Tutorial SPS - Sabertooth Packet Serial PID motor driver sketch w/SoftStart
Discussion in 'SimTools compatible interfaces' started by BlazinH, Nov 10, 2016.
  1. Blame73
    Blame73 Well-Known Member
    8,303Coins
    Did you check the pot? Maybe it got broken/disconnected and didn't reach the limit to make the motor stop so it kept moving
  2. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,261Coins
    The Pot is working fine, I disconnected the motor leads and moved it back around to the normal position with a spare battery.
    I tested the pot while moving it with just the battery and it was responding normally.
    I had some spare fuses so I replaced the fuse and reconnected the motor and it is all running perfectly normal now in SMC3.
    I don't really want to try it again in game until I figure out what went wrong. The motors feel really powerful so I think I need to detune it even more.
  3. Blame73
    8,303Coins
    I know how you feel, it happened to me twice but always because of pots (using jrks)
    I would try lowering the power as much as you could with the stop button in your hand and check if it stops once reached the limits
    Good luck!
  4. Avenga76
    Network Engineer
    3,261Coins
    If I try it in SMC 3 it obeys the limits, The clipping limit kicks in if I try to move the slider past the limit in manual mode, and I tried setting the max limit the same as the clipping limit and it stopped the motors fine when I move the slider past that point. I also tried it with the sliders in SimTools and it stopped the motors fine when it got to the angle that I set it at, that is why I am really puzzled with this problem, because I fully tested all the limits before I tried it in game.
    When I am doing my testing I switch over to a killswitch with a really long 10 foot cable, I call it my roaming killswitch because I just have it in my hand the whole time while testing, just in case I get an oscillation or it goes out of control, but I wasn't fast enough to stop it, it just whipped around and blew the fuse probably about a good second or so before I hit the killswitch. When I have my rig all running perfectly then I have a killswitch next to my wheel and one at the back of the rig.
  5. BlazinH
    16,661Coins
    Today I asked Dimension Engineering for clarification and this was their response.
    "You can use setbaudrate with Syren 50, but only up to 38400. Autobaud does not do anything on a Syren 50. I will add that you can set baud rate 115200 using DEscribe software, then you will be able to run code at 115200. It's just the setbaudrate command that will not work for 115200."
    It appears your SyRen 50 was shipped to you already set at 38400. It was probably a returned unit they resold. Because things like this can happen is why I included jumpers in case someone's Sabertooth is not on the factory default of 9600.
    You will need a USB to UART TTL converter if you want to connect your SyRen to DEscribe in order to set it to 115200. While its fairly simple to connect it does add complexity to making it compatible with the native SMC3-SPS sketch therefore I'm not going to include it as a supported controller.
  6. Avenga76
    Network Engineer
    3,261Coins
    In that case I think I might have set the baud rate myself in some early testing, because I did try sending
    mySerial.begin(9600);
    ST[0].setBaudRate(38400);
    ST[1].setBaudRate(38400);
    mySerial.end();
    To the Syren, so it could have been that which set the baud rate to 38400.
    I will see if I can get a USB to UART TTL converter locally and I will try setting it to 115200
    ***EDIT***
    Would something like this work?
    https://www.jaycar.co.nz/arduino-compatible-usb-to-serial-adaptor-module/p/XC4464
  7. BlazinH
    16,661Coins
    That explains it.
    Yes but you can do a lot better on ebay. This one works great.
    https://www.ebay.com/itm/USB-2-0-to...918816?hash=item28230fa1a0:g:tOAAAOSwx2dYD4KZ
  8. Avenga76
    Network Engineer
    3,261Coins
  9. BlazinH
    16,661Coins
    That's your prerogative. I only showed that link because it said ships worldwide vs. ones that said US shipping only that I could get in a few days.
  10. Avenga76
    Network Engineer
    3,261Coins
    Thanks for the link. Living in New Zealand really sucks for shipping so if it is for little bits like that then it is easier buying it locally instead of waiting for ages. I'm just popping down to the electronics store now so I will give it a try tonight
  11. Avenga76
    Network Engineer
    3,261Coins
    Awesome!!! It worked.
