value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. kjjcard
    kjjcard Member Gold Contributor
    south korea
    356Coins
    2DOF, 3DOF, 6DOF
    I bought the site of the model. Https://www.youtube.com/watch?list=...fsyXA_DBBH&v=NKiWUkExirw&ytbChannel=armeniman In this model, ROLL and PITCH are put in 1DOF. But it went well. The problems are Heave, Surge, and Sway. And if you turn around, the motion platform will jump. Hmm... Is it possible to put Heave, Surge, and Sway in 1DOF?
    153,691Coins
    Your option would be to try roll and sway at smaller percentages on Axis1, with sway having the Dir unchecked, and pitch and surge on Axis 2. Heave could be awkward depending on the geometry of the rig and a transducer may be a better option.
    What you really should have is support from the manufacturer. You should also post request for support on Xsimulator.net to the Commercial or Pro threads.
  3. JayceTeng
    JayceTeng New Member
    非政府组织的专业软件测试员
    - 86Coins
    2DOF, DC motor, SCN6, Arduino, Joyrider, Motion platform, 4DOF, 6DOF
    I have a question: whether this game plugin must use simtool2.0 or later? Because i am using simtool1.3, but my simulator can not move.
    153,691Coins
  5. JayceTeng
    非政府组织的专业软件测试员
    - 86Coins
    Hello!
    My simulator doesn't work.I am using NoLimits_V2.0.9.0 _Demo and, add -- telemetry.In Tuning Center, Game Selected is NoLimits 2 but Game data-output has no value, and Virtual Axis has not changed In the Game manager.So this Game plugin can't be used for NoLimits 2-Demo version?Or other problems?
  6. value1
    14,236Coins
    NoLimits does not provide telemetry data in the demo version only in the full version.
  7. JayceTeng
    非政府组织的专业软件测试员
    - 86Coins
    How can I get a demo version game plugin?
  8. JayceTeng
    非政府组织的专业软件测试员
    - 86Coins
    Thank you for your interest.I deleted "-- telemetry", but my simulator still doesn't work, so "NoLimits Rollercoaster Simulation Plugin 2.0.0.4" is a full version of the Plugin and cannot be used for demo version?
    153,691Coins
    There is no plugin for the demo version of NoLimits, as the NoLimts demo does not provide the telemetry like the full version of NoLimts does.
    As @value1 said the plugin only works with the full version of NL, it will not work with the demo version of NL.
    When the plugin is used with the full version of NoLimits the --telemetry flag is required: https://www.xsimulator.net/community/faq/no-limits-2-v2-2-and-higher-how-to-activate-telemetry.198/
  10. MarkusB
    4,215Coins
    One additional note to @noorbeast's advice, @JayceTeng: In all your posts in which you mentioned the telemetry flag, you put a blank between -- and telemetry. This blank needs to be removed. So it has to be
    --telemetry
    and not
    -- telemetry
  11. JayceTeng
    非政府组织的专业软件测试员
    - 86Coins
    This is an important reminder, thank you!
  12. value1
    14,236Coins
    But it will still not work with the demo version!
    The demo version of NoLimits does not output telemetry data!
  13. mimakez
    mimakez Member
    263Coins
    i want to buy a license for simtools 2. Does it work with nolimits 2 last version (2.5.2.0) with simtools 2.0 and the latest plugin for simtools 2.0
  14. value1
    14,236Coins
    Yes, the DIY and PRO version of SimTools V2 does work with the full version of NoLimits.
  15. JayceTeng
    非政府组织的专业软件测试员
    - 86Coins
    Yes,that's what I did. My simulator was working.
  16. mimakez
    mimakez Member
    263Coins
    I am currently using simtools 1.3 and with NL2 version 2.2.3.7 my simulator works without a problem, I try to do update NL2 on the last version to see if it will work. If it does not work then I will buy a license for simtools V2
  17. Giuseppe Romano
    Giuseppe Romano New Member
    362Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino
    Hello to all. Some months ago I've configured on a PC Roller Coaster (steam edition), updated at that release(I don't remember what it was), Simtools 1.3, and SMC3 motion system on a 3 DOF Platform. After some days of tuning all was perfect. Today I've resumed the machine, and I found that Roller Coaster was updated to the Ver. 2.5.3.0. And the motion platform doesn't works anymore. Only uncoordinated movements. Something was probably changed in the comunication to the plugin. Have you some experience with the new version? there is a solution? Thanks
  18. noorbeast
    153,691Coins
    Simtools 1.3 and associated plugins are no longer maintained, best to update to SimTools 2.
  19. Giuseppe Romano
    362Coins
    Ok this is a thing to do, but I was asking if the new version 2.5.3.0 function with simtools 2 and the actual plugin or not...
    And another question, I've some motion platform with related PCs. I've to buy a simtools licence for each PC?
    153,691Coins
    Yes the plugin is maintained for SimTools 2.
    Conditions apply but if your progress your DIY build to the testing phase and maintain your build thread then you would be eligible for a free DIY License, which can support a dual PC install if that is what you plan: https://www.xsimulator.net/community/faq/request-a-free-diy-simtools-2-0-license.262/
    Or you can purchase a Pro License if want extended functionality: https://simtools.us/license/
