value1
Codemasters F1 2017 plugin 2.0.0.0
SimTools plugin for Codemasters F1 2017
  1. Djules
    Djules New Member
    - 175Coins
    DC motor, Arduino, 4DOF
    Hello
    it's the same for me
    even with several turns of slow speed capture nothing changes it is the same problem
  2. Leandro Kemp
    Brasil
    - 10Coins
    Thank you.
    So it's some programming error.
  3. Djules
    Djules New Member
    - 175Coins
    Hello
    with the last update of f1 2017 it is good
    No vibration
  4. mirkobastianini
    mirkobastianini Active Member
    informatic
    italy
    1,300Coins
    I use Assetto Corsa plugin with Prosimu T1000 3DOF, and everything works well, this is my setup:
    I'm now testing F1 2017 plugin and I've noticed that there are some parameters going out from game that are inverted in comparison to Assetto Corsa. Is this possible? I mean, i've tested with virtual output and, for example, in Assetto corsa if you turn to right, Sway slider goes to right...with F1 2017, if you turn to right, Sway slider goes to left... it's the same for pitch and for Traction loss (and I suspect for roll). What does it mean? That we should inverted this setting into Axis Assignment?
    153,770Coins
    +11,149 / 57 / -2
    I don't have the game @mirkobastianini so can't check, but by the sounds of it yes you should invert the Dir assignments.
  6. Jordi Rafart Ribera
    Jordi Rafart Ribera New Member Gold Contributor
    Barcelona
    - 24Coins
    I not receive telemetry data from the game.
    What do I have to do in the options menu of telematry by UPD?
    I have tried several things but nothing.
    Thank you.
    153,770Coins
    +11,149 / 57 / -2
    Do you have a 32 or 64 bit version of Windows, as the patch path is different for each with Codemaster games: https://www.xsimulator.net/communit...-32-bit-install-path-for-motion-patching.260/
    Make sure you have done the basics like having run the game for a couple of laps before patching and capturing min and max values in the Tuning Centre when creating and refining a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  8. Jordi Rafart Ribera
    Barcelona
    - 24Coins
    Thanks for answering, I have 64 bit version
  9. RobsonSwiss
    RobsonSwiss Active Member
    Preotria, South Africa
    35Coins
    Hi, the problem is with the plugin/game, if look at the output plot you will see that some outputs are oscillating at high frequency, and this is why the sim is vibrating. Not sure if it's the game or the plugin, I haven't tried it in a while, but had this problem as well.
  10. yobuddy
    51,529Coins
    It was the game and they fixed it buddy.
  11. Martin.Berger
    Martin.Berger Member
    216Coins
    I tested f12017 plugin with my Brand new seatmover.
    Nothing to win. Every slider moves crazy from left to right.
    Axis a and b shake the seat like a Saturn V at lift off.
    Game is up to date.
    SMCutil works fine. Tuningcenter has no effects or shows crazy falues from game
    Anyway ideas.
    Thanks Martin
  12. EvoSergio
    EvoSergio New Member Gold Contributor
    Las Palmas
    78Coins
    Buenas, tengo una Problema a la hora de Modificar el archivo (hardware de hardware conf.xml) de F1 2017
    Para Que funcione el Dash Pro-Race 2, me deja funcionar el simulador de movimiento con (Simtools).
    Como puedo Configurar para que me funcionen Los dos dispositivos a la vez ?, Gracias y un saludo.
  13. noorbeast
    153,770Coins
    +11,149 / 57 / -2
    Google Translation -
    Hi, I have a problem when it comes to modifying the file (hardware hardware conf.xml) of F1 2017 For the Dash Pro-Race 2 to work, let me run the motion simulator with (Simtools). How can I set up to work on both devices at the same time? Thanks and greetings.
  14. EvoSergio
    Las Palmas
    78Coins
    Me disculpo si mi problema no ha sido entendido. Tengo un problema al modificar el archivo (configuración de hardware conf.xml) del juego F1 2017.
    Si lo modifico para ejecutar el Dash Pro-Race 2, dejo de ejecutar el simulador de movimiento con (Simtools).
    ¿Cómo puedo configurar para que ambos dispositivos funcionen al mismo tiempo? Gracias y un saludo.
    153,770Coins
    +11,149 / 57 / -2
    Your problem is undersood, but you are required to include an English translation, as per the forum rules: https://www.xsimulator.net/community/threads/forum-rules.9527/
  16. yobuddy
    51,529Coins
    do you have the instructions for setting up the Dash Pro-Race 2?
