My new sim - Prosimu T1000 3DOF
Discussion in 'Commercial Simulators and Peripherie' started by mirkobastianini, Dec 9, 2017.
  1. noorbeast
    153,710Coins
    Try larger Tuning Center values.
    Of course axis limiting is limiting ;)
  2. mirkobastianini
    mirkobastianini Active Member
    informatic
    italy
    1,300Coins
    Ok, but larger tuning center values doesn't changes the range of actuator, or no? Changes only speed, right?
    153,710Coins
    Larger Tuning Center values soften the motion over a larger axis movement, smaller is the reverse.
  4. RacingRichie
    RacingRichie Prosimu T1000 3DOF
    IT Consultant
    Europe/Austria
    118Coins
    3DOF, SCN6
    Hey,
    thank you for the pictures! I was acutally not supplied with any assembly manual and just found the one attached. Is there a more detailled one for building the 3dof version? I think I can do it with these pictures and the ones on isrtv but, a guide with pictures of the screws to use might save a lot of time. Patrick is not very responsive via Email these days :(
  5. Andrej_V12
    Andrej_V12 New Member
    Ljubljana
    163Coins
    I'm also very interested to buy ProSimu T1000 3DOF. But I already have the seat - PlaySeat Sensation Pro. I will buy the platform without the seat and somehow mount the PlaySeat. Does anyone know what is the max load on the 3DOF system?
  6. Giorgio73
    Giorgio73 Alluminium rig with prosimu 3dof kit
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    Also me I am interesting to buy a 3 dof prosimu but I have a a homemade rig in aluminium structurestructure I think the weight is similar to playseat rig or aluminium rig.
    I want buy the 2 scn6 prosimu kit and after I want upload with the traction loss kit.
  7. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    2DOF, SCN6, Motion platform
    Hi, I have the prosimu t1000 2 dof and think you will be happy with the motion. I too want the traction loss but feel that the wheel upgrade is needed before that . Just ask if you want information about my rig :)
  8. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    Hy Pim1, I am very happy to have your support. I think in the next day to order the prosimu kit.
    But before I need to built some part for to mach my structure with the prosimu component.
    I need to build the support plate of the scn6 actuator.
    I need also build the round support that you have under the seat for to inclinate the rig. In the scn6 kit this component are not included but are important for to assembling my rig to the traction loss prosimu kit
  9. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    Ok great sounds like you have a plan and some work to do over the next few days. Let me know when you get sorted :)
  10. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    Ok fantastic.
    To the starter I have some questions.
    Can you tell me how much is the weight of the t1000 structure ( more or less)
    Which racing game you play.
    Which racing wheel you use In this this moment? Wich is your dreamer wheel?
    Sorry for my English.
  11. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    Really not sure how much it weighs but patriPa should give you that information if you are about to order.
    I play AC and project cars 2 and waiting for vr support in ACC. My current wheel is CSR FANATEC so not the best wheel on the market but I find with motion it's seems to help with lack of strength in my wheel. That said I may get a 2.5 fanatec but would love the DD1 wheel but I fear it's just too much.
  12. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    At a guess it would be 50-60 kg with seat and wheel :)
  13. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    Thanks you for the information.
    I think my project rig can weight 50/60 Kg
  14. rmk83
    rmk83 New Member
    REGISTERED NURSE
    Pensacola, FL
    102Coins
    3DOF, SCN6
    The ProSimU frame has some weight to it, especially once everything is bolted on. Two people to carry it. I have been running in I Racing for the last few weeks and love it. If you want online racing with other people and to have quality races that's where you should race. I drove in PC2 before and the scenery is awesome. But after racing in I Racing now going back and driving PC2 it's a let down. The driving dynamics mainly. I like F1 also for Formula cars.
  15. r3df0x
    r3df0x n00by Racer Gold Contributor
    IT technician
    Canada
    236Coins
    2DOF, SCN6
    About weight ; I put two SCN6 (40Kg 100mm) under my rSeat RS1 and it does the job!
  16. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    Very good, how much is the total weight that the two scn6 must be move?
    I think the total weight is seat and driver.
    Can you show your application please?
    Thaks in advance
  17. r3df0x
    IT technician
    Canada
    236Coins
    2DOF, SCN6
    According to specs, my SCN6 can raise 40Kg each ...
    In fact, I applied the same principle as the ProSimu T1000 2 Motion
    I will post photos to show you my installation
  18. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    Fantastic red fox. I am very interesting to see your project because I want to do the same job.
  19. Denko92
    Denko92 New Member Gold Contributor
    225Coins
    Better is to dampen the ground and to build silentproof cases around the actuators (rockwool) and dont set acceleration to 500, because there are too much vibrations then. Set it to 160 or below. Thats was completely false in the rta motorsports instruction video and I had problems with my neighbour. Now he hears nothing when i drive. And the fun begins with 82 main level. Under 75 the movement is very low, then its like you are driving with a 30 hp car.
  20. r3df0x
    IT technician
    Canada
    236Coins
    2DOF, SCN6
    Sorry for the delay ... here is my installation :
