Formula 3 simulator :)
Discussion in 'DIY Motion Simulator Projects' started by Gadget999, Sep 26, 2016.
  1. Gadget999
    12,035Coins
    Thank you for the suggestions.
    I am using the ibt-2
    It has a output for the built in protection so i will wire up some leds and see if they get activated :)
    The battery idea is a good one i will wire up 2x12v for safety.
    I decided to try out the new ibt-4 which uses 2x pwm and a ground to trigger it. I am unable to work out if it is powered by the 'motor in' power and will find out when they arrive. I suspect i may not be able to use them because they will not go to 24v
  2. SeatTime
    If you have the spare cash and want to stop experimenting, I and others could recommend the Sabertooth drivers (go the 2 X 60 if the budget allows) - One of them will do both motors and they are actually made for this type of application.
  3. Gadget999
    12,035Coins
    looks like a nice unit - but out of budget for the time being
    i will try the ibt-4 that i have ordered should be ok for 50A
    if this is not up to the job i guess i can try 2 x ibt-2 per motor and get 86 A
    interestingly the motors i have are quite low amps (8A iirc)
  4. Gadget999
    12,035Coins
  5. SeatTime
    It's not the base current that causes the issues, it's the high regenerative voltages/currents produced by the motor when the motor changes direction often and at high speeds. If a driver/power supply is not designed for this - then it will just shut down.
  6. dr.feelgood
    dr.feelgood Member Gold Contributor
    FINLAND
    478Coins
    This is so very true... Even when i have low power motors on my rig, i get shutdowns with unmanned seat while testing rapid move changes with smcutil or so.
    It is nice if you can afford testing new drivers... I'm happy with IBT-2's over MM's, which were just disaster (china copys). Those IBT-3 / IBT-4's over ebay seems a bit suspicious... Hope you get valid stuff !!
  7. Gadget999
    12,035Coins
    it appears one motor is causing the problem and in only one direction - i have leds wired up to the shutdown triggers - i wonder if i have a bad motor, or a bad ibt-2 - could the motor have bad brushes for example
    (the motors are rated at 8a continuous)
    the ibt-4 arrived today but they are not suitable for 24v
    i have ordered another pair of ibt-2 and plan to run them as pairs wired together
    i will feedback how i get on
  8. Gadget999
    12,035Coins
    i added a cooling fan to the ibt-2 motor drivers today
    so far the motors have not shut down :)
  9. Gadget999
    12,035Coins
    i have a bit of twist in the front of the sim when loaded up with a heavy person
    the UV joint is from steering column and is probably not strong enough
    I can either source a UV from a prop shaft, or fit a panhard bar
    do i need 2 bars on each side or one bar on the rear ?
    does anyone have any examples i can look at
    152,577Coins
    +11,087 / 56 / -2
    A single bar diagonally from the base frame to the seat frame will do the job.
  11. Gadget999
    12,035Coins
    thanks @noorbeast - that looks simple enough :)
    will the pan hard bar not cause it to twist right when the nose dips and twist left when it rises ?
    do i need the angle between the left and right ends to be as shallow as possible
    I will get something knocked up asap and try it out
  12. Gadget999
    12,035Coins
  13. Gadget999
    12,035Coins
    Some pics of the panhard bar as requested
    It needs to be flat and level with the pivot axis
    It seems to have done the trick
  14. Zed
    USA
    5,845Coins
    @Gadget999 - looks like you answered your question about Panhard bars actually introducing some twist in the rig while they lock out much more twist. Yup! I had to add them too with a steering U-joint where the mounting didn’t have quite enough resistance to the sim twisting.
    Very nice looking rig!
  15. Gadget999
    12,035Coins
    hope to get the DC DD wheel fitted soon and get it working again, i found an old projector that looks perfect to use on the wall.
  16. ART FLY
    ART FLY Gettin' High on DIY :) Gold Contributor
    Bavarian State Theater, Decoration Stock Manager
    BAVARiA
    421Coins
    That looks so cool to actually be seated in a real race cockpit. Congratulations :popcorn
