Showroom 2DOF by Seth2Christ
Discussion in 'DIY Motion Simulator Projects' started by Seth2Christ, May 12, 2015.
  1. Seth2Christ
    Seth2Christ Member
    216Coins
    YES!
    I get my free licence!!!! Thank you :)
    Ok, now have to set all the parameters ...
  2. Seth2Christ
    Seth2Christ Member
    216Coins
    PROBLEM
    All in Output Testing working.
    (last version of simtools, new plugin,...)
    Start playing and 2 minutes after simtools crash.
    Windows message "Game Manager has stopped working"
    Problem with all my games.
  3. Seth2Christ
    Seth2Christ Member
    216Coins
    Ok, I just found a similar problem in another discussion. I think it's a COM port problem. My steering wheel and arduino are both on the front USB port.
    I will try again tomorrow...
  4. Wanegain
    Wanegain Active Member
    Bruxelles
    2,006Coins
    This can be a conflict effectively. It's interesting to know the source of the problem
  5. Seth2Christ
    Seth2Christ Member
    216Coins
    No, it still does not work.
    Even with only the simu plug, the game manager crash after 2 min. And then the game engine stops responding and stops working ...
    152,373Coins
    +11,076 / 56 / -2
    Is there any other error message information? If so please post that.
  7. Seth2Christ
    Seth2Christ Member
    216Coins
    Here are the examples of windows messages:
  8. Seth2Christ
    Seth2Christ Member
    216Coins
    Hello ! Life goes on and I'm starting to have time to resume some activities :rolleyes:
    I took my simutor out of the boxes to reassemble it!
    I simplified it a bit, I just hope it will work again :)
  9. Seth2Christ
    Seth2Christ Member
    216Coins
    I just have a question, how can I find my Simtools license?
    152,373Coins
    +11,076 / 56 / -2
    You can look up your SimTools license number, just log into SimTools.us: https://simtools.us/member-login/
    Use the email you purchased/obtained the License with, and if you don't have a password, click reset password.
  11. Seth2Christ
    Seth2Christ Member
    216Coins
    Great ! thank you ! :thumbs
  12. herve069
    herve069 Simracer
    workshop instructor
    - 16Coins
    Hi!
    What is the Simukit kit you use? 2dof 120W?
  13. Seth2Christ
    Seth2Christ Member
    216Coins
    It's a 2 DOF but not exactly a simukit as currently sold. in 2014/2015, when I built my simulator, I used wiper motors (Smolka 24V), arduino UNO and sabertooth 2x25. The rest is quite similar to the SimuKit.
  14. Seth2Christ
    Seth2Christ Member
    216Coins
    I had an "platform move" version at the beginning, then I switched to a "seatmover" version.
    My specifications have always been the practicality of storing / moving the structure, therefore quite compact. Here the goal was to have the steering wheel support, the pedal support and the gear lever support, on two main aluminum profiles, so that they can be adjusted independently.
    The other point is to maintain the center of gravity of the seat under the "gimbal" but to be able to adjust the seat as in a car. So I placed the entire seatmover on a car seat rails.
    The whole structure is on wheels.
  15. Seth2Christ
    Seth2Christ Member
    216Coins
    I reassembled my simulator but it seems that I have "electrical interference" with my fanatec steering wheel... Looks like problems with electric grounded... ?
    Has anyone ever had this type of problem with a fanatec steering wheel? I'll recheck the assembly, there may be another problem elsewhere. Last time, 4 years ago everything worked ^^
  16. Gadget999
    12,035Coins
    Is there a controller box for the fanatec ? Move it as far as possible from the pc
  17. Seth2Christ
    Seth2Christ Member
    216Coins
    no controller box. thanks for reply.
    I'm going to check everything this afternoon
  18. Seth2Christ
    Seth2Christ Member
    216Coins
    I took everything apart and plugged it back in. And I have no more problems... I can't explain it...
    Anyway, it works!