  17. Bami Salami
    Bami Salami New Member
    161Coins
    to be continued from my side. Will show setup asap
  18. Jeroen Vrancken
    Jeroen Vrancken ProSIMU T3000 Gold Contributor
    CPA
    Netherlands
    - 65Coins
    3DOF, SCN6
    Can you make an f1 2018 plugin, refer Below:
    hardware_settings_config:
    Code:
    <?xml version="1.0" encoding="UTF-8" ?>
    <hardware_settings_config applyOOTB="false">
    <cpu name="AMD FX(tm)-8350 Eight-Core Processor " processors="8" processorStride="1" processorBinding="1" />
    <graphics_card deviceId="0x1B82" rating="4">
    <resolution width="1920" height="1080" displayMode="1" vsync="false" vsyncInterval="auto">
    <refreshRate numerator="60000" denominator="1000" />
    <windowPosition x="0" y="0" />
    <outputMonitor index="1" />
    <aspectRatio auto="true" width="0" height="0" />
    <hdr mode="0" peakNits="1000" />
    </resolution>
    </graphics_card>
    <motion>
    <dbox enabled="true" />
    <udp enabled="false" broadcast="false" ip="127.0.0.1" port="20777" sendRate="20" format="2018" />
    </motion>
    <antialiasing taa="true" checkerboard="false" />
    <ssao enabled="true" algorithm="3" />
    <ssrt enabled="true" quality="4" />
    <ssrt_shadows enabled="false" />
    <texture_streaming sizeInMiB="1024" texelDensityBias="0.0" concurrentTextureSwaps="1" />
    <led_display fanatecNativeSupport="true" sliProNativeSupport="false" sliProForceBrightness="127" />
    <anisotropic_filter level="16" />
    <lighting quality="2" />
    <postprocess motionBlur="true" godRays="true" depthOfField="true" lensStreak="true" lensFlare="true" bloom="true" />
    <shadows enabled="true" skyShadowMapSize="4096" skyShadowCascadeCount="4" skyShadowLowLod="false" worldShadowMapSize="4096" skyShadowMap32Bits="true" nightShadowMapSize="4096" nightShadowCharacterCast="true" nightShadowSourceCount="4" sampling="3" spotShadowMapSize="2048" spotShadowSampling="3" crowdInShadows="true" />
    <smoke_shadows enabled="true" mapSize="512" opacity="1.0" envOpacity="0.45" updateRate="2" />
    <advanced_smoke_shadows enabled="false" />
    <particles enabled="true" distanceScale="1.0" rate="1.0" high="true" />
    <crowd billboardPercentage="50" lod0Distance="4" lod1Distance="10" lod2Distance="25" lod3Distance="70" billboardDistance="700" finDistance="1000" lod0Quantity="5" lod1Quantity="20" lod2Quantity="50" lod3Quantity="300" billboardQuantity="2800" finQuantity="5000" propQuantity="50" />
    <vehicle_reflections envMapScale="2.0" envMapUpdateMode="alternate" envMapRenderMode="carsAndCharacters" cubeMapEnabled="true" cubeMapScale="2.0" cubeMapUpdateMode="all" />
    <mirrors mirrorsUpdateMode="both" mirrorsRenderMode="carsAndCharacters" treesInMirrors="true" crowdInMirrors="true" highDetailMirrors="true" highDetailTyresAndCar="true" particlesInMirrors="true" />
    <weather_effects rainSplashes="true" rainSheets="true" rainBeads="true" rainHigh="true" trackHeatHaze="true" planarReflectionsEnabled="true" planarReflectionsRTScale="1.0" planarReflectionsMipTailBlur="true" proceduralCloudRTScale="4.0" proceduralCloudTiling="7" proceduralCloudQuality="1" />
    <ground_cover enabled="true" grassFlattening="true" drawDistance="120.0" />
    <dynamic_hair quality="1" />
    <skidmarks enabled="true" parallax="true" />
    <skidmarks_blending enabled="false" />
    <audio radioDeviceId="" audioUpdateRate="1" />
    <async_compute enabled="true" />
    <vendor_shader_pack enabled="true" />
    </hardware_settings_config>
  19. Zeraxx
    Zeraxx Member
    188Coins
    Will this work with 2018? Or do we need to wait?
    153,770Coins
    +11,149 / 57 / -2
    You will likely need to wait.
