Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. yobuddy
    51,238Coins
    What do your max/min settings for the game look like?
  2. Hoddem
    Hoddem Well-Known Member
    Engineer
    Minnesota, USA
    3,343Coins
    +/-20 on the forces I’m trying to use. Those were the plugin defaults. But i tuning center there is no data coming through. When I do capture min max Then reset everything stays at zero.
  3. yobuddy
    51,238Coins
    Are you on a single or dual PC installation of SimTools?
  4. Hoddem
    Engineer
    Minnesota, USA
    3,343Coins
    Single pc
  5. yobuddy
    51,238Coins
    have you messed with any of the IP settings for game manger or engine?
  6. Hoddem
    Engineer
    Minnesota, USA
    3,343Coins
    I don’t think so, both are set at 127.0.0.1
  7. yobuddy
    51,238Coins
    "127.0.0.1 " that's correct.
    Looking at your pictures, you can see that game engine is not connected or running with game manger?
    Do you hear a Beep-beep when launching the game?
  8. Hoddem
    Engineer
    Minnesota, USA
    3,343Coins
    No, never heard a beep beep. Every time I launch iracing the game engine crashes. Same if I toggle the on off button in game manager.
  9. yobuddy
    51,238Coins
    Sounds like the game not sending correct data to simtools.
    I would un-patch the game.
    Then play the game once, and finish a race.
    Then re-patch the game and try again.
    let me know how it goes buddy.
    I personally don't have a IRacing account atm.
    So is anyone else having problems with this plugin?
  10. Hoddem
    Engineer
    Minnesota, USA
    3,343Coins
    I tried removing the patch, running a race and re-patching. no go. I also uninstalled and reinstalled iracing and I still get the crash as soon as I launch it.
    If I dont patch Iracing game manager stays running, but obviously no output.
    Problem signature:
    Problem Event Name: CLR20r3
    Problem Signature 01: SimTools_GameEngine.exe
    Problem Signature 02: 0.2.2.0
    Problem Signature 03: 5a360753
    Problem Signature 04: SimTools_GameEngine
    Problem Signature 05: 0.2.2.0
    Problem Signature 06: 5a360753
    Problem Signature 07: 445
    Problem Signature 08: 0
    Problem Signature 09: System.NullReferenceException
    OS Version: 6.1.7601.2.1.0.256.48
    Locale ID: 1033
    Additional Information 1: 0a9e
    Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
    Additional Information 3: 0a9e
    Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
    Read our privacy statement online:
    http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
    If the online privacy statement is not available, please read our privacy statement offline:
    C:\Windows\system32\en-US\erofflps.txt
  11. yobuddy
    51,238Coins
    I'm not sure buddy.
    That really does not give me any info to work with unfortunately. :(
    the plugin uses a memory mapped file I believe.
    My guess is its not finding that file, or the structure of the output file has changed.
    When was the last IRacing update?
    Maybe shut down your antivirus for a run and see if that helps?
  12. Hoddem
    Engineer
    Minnesota, USA
    3,343Coins
    something to do with my installation for sure, I just did an iracing simtools install on my windows 10 office computer and everything seems to be running just fine. simtools doesn't crash and I get a Game On notification in output testing.
    my racing rig is running windows 7
    So I will start uninstalling and reinstalling everything again.
  13. hazardic
    hazardic m3gt2 fan
    345Coins
    3DOF, Arduino
    @yobuddy i have similar problem: sometimes while playing Assetto Corsa in VR and motion i got "game engine has stopped working" error. This error is not consistent - it occurs sometimes. Sometimes 2-3 times during race, sometimes it just not existent and i play long sessions with no issues
    So it looks like this:
    i enjoy the race and suddenly my VR headset looses movement detection - the image in HMD became static and after 2-3 seconds it turns off - looks like disconnect. at this moment the race still live though - i should finish it by hot key, blindly. After i take off Rift i go to PC and see this pop up message
    no error codes - nothing. i click "close program" and after this the HMD starts working again - without any addition actions from my side! so in order to play again i should resart GameManager and start GameEngine again - after this i can play like always.
    Is there any log written somewhere so i could read what is going all at least? Could it be usb related - maybe some usb contacts are influenced by cold (i have cold air during race sessions) so the metal loose contact therefore SimTools looses interaction with hardware and this error pops up?
    This error was present on win 8.1x64pro and now is here too on win10x64pro
  14. yobuddy
    51,238Coins
    I would be willing to bet its related to your interface.
    Add a dummy network interface to game engine, and remove the interface you are using now.
    They try the game again (of course with no motion), but if it does not crash, you found the problem.
  15. Hoddem
    Engineer
    Minnesota, USA
    3,343Coins
    Boom, Its Working!!!!!
    I did a full reinstall of windows and changed from windows 7 to windows 10. So far I only have the bare minimum installed. I will keep testing to make sure none of my other software breaks anything as I install it.
    Thanks for the help
  16. hazardic
    hazardic m3gt2 fan
    345Coins
    3DOF, Arduino
    Thank you! What do you mean by dummy network - something different from 127.0.0.1? Should it work with another?
  17. yobuddy
    51,238Coins
    I mean the interface settings for game engine.
    I was thinking his game engine / interface was causing the crash is all.
    By dummy network, I meant setup a UDP interface that really does noting.
  18. hazardic
    hazardic m3gt2 fan
    345Coins
    3DOF, Arduino
    oh i see - so this is not about my issue:D
  19. yobuddy
    51,238Coins
    I would remove the usb hub and try again buddy.
    It defiantly sounds like the interface is loosing connection.
  20. hazardic
    hazardic m3gt2 fan
    345Coins
    3DOF, Arduino
    you mean usb hub for VR? i use Vive link box and actually it's a lifesaver cause amount of such disconnects were reduced. but still - i can't understand how this SimTools (GameEngine) crash is related to VR headset?..
    Could it be that once VR looses connect due to bad usb connection the PC system tries to reenumerate usb ports and GameEngine can't handle such procedure? Could it be? This is just the only thing comes to my mind..:( wish i do know is it possible at all..
