Tutorial GameVibe Manual
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Dec 25, 2017.
  1. Bacon2002
    Bacon2002 Member
    Underwriter
    27Coins
    SCN6, Motion platform
  2. yobuddy
    51,530Coins
    Good job David!
    Its just older dx assemblies that wont get called unless something needs it.
    I can't see it hurting anything, but I can see it fixing a few things!
    Its funny to me that windows says "you don't need this" but you install it anyway and it fixes the problem. lol
    good old windows hehe
  3. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    thank you again... im wating for this LONG LONG TIME AGO... AND FAR FAR AWAY... IN A DISTANT GALAXY.. ops rs...
    by the way.. im using simvibe, but its a very limited and EXPENSIVE software !
  4. llluis
    Quebec
    1,632Coins
    Just to clarify this a bit more: you have to select the card above the right one.
    In my setup below, the card for the Vibe is Speakers Realtek High Definition Audio, but to make it work, I have to select S/PDIF Passthrough Device.
    edit: this is fixed in the lastest version.
    One more note: caution when testing the MIN and MAX. The square wave on the Buttkicker will be LOUD. :)
  5. llluis
    Quebec
    1,632Coins
    In the current Beta version, this was renamed to Vibe Creator, instead of Vibe Settings.
  6. paulopsx2
    brasil
    647Coins
    but spdif in your case... using a xonar. Here.. i put realtek and usb pnp ( im using2 sound cards with 4 auras in each )
  7. llluis
    Quebec
    1,632Coins
    It's a list index issue within the code of GameVibe, so the actual name will always change in one's setup but the important thing is: you must select the item just above the right one in the list. In my case it was the SPDIF of my Xonar.
  8. llluis
    Quebec
    1,632Coins
    @yobuddy, even with the provided LFS plugin, I'm not seeing the effects in GameVibe.
    Any hint?
  9. yobuddy
    51,530Coins
    @llluis,
    Did you turn it on in Game Manger buddy?
  10. llluis
    Quebec
    1,632Coins
    Yup
  11. riton
    riton Active Member
    1,006Coins
    I have the same problem.
    I'm on Assetto corsa, maybe it still does not work for Assetto?
    I saw another problem, I have a bug?when I change the IP, or I open the IP tab, then I can do nothing.
    153,818Coins
    +11,150 / 57 / -2
    At the moment Game Vibe will work with LFS, other plugins will need to be updated to support it.
  13. llluis
    Quebec
    1,632Coins
    This is happening with me too. I believe GameVibe is not communicating with GameManager for some unknown reason.
    Maybe @yobuddy should include the green box in the top corner of GameVibe too.
    edit: this is fixed in the latest version.
  14. Anubis9
    Anubis9 New Member
    Moldova
    100Coins
  15. llluis
    Quebec
    1,632Coins
    No, only LFS now. GameDash is not the same as GameVibe.
  16. Anubis9
    Anubis9 New Member
    Moldova
    100Coins
    Yeah, but it says that it has basic Vibe support.
  17. llluis
    Quebec
    1,632Coins
    Cool, interesting to know.
    But let's focus on LFS for now which is the only one confirmed to be 100% implemented at this time. ;-)
  18. yobuddy
    51,530Coins
    Hi Guy's, I think what may be happening with some, is that LFS does not output telemetry when not In first person view mode.
    So when you first hit the track, press 'V' on your keyboard to change the view to inside the car.
    This will update GameVibe with the effects LFS has to offer.
    Let me know how it goes guy's
  19. yobuddy
    51,530Coins
    It should popup as IP Settings Box.
  20. paulopsx2
    brasil
    647Coins
    its possible to put a basic plugin for some generic games? like a CARS... TRAINS... SPACES.. etc? so, we can just change some parameters?
