SimTools v2 - Video Ride Creator v2.1
Create video ride films for the Video Ride Player
  1. yobuddy
    51,525Coins
    yobuddy submitted a new resource:
    SimTools 2.0 - Video Ride Creator - Create video ride films for the Video Ride Player
  2. yobuddy
    51,525Coins
    This first version deals with:
    • Creating a New Telemetry file for a video.
    • Editing a Telemetry file for a video.
    • Re-formatting an Existing Telemetry file for SimTools.
    1) Create a new telemetry file for a video.
    a) Set the # of data points you want for your new telemetry file.
    b) Set the delimiter you wish to use.
    c) Load a video file and a new telemetry file will be created.
    d) Edit as needed
    e) Press write file when finished.
    The telemetry file is always created in the same folder as the video file.​
    2) Reformat an existing telemetry file for SimTools.
    a) Open the Formatter.
    b) Set the delimiter type for the existing file.
    c) Load the original telemetry file.
    d) Set the DOF output order. (the # above the DOF, is the SimTools Order)
    e) Click ‘All Scale’ to rescale the file to within SimTools standards.
    f) Set the delimiter you wish to use in the new file.
    g) Name the file.
    h) Click “Save Telemetry File”.​
    I will post more as we go along, or people ask questions.
    • Winner Winner x 4
  3. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    Hi yobuddy, first of all congratulations for all the work you did with simtools !!
    This creator video plugin is very interesting and I would like to try to extract the motion data from a video, the problem that even installing the plugin from the available tool, I do not see it in the list to open it.
    I apologize if I was wrong to ask here, if so, tell me where I can write. Thanks in advance
  4. DSSxSIM
    DSSxSIM Member
    Taiwan
    151Coins
    is there any place to share or download other users' file?
    I wanna try the ride player but I wish it comes an easy method, you know.
  5. -kevin-
    128Coins
    I thought it was a plugin, instead it is an exe :grin
  6. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    hello
    I did everything according to the instructions.. simtools game engine . after play video not blue icon....why?
    thanks
  7. yobuddy
    51,525Coins
    @misoswan,
    Did you patch the "game" with game manger buddy?
    (Essentially turning the output on for the Video Ride Player)
  8. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    hello
    I did patch ....
    Essentially turning the output on for the Video Ride Player ...(What do you think?)
    thanks
  9. yobuddy
    51,525Coins
    @misoswan,
    Can I see a screenshot of Game Manger's GUI with the Video ride player running also buddy?
  10. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    hello
    yobuddy ....My mistake forgot plugins lol
    Now it's okay.
    sorry my stolen you time...
    thanks
    Michal
  11. fzxj520
    fzxj520 Active Member
    1,341Coins
    Thank you very much for your tools
    I do not know if the way to create motion data is correct, (click / move / click / move / ...) this way is very inefficient?
    If the black spots can be sucked to the mouse to move the trajectory, (or play the video, real-time cue mouse movement) motion data creation will be very convenient? 2.JPG
    Perhaps the use of key point curve editing method?
  12. yobuddy
    51,525Coins
    @fzxj520 ,
    I agree the current setup is better suited to re-format an existing ride film for SimTools than create them from scratch.
    But you can sort of do what you want when making a telemetry file from scratch.
    Instead of using 30 data points per second, use 2 or 4 when creating the telemetry file.
    Then simply use the 'double points' buttons to add more points once complete.
  13. fzxj520
    1,341Coins
    @ yobuddy
    Thank you very much :)
  14. Leandro Kemp
    Brasil
    - 10Coins
    Is it possible to record the motion data in the video ride creator from the joystick? While the video is in motion by moving the joystick? It would be very practical and easy.
  15. Leandro Kemp
    Brasil
    - 10Coins
    Is it possible to import the telemetry data recorded with the joystick into the .bat extension?
  16. yobuddy
    51,525Coins
    Yes - its possible to record data with the Video Ride Creator.
    But it takes another small app called "VRC Input"
    The idea is with the source example posted "VRC Input", anyone can make any input device they want for Video Ride Creator.
    Weather it be joystick input, mouse input, Nintendo Nunchuk input (seen this one work), any sort of input device can be created and shared to work with the Video Ride Creator.
    It's just not ready for daylight yet is all, Still pondering all the feature it needs.
    We will get there!
    The Video Ride Creator is far from finished guy's.
    The first thing that needs to be added is the ability to sync telemetry files with video!
  17. Leandro Kemp
    Brasil
    - 10Coins
    Is this VRC input the same as for RC model airplanes?
  18. yobuddy
    51,525Coins
    VRC input is just the name I used for the app.
    It stands for Video Ride Creator Input.
    Maybe @eaorobbie could show a bit of his nunchuck test setup.
  19. Leandro Tercette
    Leandro Tercette Member Gold Contributor
    166Coins
    2DOF, 3DOF, DC motor, AC motor, SCN5, SCN6, Motion platform, 4DOF, 6DOF
    Hi.
    I had patched with the app dowloaded, but no selcted game availible on game manager.
    Theres a plug-in to apply if yes, can someone point it
    Regards
  20. yobuddy
    51,525Coins
    EDIT: - sorry, wrong spot.
