value1
City Car Driving Plugin 2.0.8.3
SimTools game plugin for City Car Driving
  1. Maksym
    Maksym New Member
    193Coins
    Can anyone tell me if there is a plugin for City Car Driving that allows to read speedometer and tachometer values from the game?
    152,373Coins
    +11,076 / 56 / -2
    No the current plugin does not have Game Dash support.
  3. Maksym
    Maksym New Member
    193Coins
    :( I am curious if there is any other working solution for that?
    152,373Coins
    +11,076 / 56 / -2
  5. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    Hi guys, I have a problem with CityCarDriving_Plugin, basically I installed it with the tool normally and manually, but I do not see it in the game list.
  6. -kevin-
    128Coins
  7. value1
    15,060Coins
  8. -kevin-
    128Coins
    Thanks for the new plugin @value1
    With the new version 1.5.4 I solved the problems, but I only find these values and normal?
    Question: City car drive plug-ins only work with steam versions?
  9. value1
    15,060Coins
    Yes and yes.
    I couldn't find the acceleration values.
    And you can convert your non-steam key to a Steam key and load it from there.
    (I didn't test the plugin with the non-steam version, but I assume it doesn't work.)
  10. -kevin-
    128Coins
    Ok thanks for the clarification @value1
    It is a pity that there is no acceleration between the values.
    I have another question to ask, if you can kindly also clarify this:
    Are updates to new plugins also included in previous versions, or do you need to download the specific plugin for that particular version?
  11. bakemono
    bakemono New Member
    laos
    152Coins
    there is no sway and surge for this game ?
  12. value1
    15,060Coins
    Nope :(
  13. jesusete007
    jesusete007 New Member
    VAENCIA
    161Coins
    As this game has not "surge" & "sway",,, it's worth it to spent money and buy this game?
    What forces should I assign to his game?
    thanks in advance!
    152,373Coins
    +11,076 / 56 / -2
    You build a motion profile the same as for any game, but the lack of sway and surge means it is pretty poor compared to other games with motion: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  15. jesusete007
    VAENCIA
    161Coins
  16. André Vasconcelos
    André Vasconcelos Member
    Engenharia mec.
    Barretos, Sao Paulo
    61Coins
    2DOF, AC motor, Arduino, SimforceGT
    Hello, how are you
    Can someone help me?
    I tried, several more things here do not move you
    152,373Coins
    +11,076 / 56 / -2
    Are you using the Steam version?
  18. value1
    15,060Coins
    There just was an update on Steam. This might have crashed the plugin :(
  19. André Vasconcelos
    Engenharia mec.
    Barretos, Sao Paulo
    61Coins
    Yes
  20. value1
    15,060Coins
    It actually works here with version 1.5.4.5 (build 13619)
