2 dof for ps4
Discussion in 'DIY Motion Simulator Projects' started by Notre, Mar 9, 2017.
  1. Notre
    Notre New Member
    seville
    - 69Coins
    Hello I am from Seville (Spain) I communicate with you through translators. I am making a simulator for ps4 com logitech g29 a baquet momo some lamps of diachroic lamps, arduino two bridges for 12 volt motors of ibiza 6l windscreen (2004). I am an electrician and my blacksmith friend is the one who helps build the structure. I leave you some photos
  2. Notre
    Notre New Member
    seville
    - 69Coins
  3. Michael McMillan
    Michael McMillan New Member
    new zealand
    154Coins
    Hi how will you controll it? from the wheel or ps4?
    152,373Coins
    +11,076 / 56 / -2
  5. Notre
    Notre New Member
    seville
    - 69Coins
    hello again I already have my 2dof ready with smc3 firmware since in the future I will add the tracction loss. I have a problem. when I use smc utily the engines work perfectly for me but with the simtools program they do not work for me. only one led in arduino flashes quickly.
    152,373Coins
    +11,076 / 56 / -2
    Can you please post pictures of your SMC3 settings and SimTools Interface and Axis Allocation settings @Notre.
  7. Akj6zero
    Akj6zero New Member
    Attichy
    156Coins
    Hello, nice start of structure for your simulator.
    For Simtools, be careful not to forget to fill a parameter salt, I had the problem at my beginning, I looked for 3 days before realizing that I had just forgotten to fill a box, so check that everything is filled.
    Good continuation...
  8. Notre
    Notre New Member
    seville
    - 69Coins
    Hello !! after intwntar several times, I already got my engines to move with ps4. Now all the values have to be adjusted and the potentiometers have to be perfectly fitted with some pinions that are making me.
    then I leave some photos of the process.
    a greeting!
    20180315_223418.jpg 20180315_230231.jpg 20180315_223429.jpg 20180315_223410.jpg
  9. Notre
    Notre New Member
    seville
    - 69Coins
    Hello again, after a long time, I come back to continue my project.
    Among other things I go to the PC platform
    After my first project without great successes due to various failures, now I come back with more knowledge thanks to all the contributors to this forum.
    Used:
    - improper power supply
    - underpowered engines with unsuitable gearbox.
    - very low quality potentiometers
    The result :
    It worked, which for me is already a lot. So now I decided to perfect it with better components.
    Next I show the components that I am going to use:
    Motor: https://es.aliexpress.com/i/32926108505.html
    gearbox : 50:1
    Potenciometer: https://www.mouser.es/ProductDetail/858-6127V1A180L.5FS
    power supply: mean well 24v 20A for each motor
    What do you think of the new components? THANKS!!!
    IMG_20200405_104831.jpg IMG_20200405_105041.jpg IMG_20200405_104831.jpg IMG_20200405_104853.jpg IMG_20200409_110028.jpg
  10. Zef
    Zef New Member
    Electrical Engineer
    Gothenburg, Sweden
    149Coins
    2DOF, DC motor
    Looks like you got a much better selection of components for your new build.
    I also looked at those potentiometers for my build, seems really good.
    Mean well power supplies I have used before and done some measurements on, really well built power supplies for a reasonable price, great bang for the buck!
    What motor drivers will you use now?
  11. JayZ83
    JayZ83 New Member
    152Coins
    Great to find your threads with PS4. Now i have more confidence on it.
    Currently am also working on PS4. Planing to build a 3DOF + traction loss.
    I don't have a PC but a small tablet hopefully it could run Simtools. LOL.
    Will see.
    152,373Coins
    +11,076 / 56 / -2
    It it a Windows tablet?
  13. JayZ83
    JayZ83 New Member
    152Coins
    Yes Windows Tablet. but not a high end one.
    Planning this tablet as a hub to communicate PS4 and Arduino."Hopefully they will talk to each other."
    152,373Coins
    +11,076 / 56 / -2
    As long as it is x86 SimTools should run on it, as SimTools does not use a huge amount of resources.
  15. JayZ83
    JayZ83 New Member
    152Coins
    Great news. Thank you so very much.
    Once all parts is ready , will start posing my project for application.
    SMC3 testing Ok on currently electric parts, Arduino BTS7960 +12V.
    Thanks again for your supports.
  16. Notre
    Notre New Member
    seville
    - 69Coins
    I have a problem with both engines.
    The motors are continually stopping and I have to press the reset button on the arduino
    I use ibt2, in smc utily I observe that the yellow line (pwm) is very irregular.
    in my opinion with many peaks.
    Could they tell me that I have bad?
    152,373Coins
    +11,076 / 56 / -2
    Can you please provide pictures of all of your settings.
  18. Notre
    Notre New Member
    seville
    - 69Coins
    Also say that he added some pneumatic pistons to smooth the movements.
    Without the pistons the platform did not return to position 0 when it had to go up.
    when no one is on the chair it seems to work.
    sdjoint the photo of the configuration.
    152,373Coins
    +11,076 / 56 / -2
    Can you also please post pictures of all of your SimTools settings.
    Under what circumstances do the motors stop, is it hitting something or something else?
  20. Notre
    Notre New Member
    seville
    - 69Coins
    right now I am not in front of the pc.
    In my opinion the engines stop when they have to make an extra effort.
    it also happens when I move quickly in smc3 utily.
    could the ibt2 be defective?
    the ibt2 have feedback towards the arduino? I cannot find the reason for the stop since the feedback of the potentiometer never exceeds the maximum limit.
    all of this happens mostly since I added the pistons although before it also happened less frequently
