value1
Raceroom Racing Experience Plugin 2.1.0.0
SimTools game plugin for Raceroom Racing Experience
  1. bob williams
    bob williams OSW sfx100
    IT
    Ermelo, Netherlands
    113Coins
    Thanks noorbeast! You`re a great guy!
  2. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    Can it be vibe time ?
  3. value1
    15,078Coins
    • Winner Winner x 4
  4. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
  5. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    Tested and working Thanks again:thumbs
  6. Historiker
    9,208Coins
    @value1 I have got to leave feedback for this plugin.
    Ok...I need a new vocabulary of superlatives.....lets see. FREAKIN AWESOME MAN! (ok, the old reliables still work)
    First the motion: The last time I tried this sim was with Simtools 1.2, it was good, moved the rig well. But with Simtools 2?!! I can feel every crack in the asphalt man! Tires give me a warning when I am getting too close to the edge, a quick jerk tells me that the gear is engaged. WOW.
    Second: Game Dash: I am only using Simulated Wind (thanks again @SilentChill ) but it works out of the box (pun intended....come on....racing humor.... :D ) Gives a nice immersion to any sim. Works very well with this plugin in particular.
    Third: Game Vibe. I have to admit that it takes some tinkering to get your Vibes just right but when you do it is incredible. Shift bump along with motion shift bump just syncs together perfectly. I am having issues with ground noise and bumps being on all the time as a low rumble but I need to work on my profile a bit more. Engine rumble under my feet tell me that my V12 [or enter favorite engine size here] is getting the amount of fuel that it considers YUMMY. :)
    Overall? Well Done Sir! Oh Well Done! :thumbs
  7. yobuddy
    51,223Coins
    Increase the 'Low' value for this input in Tuning Center for GameVibe.
    That will help turn if off when not needed.
    Take care,
  8. Historiker
    9,208Coins
    I have a strange issue today (ok, yes I have strange issues everyday).
    In R3E I get wildly fluctuating game data output. This flickers my axis back and fourth so fast that I popped a 20amp fuse in one motor. And this was while driving in a straight line (yes, I can drive in a straight line....sometimes).
    Yesterday it was fine, nothing changed that I know of.
    Here is something very odd; notice in the tuning center that it says that the game is Assetto Corsa?
    I tested Assetto Corsa and capturing Min/Max in R3E does indeed change Min/Max for Assetto Corsa.
    Assetto Corsa is not showing any unusual behavior.
    Ideas? Did I screw something up (again?)
    EDIT: I rolled the plugin back to the pre-vibe version and still am having the issue.
  9. Historiker
    9,208Coins
    Update: I manually deleted all plugin information in user/[name]/appdata/local/simtools and reinstalled the plugin. That fixed the issue.
    No idea why the profile .pro file for R3E would show <_GameName> Assetto Corsa</_GameName> rather than what it should (and does now); <_GameName>R3E</_GameName>
  10. Phil Barnes
    Phil Barnes New Member
    - 104Coins
    ok - I am using this to power my Wind Mod - thing is, when the game starts, the fans come on and then do not run faster - just a constant speed.
    I have Dirt Rally working lovely - care to share your settings?
    Thanks in advance
  11. Historiker
    9,208Coins
    I would love to have done so...I really would...unfortunately I am reinstalling everything to an old hard drive off the shelf as my simpit harddrive died yesterday :(
    Sorry.
    You might check your math settings, they may be too low for the game. I ran mine (I think) around 1.5.
  12. yobuddy
    51,223Coins
    Just a little bug, update out soon.
  13. Historiker
    9,208Coins
    @Phil Barnes Just in case the issue with not with simtools/GameDash I wanted to mention this:
    I have my simpit PC up and running again, which means that I had to set everything back up from scratch (Backup your profiles!!!! ;) ) and I found that R3E also started with fans on constant speed. For me the fix was that I forgot to enter an interface-output rate. After setting mine to 20ms it worked fine. I did have to reboot GameDash but I did not have to leave the game.
    Hope this helps
  14. Phil Barnes
    - 104Coins
    Thanks, but where is that setting (interface output rate) - and how do I set it?
    UPDATE - found it - duh - will test later!!
    Thanks awfully for the help!
    Phil.
  15. Phil Barnes
    - 104Coins
    ok - that sorted the issue out in RRE and Assetto corsa! Cool :)
    Only problem I have is now the fans trip when I reach maximum speed!
    Some more reading to do, but I do not think this is a SimTools issue :)
  16. Eliottk
    Eliottk New Member
    Austria
    247Coins
    today I tried Raceroom with the Sim Tool and I can't get it running. When I start the game my whole seat began to shake around with the sway axes.
    I installed the correct plugin twice but it didn't change anything.
    Please help...
    Kind regards
    Eliottk
  17. Historiker
    9,208Coins
    Hi @Eliottk, did you try doing a tuning center reset and capture?
  18. noorbeast
    152,595Coins
    +11,087 / 56 / -2
    Sounds like you need to refine the motion profile for it: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  19. Eliottk
    Eliottk New Member
    Austria
    247Coins
    thanks for the fast reply, no I din't try to reset the tuningcenter, I will try that.
    And I will also take a look at the motionprofile.
    Kind regards
    Eliottk
  20. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    331Coins
    Is simwind supported in this plug-in ?
    I just bought simtools v2 and was about to de-install v1.3 when read the in version history that there's no instrument support for R3E implemented.
