F1 Cockpit Kit
Discussion in 'Commercial Simulators and Peripherie' started by mrt, Dec 3, 2015.
  1. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
  2. mrt
    mrt Member
    United Kingdom
    719Coins
    3DOF, SCN6
    So I'm back on this project as its been left to one side with other projects . So to aid the aesthetics of the cockpit I had a 3d printed roll hoop made ! This took about three days to print IMAG0885.jpg IMAG0912.jpg
    • Like Like x 6
  3. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    WOW! Very nice. The red part, is it gel coat, top coat or just paint? How do you smooth the PLA? ABS is easier... It looks fantastic!
  4. mrt
    mrt Member
    United Kingdom
    719Coins
    3DOF, SCN6
    The red head surround is an actual headrest although it would be good to have it drawn up for 3d printing.
  5. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    I see. but I wanted to know also what you used to have that smooth look. Thanks!
  6. mrt
    mrt Member
    United Kingdom
    719Coins
    3DOF, SCN6
    So haven't posted in a while. As this project has been on the back burner. But im back on it now
    A few pictures below in no particular order
    View of the seat from the back of the monocoque im currently working on a supportive frame for the seat .Eventually I will add a seatbelt(maybe as far as a seat belt tentioner) and a tactile transducer to the back of the seat. Below a view of the seat from the front of the cockpit.
    The motion frame with some additional pieces the follow the shape of the monocoque. I will cover this with some plywood and maybe some black vinyl eventually. The idea being is that I will secure the monocoque to this platform with bolts.
    Marking up the plywood prior to drilling . Luckly the cockpit has a center mould mark which has made it easier to line up in the center of the platform
    Prior to securing the monocoque to the platform I will do another weight test to determine how for forward/back the monocoque is placed in relation to the actuators and the rear pivot.
  7. mrt
    mrt Member
    United Kingdom
    719Coins
    3DOF, SCN6
    Managed to pick up an ex force india T tray with bardge boards still attached. With a slight bit of modification this would fit. Although they may get in the way of climbing in and out of the cockpit so haven't decided if I will use them . barge boards.png 11.png
  8. dualclick76
    dualclick76 Active Member
    italia
    1Coins
    this is an incredible job, congratulations
