Tutorial How to Modify a Server Power Supply for 12v
Discussion in 'DIY peripherals' started by Slider, Sep 7, 2014.
  1. Zed
    USA
    5,845Coins
    @mirkobastianini - I think your connections might work but don't know for certain.
    Each power supply looks correct by the tutorial but I don't know about paralleling the control pins. The power supplies may or may not be ok with that. In server use with redundant supplies, if that is how they get connected, you should be ok but I just can't say for sure.
    If you got a double pole switch instead you could keep the control sections separate and not have to worry.
    Maybe someone else will know...
  2. Nick Moxley
    You would be the first to attempt this to my knowledge, Be sure to let us know if they let out the magic smoke. :p
    Also agreed, if your only firing up 2 supplies, a DPST is what you want. Will eliminate the need or thoughts of potentially messing up the supplies.
  3. mirkobastianini
    mirkobastianini Active Member
    informatic
    italy
    1,300Coins
    I've decided to solve problem on top: this is my switch:
    I've simply ordered another of this thing, so i can use 2 poles.
    What do you think about it?
  4. Nick Moxley
  5. Zed
    USA
    5,845Coins
    @mirkobastianini - that looks like the solution. Two poles will be fine for two supplies. If you ever add a third axis or more, you can revisit.
  6. Gadget999
    12,053Coins
  7. Dicko
    Dicko New Member
    Kangaroo Island Australia
    164Coins
    Hey, I have some HSTNS-PL18 psu, I've seen that you can short a couple of pins with a resistor to turn it on, does anyone know if there is a fan speed mod for this psu?
  8. erivx
    erivx Member
    Ecuador
    206Coins
    2DOF, Arduino, 4DOF
  9. Gadget999
    12,053Coins
  10. domnulvlad
    domnulvlad New Member
    27Coins
    Hi! I am looking for a good power source for a 2 DOF build I'm planning on making and I was thinking of getting two 750W supplies.
    I can't decide between two server PSUs, one is from HP and the other from Dell.
    I can't add external links yet so I will upload a photo of both eBay listings.
    HP:
    Dell: (only 4 units left)
    Can someone please help me decide between the HP HSTNS-PL18 and the Dell 2950 PSU?
    Also the total price difference is of ~$13 (in favor of Dell), and as I am (of course) going for a cheap build, I already think I'm going with Dell. If there are more cons than pros, then I will choose HP (a brand I trust more).
    Thanks.
  11. Gadget999
    12,053Coins
    In the end i used 2 x 12 car batteries and a 25a 24v power supply
    The server power supplie did not like the regenerative braking and would shut down
    152,627Coins
    +11,087 / 56 / -2
    I know the Dell's have been modified and used by members: http://www.xsimulator.net/community/threads/how-to-modify-a-server-power-supply-for-12v.5774/
    Not so sure about the HSTNS-PL18, you would have to research those a bit to be sure.
  13. Bobby2682
    Bobby2682 New Member
    98Coins
    152,627Coins
    +11,087 / 56 / -2
  15. Bobby2682
    98Coins
    I'm sorry but am I missing something. When I follow the link you posted and click on the link for the 2950 psu it takes me to this thread and to the 1st post (for moding the dps-600bp b) that I referenced in my post. I don't see any information about modding the 2950, only the mention that I quoted in my first post. Sorry if I'm not seeing it but if you could be so kind to link I would really appreciate it.
  16. noorbeast
    152,627Coins
    +11,087 / 56 / -2
    Post 8 shows the modified Dell 2950 PSUs: https://www.xsimulator.net/communit...-server-power-supply-for-12v.5774/#post-65089
    With post 14 providing a brief explanation: https://www.xsimulator.net/communit...-server-power-supply-for-12v.5774/#post-68351
  17. Gadget999
    12,053Coins
    I tried converting several server power supplies
    It works until there is a surge and they shut down.
    A waste of time and money imo
    A decent ppwer supply and a car battery works pretty good in my experience
