value1
City Car Driving Plugin 2.0.8.3
SimTools game plugin for City Car Driving
  1. André Vasconcelos
    André Vasconcelos Member
    Engenharia mec.
    Barretos, Sao Paulo
    61Coins
    2DOF, AC motor, Arduino, SimforceGT
    You can see in the capture,
    everything works, but there is no movement
    Yes it's the same version, which I have
    do not understand!
    pcars, assetto corsa, nolimits everything works
    152,373Coins
    +11,076 / 56 / -2
  3. André Vasconcelos
    Engenharia mec.
    Barretos, Sao Paulo
    61Coins
  4. Leandro Kemp
    Brasil
    - 10Coins
    Not worked in my non steam version.
  5. abkglobalresearch
    abkglobalresearch New Member
    Uk
    23Coins
    Hello, I have just updated my city car driving to 1.5.5 but seems its not compatible with the plugin for the 1.5.4.
    Please. when will there be an update for the 1.5.5 version?
    152,373Coins
    +11,076 / 56 / -2
    I am guessing it may be a little while before @value1 gets around to an update, because of the festive season and other updates that will be needed for Game Vibe support.
  7. abkglobalresearch
    Uk
    23Coins
    I just tried un-patching and then re-patching. and that seems to bring it back to life.
  8. value1
    15,054Coins
  9. value1
    15,054Coins
  10. spyderwash
    spyderwash genesy sim
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    I tried plugins but a game engine crash with all the other games I have no problems
    this is error detected
    Problem event name: CLR20r3
    Problem signature 01: SimTools_GameEngine.exe
    Signature problem 02: 0.2.2.5
    Signature problem 03: 5ab1b426
    Signature problem 04: SimTools_GameEngine
    Signature problem 05: 0.2.2.5
    Signature problem 06: 5ab1b426
    Signature problem 07: 445
    Signature problem 08: 0
    Signature problem 09: System.NullReferenceException
    SO version: 6.1.7601.2.1.0.256.1
    Local settings ID: 1040
    Additional information 1: 0a9e
    Further information 2: 0a9e372d3b4ad19135b953a78882e789
    Further information 3: 0a9e
    Further information 4: 0a9e372d3b4ad19135b953a78882e789
    use win 7
  11. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    I have done other tests on a different pc always with win7 and simtools v2.2 and everything works, so the problem is of my pc;)
  12. tony-sim
    tony-sim New Member
    russia
    228Coins
    Hi value1, I just changed my system for simtools 2.2.5 because of new CCD 1.5.6 which provides better support for oculus cv1. On simtools 1.3 and CCD 1.4 the old plugin worked but now the last plugin version is not even picking up data from the game (all zeros). Patched/unpatched several times and tried all four v.2 plugins. I am using a russian non-steam 1.5.6. build 16396. "English location settings" bug isn't relevant. Pcars works perfectly. Maybe you can have some suggestions on how to run these new things ? Thank you in advance.
  13. noorbeast
    152,373Coins
    +11,076 / 56 / -2
    My guess would be that the russian non-steam 1.5.6. build 16396 likely has different pointers than what the plugin was built against, which is the Steam version.
  14. tony-sim
    tony-sim New Member
    russia
    228Coins
    Probably...how to fix it? find new pointer and write new plugin?
    152,373Coins
    +11,076 / 56 / -2
    Correct, it would likely need to be a new plugin for that version, though the reality is it would be easier to just swap and use the Steam version unless you want to create a custom plugin yourself.
  16. tony-sim
    tony-sim New Member
    russia
    228Coins
    Thank you for reply. Steam will be not that easy to get because of some conflicts with original oculus software and steam vr (much resourse usage and lagging). Is it hard to write a plugin for a game? Is there any open samples on previous plugin versions here on forum?
    152,373Coins
    +11,076 / 56 / -2
  18. tony-sim
    tony-sim New Member
    russia
    228Coins
    Thank you for help, switched to Stream version - telemetry started to work. Steam VR is not required for this game, by the way. I run it with oculus original app - no lags. Here is another thing with either simtools game manager or the plugin. Processor load of Game Manager while playing Project Cars is 2-3%. But when it comes to CCD the load rises up to 26-27% and this leads to huge lagging in CCD. Tried to decrease priority of Game Manager - same thing. Processor is i5 7300hq (up to 3.5 ghz), gtx 1060 6gb, 8 gb ram. Tried also with No Limits - no load. What can I do here?
  19. tony-sim
    tony-sim New Member
    russia
    228Coins
    Update: in simtools v 1.3 the old plugin loads CPU even harder - 33%. I guess it is because of memory hook mode. Other plugins in above mentioned games use memory map. Is there any chance to adjust, for example, refresh rate to make it work better? or how this can be fixed?
  20. Youngsoo Cho
    Youngsoo Cho VR Sim Racing Gamer
    Business Man
    Korea
    467Coins
    Can I assign Yaw to axis 3 for 3dof motion rig ?
