DIY high power Bass Shaker
Discussion in 'DIY peripherals' started by Alexey, Jul 6, 2015.
  1. RacingMat
    21,082Coins
    [​IMG] aouch! :eek:
  2. h106frp
    h106frp New Member
    117Coins
    I guess they have quite a high frequency applied. Useful for brazing - not magnets ;)
    But add a suitable core and you could easily saturate it at lower frequency. :cool:
  3. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    Would only using a positive cycle square wave (0 - +12v as opposed to +12v - -12v) have any detrimental effects?
    Would the fly-back diode dissipate the stored energy quick enough before the next pulse come through (70Hz max) or would a transient suppressor diode be better suited? Currently my plans are to use a mosfet as a switch, using a square wave generator to trigger it. I'd basically be using the mosfet to turn the magnetic field on and off.
    Cheers
  4. h106frp
    h106frp New Member
    117Coins
    You need to reverse polarity every other cycle or you will gradually get DC field build up in the core. From a logic type square wave you can use a flip-flop and op-amps to get the positive and negative components required to have a magnetic field that reverses each time and creates the magnetic pull.
  5. Alexey
    Adelaide, Australia
    8,066Coins
    Ok I'll look into that and come back with a design. Than you for your input, it is much appreciated.
  6. h106frp
    h106frp New Member
    117Coins
    No problem, basic scheme is pulse train fed to flip-flop and each output on flip flop will toggle alternately but will never be 'ON' together, one output will need inverting before you sum the 2 outputs back together. You will need a bipolar supply and op-amps for inverting and summing.
    Some modern H bridge drivers will do the inversion bit for you and you only need to feed it the 2 flip flop logic outputs.
    Like this one that i have used alongside their demo ucontroller board before - note PWM0 and PWM1 inputs - think you can download all the data sheets.
    http://uk.farnell.com/analog-devices/eval-cn0196-eb1z/adum7234-h-bridge-drvr-eval-board/dp/2070661
    Before anyone asks, yes it is feasible to replace the FETS with headers and connect bigger output FETS :grin
  7. MauroM3
    MauroM3 New Member
    Tecnical Consultant
    Canoas - RS - Brazil
    338Coins
    2DOF, 4DOF
    Good idea, I tried it with a bass speaker, and had some success. But did not cut the speaker cone . Its idea is the best I've seen so far.
    Congratulations.
    And I'm behind transformers to test ..
  8. trust928
    trust928 Member
    brazil
    435Coins
    awsome boy, but a lot of work lool
  9. trust928
    trust928 Member
    brazil
    435Coins
  10. daldosch
    daldosch New Member
    Wien
    288Coins
    pretty good idea, I just found a source of free available electromagnets:
    I take the ballast from obsoleete HQI Lamp fixtures. They have about 8 Ohms, so no need to recoil them! Every store is nowadays changing to LED lightning, so they throw out their old lightning utilities. I used 2 in parallel, one on top of the other.
    And you are right, considering square waves. Sinus or music like waves are for magnets unsuitable, they need on and offs.
    truely Johannes
      64.3 KB
      919
  11. daldosch
    daldosch New Member
    Wien
    288Coins
    Here is a circuit that I`ll try, I´ll post it in my next posts.
    Ne 555, astable smith trigger, base freq 1-10Hz, and controlle the freq by musik. A power FET will make those Mags rumble. A car battery 21 V hsould be fine, may be 24V .
    truely Johannes
  12. daldosch
    daldosch New Member
    Wien
    288Coins
    The I plates came of quite easy.
  13. daldosch
    daldosch New Member
    Wien
    288Coins
    Now I can post the link to the cirecuit I found:
    http://makezine.com/projects/plasma-arc-speaker/
    It uses 23 KHz, so I`ll use 1M ohm and 10 µF for 1Hz.
    And of course we don`t need the tessla coil, ninsteat of it the power magnet goes.
    Truely Johannes
  14. daldosch
    daldosch New Member
    Wien
    288Coins
    This is what I came up over the weekend:
  15. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    im using some aura shakers.. this code works well on it? or its specific for your project?
  16. Javo5
    Javo5 Active Member
    Buenos Aires, Argentina
    300Coins
    Awesome! Too bad I threw away so many transformers
  17. Pastrana
    Pastrana Member
    Argentina
    165Coins
    What happened with this project? There were no more advances?
  18. paulopsx2
    brasil
    647Coins
    Shakers like aura or buttkick are more simple and easy to setup.
