DIY FFB Steering wheel (MMosFFB ) (In Progress)
Discussion in 'DIY peripherals' started by Alexey, Dec 10, 2015.
  1. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
  2. Claudemir
    33Coins
    I do not know if this engine is Brazilian! I do not think so!
    I'm having trouble finding the encoder 8000ppr, does anyone have a link so I can buy it?
  3. Gadget999
    12,035Coins
    hi @auryza
    i have decided to make a similar wheel you yours using a 300w unite motor - but i will try direct drive
    is there a thread for your build ? can i see the arduino code ?
    did you use the leonardo because it can be seen as a windows keyboard / gaming device ?
  4. Fernando Igor
    Fernando Igor Member
    Programmer
    Fortaleza, Brazil
    913Coins
    DC motor, Arduino
    Leonardo is used for operating as a joystick / keyboard device.
    I believe this project was finalized, but the creator made available a code from an initial version. I use the final version (FFBWheel.0.16.leonardo.hex), but I am studying and modifying the initial code made available.
    Look for RFR Wheel Ai-Wave, you will find the thread.
  5. auryza
    auryza Active Member
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Plenty of them in Aliexpress.
    Check this, Omron encoder,
    PR means pulse per revolution, multiple by 4, you will get CPR. If you will order encoder with 2000 PPR overall count per revolution will be 8000.
    https://www.aliexpress.com/item/6B2...lgo_pvid=925c2e64-2c2a-4654-a5e0-f3df2aa47058
  6. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    I don't have a thread of my bild, i was using info from Racingfr forum, but at this moment it's closed.
    Leonardo is used for operating as a joystick / keyboard device it's cheap and easy programmable.
    And this is really easy to build, actually all information what you need to know is on this thread.
    Some videos :
  7. Gadget999
    12,035Coins
    wow awesome videos ! is the software he is using the mmos ?
  8. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Actually the same.
  9. Gadget999
    12,035Coins
    So does a pc program control the ffb or does the arduino do it ?
    Can you use as many ppr as you want ?
  10. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Everything the same like in OSW. Arduino controlling the FFB, software is for profiling.
    I don't know how many PPR can handle Arduino, i never have tried more then 2500 PPR, but probably it can handle as much as 10000 PPR.
  11. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    I found that arduino internal timer can handle 65,536 interrupts, and the it starting count back to zero. So that means if you will use max 1080 degrees wheel rotation, u can use 5000 PPR encoder (20000 CPR). I don't know if i'm right. If somebody know better please share.
    http://www.instructables.com/id/Arduino-Timer-Interrupts/
  12. Gadget999
    12,035Coins
    I have a 360 ppr shaft encoder to hand i will start with that and see how it works.
    Does the osw project not use a stm32 processor ?
  13. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Yes, stm32, and this software modified for Arduino Leonardo.
  14. Gadget999
    12,035Coins
    is there no source code for the arduino ?
    I want to compile for an arduino mega 2560
    the original code was for a STm32 board - how did you get the arduino hex file ?
  15. Fernando Igor
    Programmer
    Fortaleza, Brazil
    913Coins
    DC motor, Arduino
    Are two different projects.
    The (initial) sources and some docs are here: http://www.aiwave.fr/downloads/ESP_WHEEL_0.3.zip (this is not the latest version but it will help you if you ever want to jump into FFB development).
    This is the source code I'm studying / modifying, but in some games the FFB does not work, I do not know, but I think it's something related to the USB FFB descriptor.
  16. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    You need to download and open XLoader , the from drop down menu, just choose mega 2560,
    All files you can find here
  17. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Xloader.zip
  18. Gadget999
    12,035Coins
    thank you guys :)
    i tried programming the code for the mega - but it did not seem to work. Does the arduino need to be a leonardo so it can emulate a joystick.
    i will keep trying
  19. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    So it's a bit tricky to program arduino with "xloader", first of all you need to restart arduino into bootloader mode, then arduino generating other com port number, whish you need find and write in to xloader com port , then you have 10 seconds to press flash button to install a hex file, that how this works with leonardo and macro.
    And with mega board probably that method doesn't work.
  20. Gadget999
    12,035Coins
    do you have a compiled version of the rfr program ?
    how does the mmos program find the wheel - is it looking for a windows device or a com port ?
    should i be trying to load the hex file FFBWheel.0.16.leonardo.hex ?
