Ville Pesonen
War Thunder Plugin 2.3.1.1
SimTools V2 plugin for War Thunder
  1. Marcocer
    Marcocer Member Gold Contributor
    France Allier Sussat
    - 262Coins
    its OK ; just windows in English
    thqnks to you
  2. cedric33
    cedric33 New Member
    - 118Coins
    Hello ! I have a simtool V2 from September and I download your plugin yesterday. When I launch the game, my motion plateform move a little in the home screen. I'm tested with the tutorial Combat and Landing and in game my plateform doesn't work. Game Engine and Game Manager are in the administrator mode, patch is ok. I don't understand. Can you help me ?
    153,697Coins
    It sounds like you need to refine your motion settings profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    It would help if you posted pictures of all of your settings and a video showing the movement of the rig and the game screen play at the same time.
  4. cedric33
    cedric33 New Member
    - 118Coins
    Hello ! Can you tell me what you think ? The game is patched, heave, pitch, roll, surge, sway are activated in 20%. Assetto Corsa works perfectly for your information. Game manager and game engine are in administrator mode. Just a very very little move heave to launch the game at home hangar menu. After when i launch the tutorial mode or combat mode any movement. I don't understand ?! I have windows 10 and i use steam. Best regards. Cédric
    153,697Coins
  6. cedric33
    cedric33 New Member
    - 118Coins
    last night i change in the windows 10 parameters region to united states (local) but windows stay in french. I change windows 10 in english for all the application ?
    153,697Coins
    If you click on English (United States) under Languages @cedric33 you should have the option to set it as the default. Then reboot the computer.
  8. cedric33
    cedric33 New Member
    - 118Coins
    Thank you, I will test tonight. Good afternoon !
  9. cedric33
    cedric33 New Member
    - 118Coins
    I'm disappointed, I changed the language in English, restart my computer and it is the same result. Any movement. I installed the plugin joystick for test, followed the procedure and doesn't work either. I dont't understand ?! Just the plugin assetto corsa work ! Thanks for help
  10. yobuddy
    51,518Coins
    @cedric33,
    Try recapturing the Max/Min values for the game.
    In the pic the roll and pitch are way higher than you sim can do for example.
    I bet it will really help buddy,
  11. cedric33
    cedric33 New Member
    - 118Coins
    I understand but the valor are at 0 in game - data output in tuning center when in game started. Any movement vs assetto corsa tuning center. Kind regards
    153,697Coins
    Can you please start your own thread and post pictures of all of your settings on it, as it really is an issue related to your setup rather than the plugin.
  13. cedric33
    cedric33 New Member
    - 118Coins
    Ok you check this pictures, I make a picture of interface setting this afternoon and after tell me please your opinion, this pictures are in game tutorial bombardier. thanks a lot 20171018_214049.jpg 20171018_214106.jpg 20171018_214930.jpg 20171018_214854.jpg 20171018_214809.jpg
    153,697Coins
    Don't use the tutorials @cedric33 use one of the existing planes and use the Test Fly option.
    Do you have a 4DOF motion simulator, which is what your settings suggest? My understanding was that you have a 3DOF SimuKit.
    Does your simulator properly follow these conventions of movement in Output Testing: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    Again as per my earlier post I believe that this is an issue related to your setup or configuration, not the plugin. Hence it belongs in its own thread, so I will ask @Pit to move the relevant posts when he gets a free moment.
  15. cedric33
    cedric33 New Member
    - 118Coins
    Yes i have a simukit 3dof with 4 engine. Sorry, I'm a beginner and I try to find a solution. Where to post my request for technical parameter ?
  16. noorbeast
    153,697Coins
    Best to let @Pit gather up the various posts and make a new thread for them.
    Does your sim move correctly in Output Testing?
    And can you please post a picture of your Interface Settings.
  17. cedric33
    cedric33 New Member
    - 118Coins
    yes my sim move correctly in output testing. As i said the plugin assetto corsa works perfectly for exemple. 20171019_213234.jpg
  18. noorbeast
    153,697Coins
    Your latest picture still shows French is set as the language @cedric33.
    Do you have any firewall running and if so can you please turn it off to check if it is interfering, because if Output Testing works something is getting in the way of the information transfer.
  19. cedric33
    cedric33 New Member
    - 118Coins
    I changed the language in English, turned off the firewall, restarted the computer and it did not change anything. After that i changed into French because assetto corsa plugin works. So I don't understand why this one doesn't work. I have windows 10 there may be something else blocking ?
    153,697Coins
    Leave it set to English Local @cedric33, as different plugins are affected in different ways.
    The War Thunder plugin gets its data via the Dynamic Battlemap, which you can open in a web browser while the game is running at http://127.0.0.1:8111/
    It sounds like something running, or in your settings, is messing with the data flow.