    I went down and got the serial to USB converter.
    Wired it all up and connected to 38400 with DEScribe then changed the baud rate in packet serial section to 115200, then restarted the SyRen to make sure I could connect on 115200 using DEScribe.
    Then I connected the Arduino back up to the SyRen and uploaded the standard sketch and it is working perfectly running at 115200. I don't get the arduino comms error anymore either. So it is working exactly like my Sabertooth.
    Normally you would connect to 9600 in the first instance but I had changed it to 38400 using the "ST[0].setBaudRate(38400);" command.
    So anyone reading this in the future. All you need to do to get a SyRen working is buy a serial to USB converter, connect to the SyRen on 9600 using DEScribe, then go to the packet serial section and change the baud rate to 115200
    Thanks heaps for your help getting this going @BlazinH
    The SyRen makes a good controller for rear traction loss if you are doing 3DoF, use a sabertooth for the seat mover and a SyRen for the traction loss.
    This is the serial to USB converter I used, it was $19NZD ($13USD) from Jaycar using my trade card, but as @BlazinH linked above, you can get them heaps cheaper on eBay
  12. MyTPioneer
    MyTPioneer New Member Gold Contributor
    Database Developer
    301Coins
    I can't seem to get the motor to turn ON. If I click any of the Motor buttons, they flash ON, and then instantly go back to OFF as shown in the picture below. Any help would be greatly appreciated.
    I have set things up according to the instructions at the beginning of this post. I'm using an UNO and a Sabertooth 2x32. I've set the baud on the 2x32 to 115200 and also set the serial timeout to 100ms using DEScribe. I've set the DIP switches as 1-2 OFF, 3-6 ON. The UNO is on COM 3 and the sketch has been uploaded. I set COMM=3 in the config file for SMC3. I've wired everything up according to the drawing.
    Any thoughts on what I'm missing?
    Thanks for any suggestions.
    MyTPioneer
  13. insanegr
    insanegr !N$@n€
    Athens
    16,721Coins
    @MyTPioneer green line is your potentiometer and must be between the red lines Max limits. its a safety feature in SMC3
  14. MyTPioneer
    Database Developer
    301Coins
    Thank you @insanegr
    I manually twisted the motor to get the POT back within the limits and was then able to turn the motor on! Unfortunately it ran the POT right back over the limit and shut off again, so I guess I need to figure out what I need to adjust to prevent that from happening, but at least I have some movement now. Thank you, thank you.
  15. MyTPioneer
    Database Developer
    301Coins
    Ah, I see the answer listed in the initial instructions.
  16. MyTPioneer
    Database Developer
    301Coins
    For some reason, I thought I had read where using this setup would work with a 3DOF rig, but now it looks like I was incorrect. Can someone please confirm this for me? If that is, in fact, the case, I'll start a new build thread for recommendations on setting up a 3DOF with an arduino and a couple Sabertooth 2x32s?
    Thanks again to All
  17. BlazinH
    16,661Coins
    Just use two arduino, one for each sabertooth, then set up Simtools with two interfaces.
  18. Avenga76
    Network Engineer
    3,261Coins
    Yes. That is correct. I am using this to control my 3 DoF with 2 Arduino’s and 1 sabertooth and 1 syren
    You could also do it with 2 Arduino’s and 2 Sabertooth then you would have a spare channel if you wanted to use it later for a forth DoF
  19. Blame73
    8,303Coins
    Hey guys, I got my Sabertooth 2x32 and I'm finishing wiring it.
    One (maybe stupid) question: when I connect the 2x32 to a motor, do I have to connect M1A to the + of the motor and M1B to the - or do I have to use the B- for the negative?
  20. MyTPioneer
    Database Developer
    301Coins
    @Blame73 See below...The B+ and B- are for your power supply coming in, and the M1A and M1B would connect to your motor 1 while M2A and M2B would connect to motor 2.
