other input device: https://www.xsimulator.net/community/threads/use-vive-wands-as-a-joystick-or-wheel.10452/
    With respect to tracking according to this data source less than 2% of Rift owners (4 cameras) experience comparative tracking with the Vive, and even then only reach those comparative figures over a much smaller tracked volume of less than 8sq m, with the average being only 3.3sq m, while the Vive average is a much more substantial 5.7sq m and can go out to an officially supported 12sq m: http://ghostline.xyz/publications/W...[{"num":1375,"gen":0},{"name":"XYZ"},0,595,0]
    In fact the Vive can actually do up to around 28-30+sq m with two base stations:
    My personal Vive playspace is big enough (8x4m) that I can also run my Rift in the area normally used by just the Vive:
    I have and use both the Rift and Vive in lots of public demos and have had thousands of users. Last week was the Bay of Fires Youth Arts Prize, this week it is the State Youth Conference. In my experience there are far greater differences between individual users and use cases than there are between the Rift and Vive themselves. As a consumer you really can't go wrong with either the Rift or Vive HMD for first gen consumer PC VR, both will be superseded but that is at least a year or more off. The best thing is to try them both, preferably back to back, and then choose what suits you best, based on your own personal needs.
    There are other HMDs hitting the market later this year, which you may also want to consider, if you can wait.
  6. paulopsx2
    brasil
    647Coins
    could i run only 1.0.3 update file? i dont have any other...
    151,479Coins
    +11,041 / 56 / -2
  8. paulopsx2
    brasil
    647Coins
    151,479Coins
    +11,041 / 56 / -2
    As indicated in its title the hotfix is for the new SeamVR Home, which likely you will now have if Steam is up to date, as it has been rolled out.
  10. RobsonSwiss
    RobsonSwiss Active Member
    Preotria, South Africa
    35Coins
    Hi
    Is it not possible to take the motion output data and subtract that from the headset movement, rather than to have a separate controller that does the subtraction?
    151,479Coins
    +11,041 / 56 / -2
    The HMD tracks the user head, the controller tracks the rig movement, you need both.
  12. RobsonSwiss
    35Coins
    I understand the principal of operation, my question is why track the motion platform since you are already sending the movement data, for instance if you are telling the motion platform to pitch 10 degrees, why not then inject that 10 degrees to the driver as well to subtract from the headset measurements.
    So right now it's: Motion sent to platform - platform moves - measurement sent to pc - subtract from headset data.
    Why not: Motion sent to platform - subtract motion sent to platform from headset data.
  13. noorbeast
    151,479Coins
    +11,041 / 56 / -2
    The motion data does not precisely measure the seat movement in 3D space, in fact the same data sent to very different designs would result in substantially different movement in 3D space. With sub mm VR tracking it is trivial to measure 1:1 where any design rig is moving.
  14. RobsonSwiss
    35Coins
    Thanks that makes sense...
    Btw, it's not really sub-mm... http://doc-ok.org/?p=1478 But I get that some rigs are likely to be a factor worse than that in any case.
    151,479Coins
    +11,041 / 56 / -2
  16. RobsonSwiss
    35Coins
    If everyone tested at 2m or 4m you'll find different results from each user in any case due to manufacturing tolerances. Unfortunately valve's system isn't open or described in detail, I've thought about ways of trying to reduce the error but they might have already implemented these...
    I'm playing around with the idea of using a single beacon with 4 lasers(hard drive motor that I stripped, spins over 10Krpm but noisy beyond 6000rpm), I think 2mm would be well acceptable. I have mounting holes underneath to bolt it down on a rig but it's expensive to have the FPGA TDC dev work done, so might have to wait a bit.
    But since there is an Opentrack driver out for SteamVR I'm going to try that in the next couple of weeks and see if it's successful... if so I'll do a dedicated helmet.
  17. benmax
    1,552Coins
    hi ,
    This is my simulator
    Now I use oculus rift instead the video projector as the video shows
    Ran the input emulator with hotfix installer
    Tested multiple setup combinaison but always the view bounces when acceleration or braking with assetto corsa.
    Maybe missed something in installation.
    Mounted the right touch just on my seat behind my head .
    One question :
    When i looked at the steam vr home window before launching the race , the right touch used as input controller not in green higlighted . Is it normal ?
    Look'at the pic attached :
    Anyway thanks for the guy who created the feature for simulator !
  18. Zed
    USA
    5,844Coins
  19. paulopsx2
    brasil
    647Coins
    This is because your control or vive track isnt green on highlights steam vr. You have a room scale back on your seat ? I mean.. new bases for room scale or recognize this control back on your seat
  20. Zed
    USA
    5,844Coins
