2DOF project
Discussion in 'DIY Motion Simulator Projects' started by MarcNSF, May 30, 2017.
  1. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    Thanks @Ned and @ferslash
    @ferslash bending was the easy part: 12mm filled steel pipe ,on a pipe bender made a circle D86cm and cut it in half
  2. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    more testing:p
  3. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    Bought this actuator today
    Wanted to fix it as heave but instead going to use it as a replacement for surge because my old motor is heating up after 15 min and reduces more than 50% of the motion
    153,746Coins
    What are the specs of the actuator?
  5. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    Hi noorbeast
    It's 18mm/'s not 25 as they say in the documentation
    I know that it's slow but with the right leverage I think it will provide the motion intended
    153,746Coins
  7. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
  8. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    Each 10mm on the actuator = 10 degree of surge/pitch
    Will have to test it more though to check if the actuator motor will heat up
  9. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    :oops: it didn't work
    Under 80kg load the movement was soooooooo slow didn't even react on time
    153,746Coins
    Member experimentation is a good thing and while that was not an unexpected result it is useful confirmation for others about the speed necessary for good motion.
  11. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    @noorbeast The specs of the actuator tricked me it couldn't even lift 100kg and at 75kg the speed was 4mm/s
    you were right :cheers
  12. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    fixed a wiper motor with 1 spring
  13. Gadget999
    12,132Coins
    can you modify the internal to make it faster ? will it run 24v instead of 12 for example ?
    153,746Coins
    Normally the innards are not designed to take loads and speeds that are 10-15 times faster.
  15. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    @Gadget999
    The motor speed is already 3000 rpm the voltage doesn't matter
    If it wasn't maybe I would have tried to change the motor but as noorbeast said they are not designed to take these kind of speeds
    thanks for trying to help :cheers
    Marc
  16. wangdaokun
    wangdaokun New Member
    2 AVENUE FRANKLIN D ROOSEVELT 21000 DIJON
    148Coins
    I am a creative design, before I had a similar idea, but in the end I chose the mainstream design practice. Recently I'm looking for some new design ideas, if find a suitable design scheme, I will again DIY simulation platform!
  17. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    Changed the DIY analog handbrake
  18. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    And a new lap, gear, rpm and speed display
  19. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    A voltmeter display with an emergency kill switch
  20. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    New seat and a new TV stand
