Tutorial GameVibe Manual
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Dec 25, 2017.
  1. llluis
    Quebec
    1,631Coins
    The popup shows ok. But if I click Save, it freezes completely and I have to close the program. If I change the IP the change is not saved.
    edit: this is fixed in the latest version.
  2. yobuddy
    51,238Coins
    Bug Confirmed.
    I will take a look at this and the wrong sound card selected bug after i get some more info posted to make setup easier.
  3. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    this is ONLY for LFS right?
    152,676Coins
    +11,089 / 56 / -2
    Other plugins will be supported, they just need to be updated to take advantage of Game Vibe.
  5. paulopsx2
    brasil
    647Coins
    you have access to simvibe soft? its interesting ( and detail ) program.. the problem is only 4, 5 games suport, and heavy interface... i think.
  6. yobuddy
    51,238Coins
  7. riton
    riton Active Member
    1,006Coins
    I have to wait for the update of the plugin Assetto Corsa, we can hope to have the days to come?
  8. llluis
    Quebec
    1,631Coins
    This was not the cause, however I can't pinpoint what was it.
    Indeed GameManager was not receiving any data at all from LFS. I did a complete re-install, recreated profiles et al and now it's working!
    It's worth noting (for the newbies like me) that the names in GameVibe will appear only with the game running. If you open only GameVibe, the default labels will show. When you start the game (and the plugin attaches to it), everything will appear as supposed to be.
    Thanks @yobuddy!
    I'll play with the profiles for LFS for now waiting on the updated plugins (don't forget my PM).
  9. llluis
    Quebec
    1,631Coins
    Hi @yobuddy, two questions:
    1) Why frequency is from -50 to +100? Is it possible to correlate this with Hz?
    2) In Vibe Creator, should we have a "None" location, to allow us to select if the effect goes to SoundCard #1 or #2 only?
    For instance, if I want Gear Shift only on FrontLeft on #2, how would I configure #1?
    One more note: if we close the Vibe Creator without hitting Save, it will save the changes anyway.
    edit: changed in the latest version
  10. yobuddy
    51,238Coins
    Well I want to get to where we can add more sound effects.
    (like anyone can try out any sound loop they make)
    And I'm not sure exactly what everyone will base their sound at.
    I made all the samples at 50hz, but we will see if we keep them there after the beta.
    And is 50% negative deep enough for all transducers?
    (I only got to test one set after all.)
    Do we have enough high frequency headroom too?
    (to much and the note becomes audible)
    I guess there is still some questions I have before I work out the fine details.
    In the end, I'm sure there is math for the proper output.
    2) Yes, this is a good idea!
    Man I spent all day working on the wrong sound card selected problem for XAudio2.
    (everything works fine on XP lol, but that's because it uses direct sound)
    Anyway, after a long day and not much working, i noticed they changed the way it works in the newest version lol.
    So I will try that tomorrow.
    It would be a whole lot easier if it was just a math +1 error lol.
    Take care,
    btw, the IPAddress windows problem was because I forgot to re-enable the main window after you click ok. :p
    Simple fix!
  11. yobuddy
    51,238Coins
    Great stuff @llluis,
    I can defiantly use all the feedback I can get.
    Thanks man!
  12. llluis
    Quebec
    1,631Coins
    Sorry to hear about the soundcard list issue. Let's hope the new version will help you.
    So, a 0 frequency in GameVibe (which is a %) means the tone will be 50hz? And our range, using the built-in samples, will be from 25hz to 100hz?
    Buttkickers can go as low as 10hz.
  13. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    not 10 but 5Hz
  14. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    @yobuddy thank you very much for this great software !
    everytime i do "alt tab" for tuning i get a little windows it says: gamevibe4 an other one game5 and so on ......
    i don't know why ?
  15. yobuddy
    51,238Coins
  16. yobuddy
    51,238Coins
    I almost have the next release done for GameVibe.
    Special thx to llluis for all his help in finding the sound card out of order problem.
    thx @llluis!
    Also the None option has been added for sound location and the Ip Address form now works as it should.
    Looks like I got a little testing to do!
    take care,
  17. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    Any idea when plugins other than LFS will be supported?
  18. yobuddy
    51,238Coins
    I'm going to try to set the next release to be between 25 and 100hz.
    its more than 4x the range we have now.
    We can bump the range up a bit more if it seems right on everyone's systems.
    @ericRacer, can you show me a pic of the tab problem.
    I can't seem to make it happen buddy.
    As soon as i get the core tuned where we need it.
    I just haven't gotten a lot of feedback yet either.
    Have people been able to get Rpm running or any other of the vibes?
    chat soon,
  19. Brett Horton
    Tampa FL
    118Coins
    152,676Coins
    +11,089 / 56 / -2
    Trouble is AC does not have a free demo for casual testers @Brett Horton.
    Perhaps if making such a suggestion something like RaceRoom Experience may be a better modern option, the base install is free but it is a pretty large download.
