Formula 3 simulator :)
Discussion in 'DIY Motion Simulator Projects' started by Gadget999, Sep 26, 2016.
  1. Gadget999
    12,035Coins
    so i tried a copy of simtools - cant seem to get it to communicate - however the SMC3 program does work
    is there a quickstart guide anywhere ?
    152,571Coins
    +11,087 / 56 / -2
    The documentation is here, though a little dated in parts for SimTools 2: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    The main difference needed for SimTools is in Input Settings, where instead of axis being defined like this <Axis1> it is now like this to designate grouping for a or b: <Axis1a>
    For a 2DOF you can ignore the b grouping, it wont be needed.
    Here are the steps to create and refine motion profiles, as one is needed for each game: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    The demo version of SimToos 2 has the fully functional plugin for Live For Speed included for testing purposes, it works fine with the free demo version of LFS.
    Conditions apply but DIY projects are eligible for a free SimTools 2 DIY license, see here for details: https://www.xsimulator.net/community/faq/request-a-free-diy-simtools-2-0-license.262/
  3. Gadget999
    12,035Coins
    thanks for the advice noorbeast :)
    i will get lfs downloaded and see if i can make it move
    i will probably use rfactor when i have worked it out
  4. Gadget999
    12,035Coins
    so far i have downloaded LFS and simtools 2.1
    i am trying to get the Sim to drive manually using the mouse
    my guess is the axis settings are wrong - is there a standard setup for a 2 motor sim using an arduino
    I am using the Simforce GT profile
    am i correct you need only one axis setup Axis(a) ?
    when i click 'Turn on' in output testing the arduino lights up but nothing happens with the motors
    152,571Coins
    +11,087 / 56 / -2
    You first need to run LFS for a couple of laps before patching it for motion, as some key files are generated. If you did not do that then unpatch it, run a lap or two, then re patch for motion.
    You do need to properly configure the Interface settings to suit the code you are running. The main change with SimTools 2 is that instead of axis defined like this <Axis1> it is now like this to designate grouping for a or b: <Axis1a>
    You won't need the b grouping for a 3DOF, so just ignore that.
    A stock profile may get you started, depending on how your rig is configured, but to get the most out of it you need to learn how to make and refine profiles, which takes time, practice and experimentation.
    To do so you need to create a Default Axis Assignment profile and you can test the sim moves manually in Output Testing. This is how SimTools expects the setting to move the rig and the Dir boxes being checked or unchecked determins which way each axis/force moves: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    Next you need to create a LFS Axis Assignment profile and refine the motion profile settings: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  6. Gadget999
    12,035Coins
    these are the settings for the Axis and interface
    do I have the correct settings for the Arduino and the Axis
    152,571Coins
    +11,087 / 56 / -2
    As per my earlier advice your Interface Output needs to be like this <Axis1a>and this <Axis2a>
  8. Gadget999
    12,035Coins
    Thanks again Noorbeast
    so the settings should be
    L7FR7F
    L<Axis1a>R<Axis2a>
    L7FR7F
    i will plug them in tomorrow and give it a go
    how do you adjust the PID settings ? do they get set by the sway % numbers
    152,571Coins
    +11,087 / 56 / -2
    If you are using SMC3 then the PID is managed via its Windows Utility.
  10. dr.feelgood
    dr.feelgood Member Gold Contributor
    FINLAND
    478Coins
    Hi.
    If it still is not working to you, change values in Interface Settings-screen:
    Stop bits: 1
    BitsPerSec: 500000
    Output - Bit Range: 10
    Output type - Binary
    ...somebody should really update the documentation...
  11. Gadget999
    12,035Coins
    so far not getting anywhere :(
    the rig will move when i use SMCutils
    but not with simtools V2.1
    the interface looks like this
    is it correct ?
    perhaps i need to try an older version of simtools ?
  12. Gadget999
    12,035Coins
    my guess from looking at the Arduino code is the format needs to be like this
    // [Axx],[Bxx],[Cxx] Send position updates for Motor 1,2,3 where xx is the binary position limitted to range 0-1024
    [A<Axis1a>],[B<Axis2a>],[C<Axis3a>]
    the number will be binary 0 - 1023 (10 bit)
    i will try it again tomorrow
  13. noorbeast
    152,571Coins
    +11,087 / 56 / -2
  14. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,314Coins
  15. Gadget999
    12,035Coins
    we have motion !
    thanks everyone for the help especially noorbeast - there is a lot of conflicting information and it takes time to realise you are reading the wrong thread !
    hopefully now i will be able to assist someone else in my position to return the favour to the community
    right time to play with the settings and take this sim for a drive :)
    i will post a video up soon
  16. Gadget999
    12,035Coins
    ok i have installed simtools and installed my DIY license
    i have patched the game to c:\LFS\
    as i open the game i get a microsoft.net error message
    see below
    Code:
    System.ComponentModel.Win32Exception (0x80004005): Only part of a ReadProcessMemory or WriteProcessMemory request was completed
       at System.Diagnostics.NtProcessManager.GetModuleInfos(Int32 processId, Boolean firstModuleOnly)
       at System.Diagnostics.ProcessManager.GetModuleInfos(Int32 processId)
       at System.Diagnostics.Process.get_Modules()
       at SimTools_GameManager.frmMain.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
       at System.Windows.Forms.Timer.OnTick(EventArgs e)
       at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    mscorlib
        Assembly Version: 4.0.0.0
        Win32 Version: 4.7.2101.1 built by: NET47REL1LAST
        Assembly Version: 0.2.1.0
        Win32 Version: 0.2.1.0
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    xdFZySjlJvJuSyJCrKNFqiOVuiS
        Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
        Assembly Version: 10.0.0.0
        Win32 Version: 14.6.1586.0 built by: NETFXREL2
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
        Win32 Version: 4.6.1586.0 built by: NETFXREL2
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
        Win32 Version: 4.6.1647.0 built by: NETFXREL3STAGE
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Accessibility
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Runtime.Remoting
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Configuration
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Core
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Game_PluginAPI
        Assembly Version: 1.0.0.0
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Game_PluginAPI.DLL
    System.Management
        Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    KartRacingPro_GamePlugin
        Assembly Version: 2.0.1.0
        Win32 Version: 2.0.1.0
        CodeBase: file:///C:/Users/User/AppData/Local/SimTools/GamePlugins/KartRacingPro_GamePlugin.dll
    LiveForSpeed_GamePlugin
        Assembly Version: 2.0.0.0
        Win32 Version: 2.0.0.0
        CodeBase: file:///C:/Users/User/AppData/Local/SimTools/GamePlugins/LiveForSpeed_GamePlugin.dll
    Microsoft.GeneratedCode
    enabled.
    For example:
    <configuration>
    </configuration>
    any suggestions greatly appreciated :(
    152,571Coins
    +11,087 / 56 / -2
    Try downloading the latest windows .NET build from microsoft, uninstall the existing .NET then do a clean reinstall.
  18. Gadget999
    12,035Coins
    H
    i noorbeast i will give that a go.
    (When i originally went to install .net it told me it was part of the operating system and i did not need to reinstall it.)
  19. Gadget999
    12,035Coins
    not had much luck installing .net - windows is telling me i don't need to install it because it is part of the operating system
  20. Gadget999
    12,035Coins
    does simtools need to be run in a compatibility mode for an earlier version of windows ?
