value1
Joystick plugin 2.0.0.1
SimTools plugin to read the joystick values
  1. bergstein
    bergstein New Member
    CHINA
    224Coins
    really really thanks for the spectacular work that had been done.
  2. Leandro Kemp
    Brasil
    - 10Coins
    Any news on how to play a recorded data?
    153,812Coins
    +11,150 / 57 / -2
  4. BOUVEROT CLAUDE
    BOUVEROT CLAUDE New Member
    simracing, video game, music, movies, sports
    Saint Gervais Les Bains - France
    115Coins
    2DOF, SCN6
  5. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    great, works as well. thanks.
    but.. my left thumb, dont have a "correct" movements for most used games.. like a PITCH UP( push thumb down ), PITCH DOWN ( pull thumb up ) and ROLL LEFT ( push thumb left ) ROLL RIGHT ( push thumb right ); and no uses for RIGHT THUMB on general games ) some idea how to change this?
  6. Leandro Kemp
    Brasil
    - 10Coins
    Yes. I already have the video Ride creator. The problem is to click clicking point by point to configure each movement. Could not you put the joystick recording data together with the video?
  7. Leandro Kemp
    Brasil
    - 10Coins
    Send me a ZAP that I explain. KKK.
  8. paulopsx2
    brasil
    647Coins
    Mkay rs
  9. chappy
    chappy New Member
    Melbourne, Australia
    231Coins
    2DOF, JRK
    thanks for this plugin, looks like its probably the best option for titles like IL2 BOS where no data is provided by the developers to aid in these projects (yet)
    anyone tried this with either x55 or G940 joystick axes?
  10. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    hi
    i have g940 work fine :grin
  11. paulopsx2
    brasil
    647Coins
    Im using g940 too... but... how to change axis thumbs?
  12. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    in sim tools game engine ..... ( axis assignments) ...... Joystick
  13. paulopsx2
    brasil
    647Coins
    weird.. i try this. but axis are assign on diferent patches, for RIGHT thumb. I try some combos like a pitch roll disable, change to heave, but dont works
  14. George Dobransky
    Hungary
    - 43Coins
    Hi guys,
    Joystick selection table at start has dissapeared. Till now it was shown and selectable. Only small window
    can see. Any ideas?
    George
  15. George Dobransky
    Hungary
    - 43Coins
    Hi There,
    I Have X56, with 2 usb. One for the thrust unit, one for the joystick unit.
    I can only use with the plugin one in the same time.
    Any ideas to use both USB units (thrust and joy)?
    Cheers,
    George
  16. paulopsx2
    brasil
    647Coins
    Unfortunely, isnt possible. If you run joy plugin, the program asks you abou your joy. Only one for use.
  17. jesusete007
    jesusete007 New Member Gold Contributor
    VAENCIA
    157Coins
    Hi there!
    Im also interested to know if Thrustmaster - T.Flight Hotas X is supported.. :)
    thanks in advance for any help!
    regards
  18. George Dobransky
    Hungary
    - 43Coins
    Guys,
    Here is an article I wrote to Elite forum about you can easy set up any joystick, or multiple joysticks with more than one usb with the following method:
    Joystick plugin only can manage 1 joystick input, so if you have stick, thrust and pedal separatelly with 2 or 3 usb inputs, or if you have some compatibility problems with your joy, you can use the software called vJoy, a virtual joystick device. you can download from here:
    https://sourceforge.net/projects/vjoystick/files/Beta 2.x/
    There is several versions, the new ones has a chance to get an installation problem with win7, or win10, in this
    case you can try an older version. I have spent some hours with that fcking issue....:(
    You need also a remapper utility, for new versions of vJoy there is UCR, link:
    https://github.com/evilC/UCR
    For older versions of vJoy, you can use UJR:
    http://evilc.com/fil...hk/vjoy/ujr.zip
    With these utils you can easily set up multiple joys or usb input into one, and a lot of advantages
    there, like you can program some movements to buttons, axes, etc. For example you can program any
    movement to landing gear down, or hyperjump, etc.
    Hope it helps you in these unhappy days....
    Cheers,
    George
  19. jungletech
    jungletech New Member
    California
    158Coins
    In case anyone else has a problem with getting the plugin to detect joystick movement when multiple devices are plugged in, I had to go to my game controller setting in the Windows control panel and select the preferred device. The plugin was detecting movement from my xbox 360 controller, but not my HOTAS. Changing that setting fixed the issue for me:
    Thanks for this plugin, it's been awesome!
    • Informative Informative x 4
  20. Youngsoo Cho
    Youngsoo Cho VR Sim Racing Gamer
    Business Man
    Korea
    467Coins
    it works fine but,
    fanatec csw 2.5 is off center - 32768 is default value for roll/sway/heave and 665.35 for extra 1.
    so my dofreality v3 rig keep being off center everytime I run the plugin.
    how can I handle it? any ideas?
