Question 6DOF with servomotors for flight sim in VR
Discussion in 'DIY Motion Simulator Projects' started by dureiken, Aug 4, 2017.
  1. dureiken
    dureiken Active Member
    1,248Coins
    the other problem of my rig is that I only have 200cm between ground and top in my room
    I made a design like this but I really don't like :
  2. dureiken
    1,248Coins
    I am going back to wormdrive for now.
    I would like 400mm heave, 120° of motor rotation, 6DOF, 35° pitch/roll
    In term of angle :
    What gives me 450 for platform radius :
    Mobile :
    Fix :
    In a vertical plan (trying 2D before 3D), does the neutral position should be like this :
    Or should I put the axis of fixation at the middle of lever, like this ?
    I think I'm wrong because after having done all of this, I only have 15° of roll :(
    Thanks for your help guys !
    151,528Coins
    +11,042 / 56 / -2
    Others with 6DOF rigs like @SeatTime and @SilentChill are better placed to comment, but I would think 35 degrees excessive.
  4. dureiken
    1,248Coins
    BTW I only have 15° lol
  5. dureiken
    1,248Coins
    Hi
    do this kind of actuator work ? or is there something wrong ? (except there is no screw ball and gear between motor and screw ball !
  6. dureiken
    1,248Coins
    Hi guys,
    is that a problem if my seat is not at the center of rotation ?
    because of problem of room size, I have to put the seat down of 350mm and back of 330mm.
    Will it change the movment perception in bad terms ?
    Or is that a problem for gravity center ?
    Thanks a lot
  7. dureiken
    1,248Coins
    project keeps going !
    30° pitch and roll, 70° yaw
    [​IMG] [​IMG]
    400mm for/back and left/right and 500mm Heave
    [​IMG] [​IMG]
    Do you know where I could find a seat where I can put my warthog joystick between my legs ?
    And where to find gear wheel ? with chain ? would it be able to transmit 750w ?
    thanks
  8. Zed
    USA
    5,844Coins
  9. dureiken
    1,248Coins
    is there a way to have one with an angle ?
    et imprimer des parts :
  10. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,761Coins
    DC motor, Arduino
    at5 belts are more suitable, much less noisy and smooth!
  11. dureiken
    1,248Coins
    I wil go with AT3 or AT5 thanks a lot
    is 0.5m/s and 60°/sec good specs for VR ?
  12. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    500mm/sec it's a lot! (and difficult to achieve)
    Nice actuator design, I have a similar but a little more radical design in mind if my more simplistic design fails this week.
  13. dureiken
    1,248Coins
    thanks
    where is your design ? :)
  14. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    WhatsApp Image 2017-10-07 at 10.30.05 AM.jpeg Dual ball bearing nut in the upper free floating part to keep it center...
  15. dureiken
    1,248Coins
    What is your motor ? and linear spec ?
  16. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
  17. dureiken
    1,248Coins
    Hi guys,
    still not dead, project keep goes up ! @wannabeaflyer reboosts me a lot !
    Under fusion360 :
    Screw lenght : 550mm, total travel : 480mm
    And hardware in real :
    I have a problem : the ball screw nut is in the wrong side compared to machined size, can I remove it and reverse it ?
    What do you think of my design ? @SeatTime @wannabeaflyer @baykah @Hoddem @noorbeast
    Thanks a lot :)
  18. dureiken
    1,248Coins
    not a lot of help round there :(
  19. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    You can unscrew it, but you need a piece of tube of the same size of the screw, or a printed screw.
  20. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
