Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    your platform? custom made by you, or new ones from some store? My question is because, in general, if you buy a platform, some configs are custom for it. So, make a copy from 2.0, install 2.1 and drag and drop all configs from 2.1. Should be ok.
    153,866Coins
    +11,153 / 57 / -2
    Please post pictures of all of your settings and details of your hardware on your own thread.
  3. George Dobransky
    Hungary
    - 43Coins
    OK, here are the pics of my setup. It is exactly the same as in ver.2.0.
    It was strange, but after I have installed 2.1 (to other directory than 2.0) all of my 2.0
    setup transferred to 2.1 as well, so I didn't need to copy the values.
    With 2.0 it is still working as well.
    My platform is a custom made, I'm using SMC3 Arduino 3DOF Motor Driver.
    Thank You
    153,866Coins
    +11,153 / 57 / -2
  5. George Dobransky
    Hungary
    - 43Coins
    Noorbeast,
    thanx for advise, I have uninstalled both 2.0 and 2.1. After I have installed 2.1, but the result is the same. It is strange, If I turn on the output testing, one of the motors rolled to about 20% one side,
    it looks like the zero point is different, but only for one motor. If I sliding the slider "roll" left and right it is pulling so hard to the requested position.
    After I reinstalled back with 2.0, without uninstalling 2.1, but to the same directory.
    2.0 is still working well, as I start testing the motor set back to center and working well, softly and good.
    Any other ideas?
    George
    153,866Coins
    +11,153 / 57 / -2
    You have likely messed up the install somewhere, so try unistalling, then to be sure manually remove C:\Users\your_user_name\AppData\Local\SimTools and also the C:\Program Files (x86)\SimTools folders, reboot and do a clean install.
  7. George Dobransky
    Hungary
    - 43Coins
    Noorbeast,
    I have done, nothing changed....In this case, I'm still using 2.0.....
    Regards,
    George
  8. yobuddy
    51,535Coins
    When you uninstall SimTools, are you answering yes to the question "Remove old settings..." ??
    SimTools v1.0 and v2.0 can not be on the same PC is why I ask.
  9. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    The Tuning Center guys ...
    Weaker forces comes from a bigger nembers .
    Check for the force balance too as the game plugin may have a defferent default values other than what yoou need .
  10. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Hello to all. I have a question.
    If I buy a "professional license" of simtools 2.x , do I also get unlimited access to download plugins???
    From what I read, I think no, but many time ago a forum member answered a question by saying the opposite. Unfortunately I can not find the post anymore.
    Can you help me? Thank very much!
    153,866Coins
    +11,153 / 57 / -2
    The Professional License only covers SimTools, not plugins, but you can use activity coins or real money to purchase access to plugins: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
    See here for more information on the revenue sharing relationships between SimTools and the the Xsimulator.net member site: https://www.xsimulator.net/community/faq/simtools-and-xsimulator-partnership-explained.275/
  12. ilbiga
    Network Engineer
    103Coins
    OK thanks. That's what I understood, but as I said, some weeks ago I discussed this with an user who stated the opposite and I had doubts .... among other things, it seems to me that the user in question is no longer present in the forum.
    Thanks again.
    I take the opportunity to ask if anyone has information about the developments in the "game vibe" feature that might be interesting for buying a "professional license".
    Ciao:thumbs
  13. noorbeast
    153,866Coins
    +11,153 / 57 / -2
    Game Vibe is currently in closed Beta testing, this is a recent comment from the dev @yobuddy: https://www.xsimulator.net/community/threads/where-is-vibe.10641/#post-138282
  14. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    Hello
    What is happening ?
    I'm still on a simtools version I downloaded about a year ago
    Everything working fine
    Do I need to update ?
    Is the vibration now included on latest version ??
    153,866Coins
    +11,153 / 57 / -2
    SimTools 1.3 is no longer maintained, nor are its plugins, as the focus is on the development of SimTools 2 and associated modules, one of which is Game Vive, which is currently in closed Beta testing: https://www.xsimulator.net/community/threads/simtools-2-0-question-and-answer.8175/
  16. ilbiga
    Network Engineer
    103Coins
    @noorbeast: thanks for information and the link !!!:cheers
  17. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    Hallo again
    I am having problems with my right SCN5 actuator back again - it seems the ST 2.1 lost the ID, and only right moves. AS I remember I need to change the ID in x-sim converter to make it work?
    In ST 2.1 I have COM 3 and COM4 to choose from. In x-sim converter both SCN5s seem to be connected to COM4
    Any help will be appreciated
    Here I present x-sim converter
    PS - I switched the USBs and in x-sim converter all seemed to get back. I had two SCNs working. I started ST 2.1 and iR and nothing happened. I just felt a tiny movement at the end of session of iR.
    I restarted the computer and all is back to what it used to be which is wrong . x-sim conv finds only one scns. Both IDs are set to ZERO.
    What is funny - when I start x-sim conv only right SCN works. With ST 2.1 the other one starts.
    Any ideas what went wrong?
    PS 1 to make it works I have to replug USBs - then both ST 2.1 and x-sim conv see SCNs
    PS 2 ST does not work with iR. GM GE are connected and patched - a small movement sort of vibe is felt
    PS3 During the session with iR info popped up - that ST stopped working
    PS3 I replugged the USBs and x-sim conv saw both SCNs - the moment I started ST 2.1 it went down to one left. After that when I run x-sim converter only one SCN is visible.
  18. yobuddy
    51,535Coins
    @TPS
    Are both your SCN actuators connected to the same serial adapter?
    Or do you have each SCN connected to its own adapter?
  19. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    Every actuator has its own connector. It used to be good before, as I switched from Lince to ST2.0/2.1. After a long period of time I started ST and it moved only one scn. After I replug usbs it is found by x-sim converter, (see attached files above). but it changes nothing as I start ST 2.1 and only one scn moves
  20. yobuddy
    51,535Coins
    I can't speak for xsim stuff.
    But if it used to work, and now it does not, I would look for hardware problems.
    Loose wires or a faulty USB cable maybe?
    Maybe look at your interfaces settings and make sure both SCN actuators are listed in Game Engine?
    If one looks wrong, remove it. then restart SimTools and re-set it up.
    But it sounds like it could be hardware to me.
