Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. Massimiliano Soresini
    Massimiliano Soresini SoNiVR - The Land of Hyper Reality Gold Contributor
    Virtual Reality Arenas & Simulators Entrepreneur
    Italia
    251Coins
    Perfect Brett.
    I was wrong, when I wrote "install" I was thinking "run"
    Thanks again. All the best.
    Max.
    153,986Coins
    +11,162 / 57 / -2
    Just so you know SteamVR hands off to the Oculus runtime even though a game is launched from Steam, so you still have ATW and ASW.
    A good way to determine where to buy games from is to ask which store offers the best value and has the functionality you need, and the latter includes checking if a plugin has or has not been tested against the Oculus Store version, as most plugins are tested against the Steam version. If a game is unaltered in any way then the motion plugin will work with both stores. But if the game is altered for a particular store then the motion plugin may not work.
  3. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    Thanks Noorbeast for confirming when running steam it does "hand off" the duty to Oculus Home. I figured...
  4. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Ciao @Massimiliano Soresini, se il dubbio riguarda il funzionamento del plug-in con la versione "Steam" di Dirt Rally, ti confermo anch'io che funziona. Io utilizzo quella! Ciao! ;)
    Hi @Massimiliano Soresini, if the question concerns the operation of the plug-in with the "Steam" version of Dirt Rally, I also tell you it works. I use that one! Ciao! ;)
  5. Massimiliano Soresini
    Italia
    251Coins
    Ciao @yobuddy and @value1 and ciao to Everybody,
    I finally bought Dirt Rally from Steam and also from Oculus store to be sure I got the system working at least on one of those platforms with Simtools !
    The DirtRally plugin if perfectly installed and Simtools PRO license is correctry working.
    Now I've to patch GameManager but when the GameManager ask for the directory of the Dirt Rally and I choose one from Oculus or Steam (I've tried many many times) I still have the message:
    "Selected Path is not valid for patching"
    The Oculus Dirt Rally Folder (where there is the exe file) is C:\Program Files\Oculus\Software\Software\codemasters-dirt-rally\World\application
    The Steam Dirt Rally Folder (where there is the exe file) is D:\STEAM\steamapps\common\DiRT Rally
    Can you please give me a suggestion ?
    Thanks so much. Max
  6. Massimiliano Soresini
    Italia
    251Coins
    @yobuddy and @value1,
    forget my previous message. I got finally the patching for DirtRally in GameManager.
    Now I've everything working but when I play with the game using the virtual axis (I'm making some offline test before connect the hardware of my simulator) I don't get the values of pitch, roll and yaw as you can see also from the tuning center picture I've attached.
    You can find all the configuration I did.
    With LFS I get all the correct values. I seems that the Dirt Rally PlugIn don't get correctly the values from the game.
    Can You please help me buddys :sos ?
    Thanks so much. !
  7. yobuddy
    51,563Coins
  8. evolaco
    evolaco Member
    Spain
    694Coins
    Hello, I can not make the motion work with dirt rally, when the car is stopped, the engines do not stop moving, when brake or turn do not move anything, do you have to modify some file of the game so that it works well?
  9. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Delete C:\Users\User\Documents\My Games\DiRT Rally\hardwaresettings\cfg.BAK.
    Unpatch the game.
    Run DiRT Rally once.
    Stop the game.
    Patch it.
    Restart the game.
  10. evolaco
    evolaco Member
    Spain
    694Coins
    I have tried and still does not go well, only the heaven works, it arises and sway do not move anything or to 0.1 in tuning center, on page 22 I have seen a plugin but it does not recognize me simtools, I drag it but it does not do anything
    I also have the problem that it moves when it is loading the race and until you do not make the exit it continues to move, once you leave it does not move any more, if you do capture with the tuning center sway and it comes out to 0, I have been a long time with the motion finished and I have not gotten it to run dirt rally ..
  11. Macfly123
    Macfly123 New Member
    Berlin
    6Coins
    The official plugin does not work for me (Problem with Heave, Surge and Sway).
    Do you already know why it generally does not work for some?
    I now use the plugin from page 22. What is the difference between this and the "official" plugin.
    Thanks for your comments.
    Merry Christmas for all.
  12. llluis
    Quebec
    1,632Coins
    @SilentChill, could you please indicate what this plug-in does differently from the original one?
    (codewise, I mean)
  13. Leo Burton
    Leo Burton Active Member
    London, UK
    2,639Coins
    So, I'm a little confused as to where I should buy this game from.
    - Oculus Home is selling for £18.99,
    -Steam for £40.
    Can this plugin be used/patched while game is running from Oculus Home?
    153,986Coins
    +11,162 / 57 / -2
    Dirt Rally regularly comes up on Steam or there are others who also sell Steam keys for much cheaper than that, it was US $9.99 a couple of months ago: https://www.xsimulator.net/communit...fers-steam-sales-etc.6143/page-18#post-142711
    Personally I have found Steam to have the better sale price bargains, established cross HMD multiplayer and is the most common platform SimTools plugins are often tested against.
  15. Leo Burton
    London, UK
    2,639Coins
  16. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    332Coins
    I can't seem to patch Dirt Rally with simtools manager
    - i have run the game once
    - completed a single race
    - pointed game manager to the my docements\myGames\Dirt Rally folder
    (C:\Users\Your_User_Name\Documents\My Games\DiRT Rally)
    It's not patching
    There's no save game in that folder ( never was)
    Tried the F:\Steam\userdata\26117516\310560\remote folder, which is the only folder than contains a dirt rally save game, but still a no go.
    I'm on windows 10 x64 and simtools 2
  17. llluis
    Quebec
    1,632Coins
    Search your computer for the file hardware_settings_config.xml
    Can you find it?
  18. HoiHman
    Mechanic
    The Netherlands
    332Coins
    Yes it's in there in the (C:\Users\Your_User_Name\Documents\My Games\DiRT Rally) folder. But simtools is not patching, will try a complete reïnstall from both simtools and Dirt Rally and will report back.
  19. HoiHman
    Mechanic
    The Netherlands
    332Coins
    Deleting the entire Dirt Rally folder in the Document\My Games folder, followed by restarting the game solved the problem
  20. satbranigan
    satbranigan Member
    spain
    - 180Coins
    Hi, how did you make it work?
    I bought dirt rally in the oculus store, I have patched the game in the following folder C: \ Users \ user \ Documents \ My games \ Dirt Rally VR and I have the following message "patch installed" but simtools does not work
    Can anybody help me
