Cousin of OSW (Open Sim Wheel)
Discussion in 'DIY Motion Simulator Projects' started by Gadget999, Sep 23, 2017.
  1. Seth2Christ
    Seth2Christ Member
    216Coins
    In one of the youtube video we can see how fast motor spins back. It looks good.
    Just a question, how does the steering wheel stop at 900 °?
    There is a mechanical stop or just the engine stops the steering wheel?
  2. Gadget999
    12,035Coins
    There is no mechanical stop, the motor is resisting movement
  3. danove_b
    danove_b Active Member
    Sweden
    1,782Coins
    Hi! I'm very interested of how your simplified direct drive wheel works in more detail. I have had the same plans (using a brushed DC motor just for the simplicity) for a while now and search the internet and found this thread. I currently using a G27 which isn't too bad, but using it together with rfactor2 makes you crazy with the rattle sound from the gearing. So my question is, compared to a G27 (if you have tried one or another consumer wheel) how is the detail from loosing the back etc. And also the strength, In your video, it doesn't look that strong at all.
  4. Gadget999
    12,035Coins
    in the video it was running off a 12v 7 amp power supply
    it now runs on a 77 amp 12v power supply
    i have G25 wheel and its rubbish compared to this wheel
    the downside of this project is its quite technical to get it working and there is not much support available on the wheelconfig program
  5. danove_b
    Sweden
    1,782Coins
    I would much appreciate if you could post some video showing the strength/response. Driving over some curbs, some drifting etc. Do you know if this arduino solution is comparable with the MMOs solution? I have a leornado allready, but it seems that the most DIY projects are using the MMOs.
    Thanks for your respond
  6. Gadget999
    12,035Coins
    Some more video with the test driver below.
    I have drilled the front cover to let some heat out - you can now hear the motor vibrating with the pwm frequency.
    I will try a different frequency to see if i can get the noise to dissapear
  7. danove_b
    Sweden
    1,782Coins
    Thank you very much for that! I have study brushed DC motors during the day, and what I can understand, the power is constant regardless of the rpm, so lower speed equals higher torque. So the 250w version of this motor actually should give you about 8 Nm at 300 RPM. But I realize now that the heating could be a problem. My plan is to use 24VDC/30A to take full advantage of the power of the 250w engine. How did you fit the rotary encoder to the motor axle?
  8. Gadget999
    12,035Coins
    I am using a 350w motor - if i was to build a new wheel i would use a 450/500w motor and make it work at half power
    to fit the shaft encoder what i did was open the motor and remove the armature - then remove the rear cover and drill out the centre with a drill, i then bonded a metal cap to the end of the armature and reassembled the motor.
    a small stub axle now pokes out the back of the motor. A rubber pipe connects the shaft encoder and the stub axle.
    as a test i reduced the ffb effect in the LFS game to 50% - the wheel seemed to give even better feedback and was still powerful when a bumped a kerb or crashed the car - not what i was expecting !
    raising the PWM frequency to 20khz means you can no longer hear the high pitched noise :)
    I also tried the wheel with a true 3 phase omron shaft encoder but it did not seem to allow the wheel to go into FFB mode, refitting the 2 phase encoder resulted in everything working again
    • Informative Informative x 3
  9. danove_b
    Sweden
    1,782Coins
    http://www.slo-racing.com/forums/topic/2769-wheelcheck/
    Should be interesting to see the results with your wheel
  10. danove_b
    Sweden
    1,782Coins
    If I have understand it correct, the third phase of the encoder is just a index indication for zero position. So when ju turn on the controller, just must turn the wheel with your hands until the index signal are detected, than it should startup normally.
  11. Gadget999
    12,035Coins
    Attached are some pics of an old winch motor i had lying about.
    This motor is 12v and well over 1kw !
    It is a bit stiff to turn the axle by hand, it was removed because it was worn out.
    It could be used as the basis of a DD wheel
    However i am slightly concerned it could rip someones thumbs off !
  12. SeatTime
    Don't be concerned, most direct drive wheels are capable of breaking thumbs and dislocating wrists:).
  13. danove_b
    Sweden
    1,782Coins
  14. Gadget999
    12,035Coins
  15. danove_b
    Sweden
    1,782Coins
    I think the biggest problem with any kind of gearing is that you get some clearance and with that more or less rattling sound when your sim tries to emulate vibration. I have an G27 today, and when you lock your brakes in rfactor2 and get a flatspot you can't stand the sound from it. Now that I have already decided to go with the brushed motor, it isn't that important, but it had been interesting to see the results on your wheel with the Wheelcheck software.
    https://www.xsimulator.net/community/attachments/wheelcheck_1_72-zip.43921/
  16. SeatTime
  17. Gadget999
    12,035Coins
    basically what we have built is a servo motor using a shaft encoder and a motor driver
    the options are
    1. build a osw
    2. buy a decent ffb wheel
    3. build a osw clone using a stepper motor (not sure a stepper motor is suitable for a ffb wheel)
    4. build a osw clone using a dc motor
    as long as we have enough resolution in the shaft encoder and the pwm output channel of the arduino we should be able to get good fidelity of FFB
    however - i have not tried a OSW so i can't compare, hope to try one out back to back at some stage :)
  18. SeatTime
    Not hating on your project but, don't agree. There is more to it then just the shaft encoder resolution and simple PWM out of an arduino. People don't spend good money on specialised software/controller/drivers and Expensive Midge servo motors for nothing. If you ever get the chance to try a proper DD wheel, it will be obvious. If I thought I could get away with using a standard DC motor and controller/driver for a DIY DD wheel then believe me I would have and saved myself allot of money.
  19. wimpo`
    wimpo` Member
    metselaar
    nederland, twente, vroomshoop
    178Coins
    But what are the big differences then? Not that I am denying that for broad industry purposes a servo controller and servo motor are a safe bet. But for something with a specific purpose such as a dd wheel I think with the right encoder and right motor you can take that what makes the servo so great and duplicate that. All the other things that makes a off the shelf servo great are maybe not that important in a dd wheel. But if it is than maybe that can be duplicated to is what I think.
  20. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    As soon as you add positional feedback to a motor it becomes a servomotor. the servomotors that you buy off the shelf are just packaged better.
    1KW vs 450W/ ~$2500 $300 is the difference.
    Apart from that the AC servo motor is better at positional control which is irrelevant in terms of FFB wheels. No brushes to replace, not as high currents to worry about. For the amount of shaft power an AC servo motor is cheaper and easier. Although directional changes are faster in an AC servo motor that advantage is negated due to the RPM of a DD FFB wheel being almost 0 (DC servo has higher inertia at higher RPM).
    The ARGON drive that controls the MIGE motor can actually control DC motors as well as AC and BLDC.
    I'm sure if you spent $600 on a DC motor and $800 on a motor driver I'm more than positive that you'll end up with a great DD wheel.
    The bigger question will be how does the DC DD wheel feel in comparison with its price comparison i.e a G920/29 or a CSW/CSL Fanatec.
