VR Motion Cancellation - Time to test!
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by noorbeast, May 6, 2017.
  1. evolaco
    evolaco Member
    Spain
    694Coins
    in assetto corsa, you start it in steam vr mode, I just put a reference touch and put the compensation mode
  2. Eliottk
    Eliottk New Member
    Austria
    247Coins
    Ok, I'm trying it with Project Cars 2 but I can'T get it working.
  3. evolaco
    evolaco Member
    Spain
    694Coins
    and the turns because it does not compensate them? I want to compensate for the loss traction but if I turn a few degrees the image will be off as if I were looking at a square image, this is so?
  4. evolaco
    evolaco Member
    Spain
    694Coins
    Same problem, has it solved it?
  5. apointner
    apointner Siddhartha
    N 48° 9'0.88" E 12° 5'45.84"
    764Coins
    This is only for a certain motion platform. But i startet a request if this app could work out for other motion software also.
  6. apointner
    764Coins
    Here is the fast answer:
    Hi André.
    At this moment our software is dedicated to work only with our motion platforms to ensure highest possible compatibility and easy of use. We do not support 3rd party motion platforms because compatibility and performance issues. We just don't have resources to tune each case individually. Additionally introducing interface for 3rd party motion platforms would also allow our competitors to use our software for their products and it would involve complicated licenses enforcing procedures.
    Our course we might consider making VR HeadWay a separated product in future, but it will not happen soon.
    BTW. Does your motion platform support forward kinematics so it is able to provide absolute pitch and roll in radians to motion cancellation software?
    Regards
    Paweł Koczan
    MotionSystems
  7. evolaco
    evolaco Member
    Spain
    694Coins
    Is there a way to fix the yaw? every time the structure turns with the loss traction there are black stripes on the sides as if the screen were moving, that makes the cancellation totally useless
  8. bendrexl
    bendrexl New Member
    USA
    101Coins
    I'm not sure if the developer is monitoring this thread; you could also comment (with your whole setup / settings details) in the GitHub thread the OP linked: https://github.com/matzman666/OpenVR-InputEmulator/issues/4#issuecomment-299575175
    I'm also going to be setting up a Rift on a 3dof platform soon, so I may be in the same boat as you with this problem. I'll update with my experiences.
  9. evolaco
    evolaco Member
    Spain
    694Coins
    Thanks, I'll ask there
  10. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,277Coins
    Sadly no, as some others said in the github thread, I also bought a Vive especially for this.
  11. evolaco
    evolaco Member
    Spain
    694Coins
    And can not you cancel the cancellation of yaw with the software?
  12. Wagnard
    Wagnardsoft
    5,277Coins
    Not that I know of, sorry.
  13. MWB
    MWB Drive it like you stole it!!
    Commissioning Engineer
    U.K.
    424Coins
    2DOF, DC motor, Arduino, Motion platform, 4DOF, 6DOF
    Hope your all enjoying whats left of your easter weekend.
    I've been trying to catch up with some of the developments, and give my rig a bit of a treat in the way of motion cancellation. For quite some time I've just been putting up the this problem, but a relatively cheep set of unused Oculus Touch controllers popped up on Ebay. $$$
    So I've mounted one of the controllers to my rig, I have decided to mount the controller just in front of my steering wheel.
    I just can't seem to get it to work!!!
    I have installed the (OpenVR-InputEmulator v1.3.exe) I can somewhat get it to work in SteamVR Home, if I move my rig the motion cancellation seems to work but I get black borders around the outside of the Oculus screen.
    I have tried to open PC2 via Steam and the cancellation stops working.
    After trawling through all 18 pages of this thread, I have seen that ReVive is being used to run the Games.
    I've installed (ReVive 1.2.2) and injected Dirt Rally and PC2. (I'm hoping I've done this correctly!!!)
    Dirt Rally loads differently and seems to be the most promising, it's loading through SteamVR but the motion Cancellation is not working!!!
    Likewise for PC2.
    Any help would be gratefully received.
    :think
  14. MWB
    U.K.
    424Coins
  15. apointner
    764Coins
    Doas someone own a Vive pro already? And if yes, doas motion cancelling work with DCS?
  16. traveltrousers
    traveltrousers Active Member
    Timbuktu, Tombouctou, Mali
    890Coins
    No reason why not... it's on SteamVR so should be fine.
  17. SeatTime
    Does this still work since steam closed off the VR beta to allow the motion compensation plugin to work?
  18. apointner
    764Coins
    What the....? They do it like occulus, throw out the hole community and build a fence around?!
  19. clyevo
    clyevo New Member
    185Coins
    I am not at home so i cant try this, and i am planning to buy vive pro for this purpose.
    1. Can anyone try to opt-in VR beta in steam like in the picture and test if the plugin still works in this mode.
    2. Did anyone tried vive pro yet? Does it work as well or better than vive with the plugin.
  20. evolaco
    evolaco Member
    Spain
    694Coins
    for oculus there is still no solution for cancellation of movement?
