Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. Guilherme Bastian
    Guilherme Bastian New Member
    Brazil
    151Coins
  2. Tummie555
    Tummie555 New Member
    - 27Coins
    If the virtual axis output shows inverted output for sway, is the problem in the plugin or my setup? From what I read in the manual: a turn to right should swing the virtual sway axis to the left.
    It goes to the right it seems, maybe I should test again to make sure because it was really late last night, but I'm pretty it sure about what I saw.
  3. hyper1966
    hyper1966 Domenic
    Edmonton QLD Australia
    833Coins
    2DOF, JRK
    If its wrong Direction JUST go into Sim tools game Engine ,Change direction in sway DIR look at Pic, I hope this helps Domenic
    151,979Coins
    +11,061 / 56 / -2
    These are the default SimTools expected movement directions: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
  5. Tummie555
    - 27Coins
    Okay perfect, sway goes same direction as the turn, thx
  6. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    Hey guys, revisiting Dirt Rally again, All is working good with exception when I put it all together...
    Motion now works great, Sim Vibe Works great, just not together.
    Anyone figured out how to get them working both at the same time?
    151,979Coins
    +11,061 / 56 / -2
  8. Brett Horton
    Tampa FL
    118Coins
    So... after playing with a bunch of settings, I finally got Dirt Rally working with Sim Tools, Sim Commander (SimVibe) and all my Fanatec gear as well as my DSD box.
    I edited the "hardware_settings_config.xml" by adding the line under the "dbox" line to define multiply ports so the telem data would go where it is supposed to go...
    <motion_platform>
    <dbox enabled="false" />
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="10001" delay="1" />
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="4123" delay="1" />
    <fanatec enabled="true" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
    </motion_platform>
  9. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Can you please confirm if the dirt rally plugin works with the version of oculus home?
    Thank
    151,979Coins
    +11,061 / 56 / -2
    I believe the plugin is tested against the Steam version, as that caters to PC, Rift and Vive users.
    If the Oculus Home version is identical then the plugin should work. But if it is altered in any way then the plugin may not work.
    If you or someone else has Dirty Rally on Oculus Home then the best thing to do is try it and report back.
  11. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Thank @noorbeast
    It is a customer who has the problem. I'm going to make sure and I'll comment on it here.
    Meanwhile if anyone has tried it, please tell me if it works for them.
    Thank.
  12. Scor3pion
    Scor3pion New Member
    Munich
    159Coins
    Thank you for the updated info.
    DiRT Rally is my favorite game, so I'm happy it's supported so nicely :)
  13. cedric33
    cedric33 New Member
    - 118Coins
    hello, heave, surge and sway doesn't works normaly. I read lots of reply but i don't understand why change ? thanks for help
    151,979Coins
    +11,061 / 56 / -2
    You have not given much detail but just so you know the plugin patch path is different depending on Windows being 32 or 64bit: https://www.xsimulator.net/communit...-32-bit-install-path-for-motion-patching.260/
    Can you please verify which you have and if it is patched correctly.
  15. cedric33
    cedric33 New Member
    - 118Coins
    I have a 64bit and the plugin patch it's ok. I drive in the full screen mode. If all the dof are "on" the movements are crazy. If i turn "off" heave sway and surge it's ok, pitch and roll works perfectly ! I have seen that other members have the same problem.
  16. stevemontuno
    stevemontuno Active Member
    1,461Coins
    Try using the "Boundary" filter.
  17. Massimiliano Soresini
    Massimiliano Soresini SoNiVR - The Land of Hyper Reality Gold Contributor
    Virtual Reality Arenas & Simulators Entrepreneur
    Italia
    251Coins
    Dear @value1
    Just to check if the Dirt Rally plugin works fine also with the Oculus VR version of the game that I want to buy on steam for my oculus cv1 ?
    thanks so much.
    All the best, Max
  18. Brett Horton
    Tampa FL
    118Coins
    Yes it does, but if you ever add additional programs, like SimVibe, it becomes problematic launching to Oculus home trough sim commander.
    I use the Steam version which IMO just works better and is more flexible.
  19. Massimiliano Soresini
    Italia
    251Coins
    Ciao Brett,
    thanks so much.
    So if I well understand, it's better that I don't install oculus home but I've to use SteamVR! is it ?
    Thanks again, Max
  20. Brett Horton
    Tampa FL
    118Coins
    No, I still use Oculus home mainly for ASW, but launch the game from steam.
    Correct me if I am wrong here guys, Oculus, at least on my machine runs (or launches) EVERY-TIME I am using the Rift.
    I can launch a game through steam, but as soon as I put the headset on, Oculus Home runs.
    Steam just allows a much more flexible environment IMO than Oculus home for odd arrangements (multiple programs utilizing the data from the game, and launch options / control)
