  1. noorbeast
    151,479Coins
    +11,041 / 56 / -2
  2. Chewwie2
    Chewwie2 Race Enthusiast
    Tile Installer
    Calgary A.B. Canada
    201Coins
    Oh yes, thank you Noorbeast. I will look at these links that you have provided me. I will post and show my project soon. Just do not want to loom like a total @$&. So many thanks again for all the help here.
    Chewwie2.
  3. M.Giulini
    M.Giulini New Member
    - 6Coins
    Ciao piloti sim io sono Marco, uso il sim dinamico da un paio di anni, adesso vorrei provare il mio 3dof, ora 2 dof perché ho bruciato un motore, con schede Spy01 con simtools che mi sembra un ottimo prodotto più frendly rispetto ad xsim. Avrò bisogo del vostro aiuto...
    151,479Coins
    +11,041 / 56 / -2
    Google Translate -
    Hello sim drivers I'm Marco, I use the dynamic sim for a couple of years, now I would try my 3dof, now 2 dof because I burned a motor, with Spy01 cards with simtools that seems like a great product more frendly than xsim. I will have your help ...
    Welcome @M.Giulini
    You can duel language post but it is part of the Forum Rules that you also include an English translation: https://www.xsimulator.net/community/threads/forum-rules.9527/
    We have bi-lingual speakers from many different language groups so if Google Translate really messes it up they can help clarify what was intended.
    You will find a whole section in the FAQs dedicated to setting up and tweaking SimTools: https://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
    Feel free to ask questions on your build thread, the members here give freely of both their time and expertise.
  5. kingwinkie
    kingwinkie New Member
    canada
    293Coins
    Hi
    Just another new person :)
    Just working through the faq and forum posts. I will say there are a lot of "google holes" to go down (searching for "would you like to know more")
    Every post I read, I learn more.
    I need to learn more before I start asking questions.
    151,479Coins
    +11,041 / 56 / -2
    Welcome @kingwinkie.
    The rabbit hole is indeed deep but there is a wealth of member information to help get you started and the community here gives freely of their time and expertise.
    Doing some research and planning is time well spent, and the Xsimulator.net community can help you out as you formulate your ideas about what you want to build and even where you can source parts from. A bit of research and consultation will save you a lot of time, money and frustration.
    I look forward to following your build thread once you get started.
  7. kingwinkie
    canada
    293Coins
    Yes you had a very nice build thread.
    I am a firm believer in "fast, easy, cheap, then pick 2" Just still at the point of what do I build (rig) verse what can I source locally /what do I have I have to buy.
    Just still at the point of figuring out what I don't know (verses what I should (know))
    151,479Coins
    +11,041 / 56 / -2
    Not a bad principle!
    Have a look at existing member builds, that may help you refine your own project ideas: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    You will find plenty to get you started in the FAQs, from design software, dimension of sims, to PSUs, pots, Hall Sensors, motors, JRKs, Sabertooths, Arduinos and Motor Monsters and more: http://www.xsimulator.net/community/faq/
    There is a glossary for common acronyms, which will help you decipher some descriptions: http://www.xsimulator.net/community/faq/glossary-of-acronyms-and-names.66/
    Have a play with SimCalc to help you get your head around some of the design related physics: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
  9. FargusFaustmeister
    FargusFaustmeister Member
    Engineering Technologist
    69Coins
    Hi Everyone, another new member today! I played Asseto Corsa at a friends house in VR and am hooked. He didn't have a motion sim but I am dead keen on getting one up and running to mod his system, then apply the concept to my own future setup ;)
    I harassed noorbeast on Reddit today and now I'm here to do my research and start a build thread. I'm a mechanical engineering technologist so I want to put a lot of effort into designing a product that fulfills the "haptic feedback" motion platform idea--short travel, high force movements--while being easy to build and inexpensive.
    Anyway, I'll be poking around and asking lots of questions, so sorry in advance ;) And thanks for making so many resources available for this endeavour. See y'all around!
