DIY Linear Actuator design
Discussion in 'Motor actuators and drivers' started by wannabeaflyer2, Mar 5, 2016.
  1. yobuddy
    51,535Coins
    I have been waiting to see a machine using these monsters!
    I can only imagine using them at 24v. lol
    Take care,
  2. llluis
    Quebec
    1,632Coins
    Is the 17mm arbitrary or does it have some reason?
    While printing my plates I find that infill is more important than the thickness.
  3. bruce stephen
    general contractor
    michigan
    9,115Coins
    monster motos at first because I have them but sabertooths(up to 30v dc) are in the plans. muahahah:D
    1605 ball screw with 5600 rpm. not sure about the math but that is the unloaded speed so it wont really apply anyway...
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
    17mm is what the pdf by @wannabeaflyer2 earlier in this thread called for.
    well the thickest plate anyway. then i just built from there. the original is 10mm for all except the part with the square hole in it.
  5. bruce stephen
    general contractor
    michigan
    9,115Coins
  6. wannabeaflyer2
    london uk
    8,350Coins
    Hi Guys I used 17 mm Thick Delrin ( Tradename for Acetal Co Polymer ) Material Mainly because that's what I had access to at the time 10mm would do the job the trick is to make sure the load is distributed evenly to minimise flexing which may or may not be a problem. if I had Aluminium sheet at the time the design may have been based on 8mm aluminium Plates.. some guys have used 18mm birch Plywood with good results . so to some extent its fitness for purpose material wise .. Cheers
  7. bruce stephen
    general contractor
    michigan
    9,115Coins
    @wannabeaflyer2 I see the design calls for 1605 ballscrews has anyone used 1610. they are a little more expensive but should be faster even with the increased loads.
  8. llluis
    Quebec
    1,632Coins
    Thanks much @bruce stephen, but I already did my plates.
    My design is slightly different from wannabeaflyer2. I'll post it when finished.
    Sorry if I led you to create it.
  9. bruce stephen
    general contractor
    michigan
    9,115Coins
    no worries. the resource is there for all members. I should also wait to post anymore as my design seems to be changing often. ive redrawn the plates three times now.
    still wondering if anyone has used the 1610 screws instead of the 1605?
  10. Dirty
    All the way up front.
    7,971Coins
    I am sure about the Math :):
    @5600 RPM they move at 466mm/s. If you use 1610 ballscrews they will move at 933mm/s. Unloaded of course. IIRC my motors develop max power at ~80% max RPM. That means you could still expect ~750mm/s (if your motors can deliver that).
    All in all I'd expect the 1610 to give you insane actuation speeds at the cost of greatly reduced acceleration performance or greatly increased cost for motors. Certainly a 50% loss in precision in any case. Your choice.
    Dirty
  11. Gadget999
    12,144Coins
    466 mm/sec should be plenty fast enough !
    has anyone actually measured the real speed when the rig is operating under full load ?
  12. bruce stephen
    general contractor
    michigan
    9,115Coins
    how would they be less precise? same position sensor with same resolution..... just more inertia to change direction. more torque to move
    they are 733 watts pos. stall (1hp). and run at peak efficiency at .4hp 310watts (5000 rpm @17amps 24volts) 5000rpm on a ten pitch is still >833mm per second no load.
    the acceleration is my main concern tho, i'm sure it will be fun if it doesnt break.
  13. bruce stephen
    general contractor
    michigan
    9,115Coins
    never fast enough lol. I have to build it to see how fast it is. I'm on actuator #1 tho so it will be some time before I finish.
  14. Dirty
    7,971Coins
    You're right! I was mislead. In my own design I was planning to pick up the position directly from the motor axis through a multiturn encoder. So, after the control loop did its Job, there would still be the mechanical inaccuracies in the system. These would double.
    If you pick up the position directly from the shaft, that would be quasi negligable. Sorry!
    Dirty :D
  15. llluis
    Quebec
    1,632Coins
    I'm still trying to figure it out if a Sabertooth 2x32 would handle these motors.
    They will not stall in the simulator, but don't know how much they will draw.
  16. RandomCoder
    Control Engineer
    1,674Coins
    The problem with opting to use a 1610 ballscrew instead of a 1605 is that the output torque is halved. You'll travel twice the distance per revolution and the load and motor size remains the same therefore more torque is required. At least that's my understanding of the physics required.
    Power = Torque x Speed.​
  17. Dirty
    7,971Coins
    First of all: @wannabeaflyer2 and @SeatTime , thank you very much for providing such a detailed description of your builds. Saved me A TON of work! I will pretty much use your design as is with a few minor changes, if you don't mind :thumbs
    Could you tell me if the actuator design allows for negative actuation. I mean: Is it designed to "pull" on the platform? If the ballscrew spins up pretty fast (or maybe if the 6 actuators are poorly tuned/wrongly configured) you might end up with a significant negative force on the actuator. Will the ballscrew be pulled out of it's bearing block?
    Thank you!
    Dirty :D
  18. wannabeaflyer2
    london uk
    8,350Coins
    Hiya @Dirty I hope I understood the question , from my limited understanding of the sim platform , t actuators are always under load with passenger on board so in most cases gravity a payload ensure the ballnut and bearings are loaded negatively as you mention . I really need some of the guys with running simulators to chime in as my baby is still mothballed ( waiting for me to get my arse back into gear ---and my graphics card update ) LOL :)
  19. SeatTime
    There would be some 'negative' inertia on the ballscrew as the sim rig changes direction quickly - my rig actually lifts itself off the ground sometimes - so there are allot of forces at play :). The ballscrew is although bolted into the bearing block - so this should not be an issue if your bearing block is suitably mounted.
  20. bruce stephen
    general contractor
    michigan
    9,115Coins
    I'll probably go with the 2x60's
