value1
Project CARS Plugin 2.0.3.3
SimTools game plugin for Project CARS
  1. Andrew Lawrence
    Andrew Lawrence Member
    Corning NY
    485Coins
    Is this plugin working with the demo version of Project Cars 2? I have tried both Shared Memory set to Pcars 1, and UDP, but seem to get no data incoming into Tuning Center? I wanted to test the game out with the G-seat before I drop $60 into it.
  2. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,045Coins
    Arduino, 4DOF
    Maybe you should try the project cars 2 plugin.... I made a PC version, using the demo version so yes, it works
    https://www.xsimulator.net/community/posts/149347/
  3. Andrew Lawrence
    Corning NY
    485Coins
    Thanks for the tip. Tried that too. I can get it to work fine on Pagani Edition but not on the PCars 2 demo. Not a huge deal, not sure if I want PCars 2, Pagani might be enough for me.
  4. vthinsel
    FRANCE
    6,045Coins
    Arduino, 4DOF
  5. value1
    15,079Coins
  6. Lol4
    Lol4 Member
    Australia
    - 115Coins
    Awesome work. Thank you.
  7. Lol4
    Lol4 Member
    Australia
    - 115Coins
    Just wanted to see if others have got Ga me Vibe working with PC2? I have updated via plugin updater, checked is enabled in game manager, IP is ok,, re patched a few times and all movement as per usual is ok, Game Vibe works fine in Dirt Rally. I did notice that it is not highlighted as per attached screen shot. If anyone can confirm is working ok for them I will keep trouble shooting this end. Also attached my PC2 settings but have not changed these as movement is fine.
  8. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    i think this is for PCars 1 not 2
  9. Lol4
    Lol4 Member
    Australia
    - 115Coins
  10. madVape
    madVape New Member
    Vape Store and Sim area
    104Coins
    Yesterday I purchased Simtools and download package to download the plugins. We managed to get LFS working perfectly and when we use the project cars plugin it does not move anything. Already activated Shared Memory in PCars but still no movement from the actuators.
    We got very little movement, but with an older version of the plugin (1.0) But when we use the same axis configuration as LFS the movement is very restricted and nothing like the previous one.
    What do I have to do to get this thing up and running?
    152,627Coins
    +11,087 / 56 / -2
  12. madVape
    madVape New Member
    104Coins
    We did the conversion from frex to simtools using rs485 adapters. We managed to get LFS workign fine by just using the preset for SimforceGT. But when we use that preset in PCars the actuators barely move at all. I never messed with tuning center for LFS, why do I need to do that with PCars? Isn't it supposed to be just for fine tuning?
  13. noorbeast
    152,627Coins
    +11,087 / 56 / -2
    Follow the steps in the link previously provided and lower the Tuning Center values.
    A motion profile has to be tailored for every game and every rig for best results.
  14. DOFreality
    DOFreality Member
    Montreal
    344Coins
    can someone remove this pops up message box/window from the plugin or fork another version without it?
  15. value1
    15,079Coins
  16. yobuddy
    51,227Coins
    @madVape
    Looks like you are using Sway and Surge for LFS, but using Pitch and Roll for Pcars.
    Probably the issue is you meant to use Sway and Surge for Pcars too?
  17. madVape
    madVape New Member
    104Coins
    Yup, I had tried the same settings. Sway and surge, but got no results. The problem was in game tuning. I didn't know I was even supposed to mess with those settings, Once I dropped the values to 3 instead of 10 it all started working fine. ;) Thank you very much to everyone for the answers ;)
  18. Pitchoun511
    Pitchoun511 Member Gold Contributor
    Perpignan
    387Coins
    152,627Coins
    +11,087 / 56 / -2
    Can you please post pictures of all of your settings, particularly your Interface Setting, Axis allocations and Tuning Centre.
  20. Pitchoun511
    Perpignan
    387Coins
    Here are the visuals. I have two other problems:
    - I can not edit a profile in "interface settings"
    - video ride player does not appear in my list of plugins
    Do you think these three problems are the same?
