vthinsel
F1 2016 UDP Plugin - Manual plugin start 1.0
F1 2016 UDP plugin
  1. Leandro Kemp
    Brasil
    - 10Coins
    Now on my PC too. UDF F1-2016 error.
    An image of each PC
  2. Leandro Kemp
    Brasil
    - 10Coins
    Images
    152,373Coins
    +11,076 / 56 / -2
  4. Leandro Kemp
    Brasil
    - 10Coins
    Silves.
    I downloaded the plugin again.
    It was some error during the first download.
    Thank you.
  5. santanadany
    santanadany Member
    Chile
    605Coins
    hello @vthinsel ,I have Problem with "Sway",definitively I do not obtain the side movements, have proved everything, from the beginning , and on having used the test, two axes move in the same sense ... only it happens to me with the F12016 UDP, with Project Cars it works to 100 %, please Help.
  6. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,042Coins
    Arduino, 4DOF
    If the values are changing in tuning center ? If yes then it is a problem with min/maw or axes configuratino that need tuning.
  7. santanadany
    santanadany Member
    Chile
    605Coins
    @vthinsel , Yes, I will try again today and inform you, Thanks
  8. santanadany
    santanadany Member
    Chile
    605Coins
    @vthinsel , Today I tried everything again, and I only have problems with Sway, help .. I attached my configuration (this was the last of several ...)
    thanks , I need G force... :(
      183.1 KB
      771
      173.3 KB
      754
      144.6 KB
      734
      179.3 KB
      757
    152,373Coins
    +11,076 / 56 / -2
    You say you have a problem with sway but don't say or show what that problem is, does it move in the wrong direction or something else?
    Your settings do look a bit odd.
    Normally the Dir settings for roll would be the opposite to sway. Yaw should not be needed at all on a 2DOF rig.
    Here are the steps to creating and refining a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  10. yobuddy
    51,114Coins
    @santanadany, can we see a pic of your simulator buddy?
  11. santanadany
    santanadany Member
    Chile
    605Coins
    @noorbeast ,
    I have all the other movements in my simulator, but no sway, and I only have problems with f12016 UDP, with projectcars UDP everything works perfect, I put all the others motion in off and I just leave sway and I don´t have movements in my simulator.
    Only don´t have sway...
    I already did 4 times: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    @yobuddy this is my simulator : https://www.xsimulator.net/communit...2dof-for-playstation-4-from-chile-2017.10844/
    attachment picture.
    best regards.
    152,373Coins
    +11,076 / 56 / -2
    Do you have sway in Output Testing?
    If so can you post a picture of your f1 2016 Axis Assignments, as the earlier one is the default.
    Can you also please post a picture of the Tuning Center with the game running.
  13. santanadany
    santanadany Member
    Chile
    605Coins
    Dear @noorbeast , f1 2016 Axis Assignments is the same to default.
  14. santanadany
    santanadany Member
    Chile
    605Coins
    152,373Coins
    +11,076 / 56 / -2
    Unfortunately there is too much camera movement on the video for it to be of any use, it needs to be stationary where we can see the movement of the rig and the game screen at the same time.
    As an aside it did seem like the seat itself could flex a fair bit from the frame, which if so means you loose a lot of the fine motion detail.
    You really don't need Yaw allocations in your settings.
  16. santanadany
    santanadany Member
    Chile
    605Coins
    @noorbeast ,
    Okay, I'll see how I can film better.
    I will solve the problem of flexion, I know where I have to reinforce, although the truth I like that it is not totally rigid, it feels very real.
    Okay, I'll remove the Yaw, although the value I gave is very low.
    My problem is still with SWAY, in the PCars it feels great, in F1 almost nothing ... I do not know what I'm doing wrong
  17. santanadany
    santanadany Member
    Chile
    605Coins
  18. noorbeast
    152,373Coins
    +11,076 / 56 / -2
    I am not sure I know what you mean.
    Do you mean you use the same settings for F1 and Pcars 2 and get a different motion result? If so that is because a motion profile needs to be set for each game.
    If you mean something different then you need to explain a bit more.
  19. santanadany
    santanadany Member
    Chile
    605Coins
    I mean, I use your instructions to create the create motion profile in both games
    but different configurations, the UDP Pcars plugin works perfect, and the F1 UDP plugin has a very poor Sway move, can you test it with your simulator?
  20. santanadany
    santanadany Member
    Chile
    605Coins