    151,479Coins
    +11,041 / 56 / -2
  11. FargusFaustmeister
    69Coins
    Thanks for the warm welcome noor. I'll be digging deep into the archives of discussions and projects. Always best to build on the shoulders of those who have gone before, then sprinkle a little personal pizazz in once things seem to be doing what they're supposed to. At least that's what I'm going to try to do, instead of building a whole system from scratch.
  12. Neo_One
    Neo_One Member Gold Contributor
    Obersulm
    198Coins
    2DOF, AC motor, Arduino
    Hallo ich bin Sven aus Deutschland mitlerweilen fahre ich 5 Jahre Sim.
    Natürlich hat sich der "Rennplatz" immer weiter entwickelt bis ich dann Ende 2017 anfing mein ersten 2Dof Motion zu bauen.
    Werde diesen kleinen Bericht meines Motion noch erstellen da ich nun soweit bin das die Hardware fertig ist mit der Softwareverkabelung und erste Versuche ohne die X-Sim Software machen konnte.
  13. noorbeast
    151,479Coins
    +11,041 / 56 / -2
    Google Translate -
    Hello I am Sven from Germany mitlerunter I drive Sim for 5 years. Of course, the "racing place" has continued to evolve until I began in late 2017 to build my first 2Dof Motion. Will this little report of my Motion still create because I am so far now that the hardware is done with the software cabling and first attempts without the X-Sim software could do.
    Welcome @Neo_One.
    Please be aware that you can dual language post but it is part of the Forum Rules that you also include an English translation: https://www.xsimulator.net/community/threads/forum-rules.9527/
    If you are seeking build, hardware and software information to get you started, then look in the FAQs: http://www.xsimulator.net/community/faq/
    We have a glossary for all those acronyms we tend to use, which will help you decipher some descriptions: http://www.xsimulator.net/community/faq/glossary-of-acronyms-and-names.66/
    Good luck with your project.
  14. dyuji
    dyuji New Member
    Sao Paulo, Brazil
    166Coins
    Hi there! I'm electrical engineer I live in Sao Paulo Brazil and I love to have fun with DIY projects envolving electronics, programming and simulation. My main knowledge is in embedded electronic , C programming and communication stacks. I'm looking forward to learn more with you guys. Cheers!
    151,479Coins
    +11,041 / 56 / -2
    Welcome @dyuji.
    You have some useful core skills.
    Doing some research and planning is time well spent, and the community here can help you out as you formulate your ideas about what you want to build and even where you can source parts from.
    You will find plenty to get you started in the FAQs, from design software, dimension of sims, to PSUs, pots, motors, JRKs, Arduinos and Motor Monsters and more: http://www.xsimulator.net/community/faq/
    Feel free to ask questions, the members here give freely of both their time and expertise.
  16. mac_peck
    mac_peck New Member Gold Contributor
    14Coins
    Bonjour à tous,
    Je suis nouveau et du Nord Est de la france
    j'ai decidé de me lancer dans la construction d'un simulateur 6 DOF en version mini dans un premier temps avant d'envisager un model plus important. Je joue à ProjectCar2.0 et essentiellement X-plane11.
    Google Translate
    Hello everyone,
    I am new and from the North East of France.
    I decided to start building a simulator 6 DOF mini version at first before considering a larger model. I play ProjectCar2.0 and essentially X-plane11.
    151,479Coins
    +11,041 / 56 / -2
  18. mac_peck
    14Coins
    Hi Noorbeast,
    For the moment I have the servos motor, my arduino, I miss the links that should arrive, I try for the moment to configure my arduino to operate the engines on x-plane11 with arduino codes encountered on the web for make a platform to Stewart. I still have many things to discover again before I've already seen several great achievements of X-Simers, I started reading the FAQ.
    Thank you for your support.
  19. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    151,479Coins
    +11,041 / 56 / -2
    Welcome @Haraguchi, I look forward to following your build thread.
