value1
Microsoft Flight Simulator X / Lockheed Martin Prepar3D Plugin 2.0.2.0
SimTools plugin for Microsoft Flight Simulator X and Lockheed Martin Prepar3D
  1. yobuddy
    51,605Coins
    For a 2 PC setup with FSX, please copy the files from the GameEngine installation folder to the GameMangers installation folder.
    "SimTools_GameManager.exe.config"
    "wow64ext.dll"
    These 2 files should be in the installation folder for GameManger (not game engine).
    This path is fixed for the next release.
    (this will only affect a 2 PC setup btw)
  2. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
    Thank you will try that
  3. lysa elec
    lysa elec LYSA ELEC
    16Coins
    Bonjour
    quel plugin utilisez pour p3d v4
    merci
    154,172Coins
    +11,174 / 57 / -2
    You need to include English, Google Traslate will do, as per the forum rules.
  5. lysa elec
    lysa elec LYSA ELEC
    16Coins
    I look for the plugin (simtool) for for p3d v4
    thanks
  6. vrxsim
    vrxsim New Member
    Barcelona
    144Coins
    3DOF, SCN6
    Could anyone confirm if V4 is supported with this plugin?
  7. value1
    14,255Coins
  8. paulopsx2
    paulopsx2 Active Member
    brasil
    648Coins
    moves ok. VIBES dont. ny idea? plugin ok, ip ok, dash output and tunning center ok... test with transducers and amplifiers.. ok. but no vibrations in game. test with admin rights, no admin, in game BEFORE and AFTER runs... dont works on any game. try asseto again and nothing...
  9. paulopsx2
    brasil
    648Coins
    see images ( nolimits 2 and prepar )
  10. yobuddy
    51,605Coins
    Looks like it need a small fix to the plugin itself.
  11. value1
    14,255Coins
    The FSX_P3D and the NLS plugins have already been fixed in the latest versions (2.0.2.0 and 2.0.1.17).
    @paulopsx2 Are you using these latest versions?
  12. paulopsx2
    brasil
    648Coins
    yes.. and asseto too, and project cars, and others.. all plugins same problem. ALL WORKS, show on dash, show on vibe tunning center, test sound on gamevibe its ok.. but no vibrations... this is freakin and burn my mind rs.. i try ALL... put game, track.. and after this open plugin, or open before... nothing works.
  13. paulopsx2
    brasil
    648Coins
    yeah... i think about.. but.. on ALL PLUGINS? asseto dont work, NLS dont works.. none of then... weird
  14. yobuddy
    51,605Coins
  15. paulopsx2
    brasil
    648Coins
    Yes
  16. yobuddy
    51,605Coins
    @paulopsx2
    Can you get sound when using the Vibe Creator?
  17. paulopsx2
    brasil
    648Coins
    i dont try this yet... only "test mode" on soundcard 1 and 2. it works.
  18. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
    Im running Sim tools 2.2.5 all my games work except fsx10, still get no data stream? any suggestions?
  19. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
    the error on launch is it wants internet access
  20. yobuddy
    51,605Coins
    SimTools does not need internet access so it must be the game?
