  1. evolaco
    evolaco Member
    Spain
    694Coins
    @RufusDufus
    The working resolution of smc3 is 1024 points, If I leave the limits to work for example with only 2.5V half the range, it stays at 512 points or within the limits is it still 1024?
  2. pimpi84
    pimpi84 New Member Gold Contributor
    Italia
    - 117Coins
    Hello guys! Hi @RufusDufus
    First of all thanks to the whole community! It's simply a perfect example of achieving something great through helping each other out.
    I have been using SMC3 since quite a bit, and I noticed, together with a friend of mine, that it seems that Kd term is not working at all on motor2.
    Anyone could confirm?
    I tried to do some quick debugging of the code, and the only differences I was able to find are related to the "SetOutputsMotor1()" and "...2()" subroutines.
    It seems that the following if()s are different.
    ...motor1...
    if(PWMout1 > (PWMmax1+LiftFactor1))
    ...motor2...
    if(PWMout2 > PWMmax2+LiftFactor2)
    Could this be the case?
    I corrected the parenthesis on motor2 code, but I also modified other parts during the debugging, and now it seems to work ok, but due to my other modifications I now always hardcode the parameters of motor1 also to motor2, so I am not quite 100% sure of my modifications.
    I wanted just to point out my findings, so that the owner could have a look at it.
    I am available for any further clarifications, ciao,
    Paolo
  3. satbranigan
    satbranigan Member
    spain
    - 180Coins
    thanks for the software, I had problems loading the code, because I programmed, MODE1 with ibt2, I did not know where I had to modify the code, finally I found this line in the skecht
    // #define MODE1
    #define MODE2
  4. shresans
    shresans New Member
    USA
    9Coins
    Hello @RufusDufus ! I am quite new to arduino coding and learning on the go. I am still trying to figure out how you got the packet data from the arduino and also how could I push commands to the arduino if I wanted to do so?
    Appreciate any help on this!
    Shreyas
  5. myxt75
    myxt75 New Member
    Bulgaria
    94Coins
    Hi guys,
    I need your help!
    I have build 2DOF motion rig and using this tutorial my creation is alive, BUT i have a little problem.
    When I use SMC3Utils to test the rig everything is working OK, but when I try to test it with "Output testing" from Simtools as soon as I hit "Turn ON" button the center position of the motors shifts in one direction. After that it is working ok but the rig is tilted. When I turn off output testing and start SMC3Utils again the rig goes to level position.
    Please give me any advice why this is happening and how to correct?
    Thank you very much!
    151,504Coins
    +11,041 / 56 / -2
    Can you please post pictures of all of your SMC3 and SimTools settings.
  7. myxt75
    myxt75 New Member
    Bulgaria
    94Coins
    My settings are uploaded!
      123.4 KB
      966
      223.2 KB
      979
      149.8 KB
      945
  8. myxt75
    myxt75 New Member
    Bulgaria
    94Coins
    And this is a short video showing the problem
    151,504Coins
    +11,041 / 56 / -2
    I don't use SMC3 but believe you will create a port conflict if you are trying to run the SMC3 utility and SimTools at the same time, it either has to be one or the other, and if this is all running on a single machine then choose SER in the Output Type of the Interface Settings.
  10. myxt75
    myxt75 New Member
    Bulgaria
    94Coins
    Smc3Utils is set in passthrogh mode just to show the problem.
    in real testing simtools output is set to use serial com.
  11. myxt75
    myxt75 New Member
    Bulgaria
    94Coins
    and after 1 full day of different tries i found that the problem exist only on my laptop. I have put a brand new copy of OS changing from win7 to win10 pro and guess what - the problem still exists.
    On my desktop everything works OK.
    Please give me some advice because i want to use my laptop.
    I have already change the OS. Install a fresh copy of arduino. fresh copy of SimTools2.2
    I have no idea what to do next!
  12. myxt75
    myxt75 New Member
    Bulgaria
    94Coins
    So,
    After a few more hours of reading and testing, finally I found the answer...
    To work properly SimTools is very important to set "System Locale" to United States.
    Changing only date format to US (mm/dd/yyyy) is not enough!
    Uploading some pictures how to do that for Win10
      58.3 KB
      882
      54.3 KB
      912
      65 KB
      905
      61.3 KB
      884
      49.2 KB
      883
      56.2 KB
      895
      29.5 KB
      888
  13. M.Giulini
    M.Giulini New Member
    - 6Coins
    Hallo i have a big problem with smc3 and sim tools, when i try the moviment in smc3 is all ok but when i use sim tolls after one big escursion the motors stars to 360' and never stop.
    151,504Coins
    +11,041 / 56 / -2
  15. M.Giulini
    - 6Coins
    I try different config but the problem is present
  16. profetadelmus
    profetadelmus New Member
    Vigo
    - 60Coins
    Hall sensors or potentiometers?
    151,504Coins
    +11,041 / 56 / -2
    What are you SimTools Interface and Axis Settings, please post pictures of them.
  18. M.Giulini
    - 6Coins
    I have arduino uno R3 with spy01 the same the motor monster (HB), i use directly potentiometers. My config is standard, when i use Smc3 utils the sim is ok but when i use Sim Tools the sim do what you wont...i don't know why.
    151,504Coins
    +11,041 / 56 / -2
    Just to be clear are you using pots or hall sensors?
    And are they actually connected to the motor, as they are not in the pictures.
  20. M.Giulini
    - 6Coins
    io using pots monted directly on motor, what you see are the same that i have in my sim.
    io have a second spy01 to do a drift effects, is 3° motor and pot in photo not legancy to sim e spy01.
