Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. yobuddy
    51,105Coins
    Play without VR for a few, see if the problem still persists.
    If it does, it's not in the VR stuff.
    This is the only way to narrow down where the problem is I think.
  2. SBDESIGN
    SBDESIGN some knowledge
    director
    125Coins
    2DOF, SCN5
    How do we see which version we are running?
    I'm about to sort gamevibe and new plugins, but want to be sure I'm up to date.
    thank you
    152,373Coins
    +11,077 / 56 / -2
    The version is on the SimTools splash screen.
  4. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    Thanks for super speedy response as always noorbeast
    My splash screen on game manager is 0.2.1.0
    do I have to uninstall?
    Or do i just begin 2.2 install and all settings will be kept?
    is there a way to back up my interface settings etc?
    Its all simple when u get into it, but damn its head frying if not touched or tweaked in a while.
    152,373Coins
    +11,077 / 56 / -2
    No you don't need to uninstall.
    To backup just zip up and save the SimTools folder: C:\Users\your_user_name\AppData\Local\SimTools
    152,373Coins
    +11,077 / 56 / -2
    You can also look up your SimTools license number, just log into SimTools.us: https://simtools.us/member-login/
    Use the email you purchased the Licenses with, and if you don't have a password, click reset password.
    How to Register SimTools 2: https://www.xsimulator.net/community/threads/how-to-register-simtools-2-0.9720/
    152,373Coins
    +11,077 / 56 / -2
    If you have a license validation issue then PM @yobuddy.
  8. yobuddy
    51,105Coins
    152,373Coins
    +11,077 / 56 / -2
  10. yobuddy
    51,105Coins
    yobuddy updated Motion Simulation Software SimTools with a new update entry:
    SimTools v2.2.5
    Read the rest of this update entry...
    • Winner Winner x 3
    152,373Coins
    +11,077 / 56 / -2
  12. yobuddy
    51,105Coins
    We aim to please! :cheers
  13. Mu-KwangKim
    South, Korea
    - 689Coins
  14. yobuddy
    51,105Coins
    What screen resolution you on buddy?
    I can't get it to do that here.
    For now, you can move the assignment to DOF slot #5.
    We read these settings from left to right where they should equal a total of 100 to 130%
    Take care,
  15. Mu-KwangKim
    South, Korea
    - 689Coins
    @yobuddy
    I used 5760x1080
    If you set 6DOF, you can not use it as a method that you have noticed.
    Maybe korean windows problem...
    Simtools 1.3 was fixed with a separate Highres patch.
  16. vsp19
    vsp19 keep Sim-Racing Gold Contributor
    170Coins
    2DOF, 3DOF, SCN6
    Hello yobuddy
    I use an e-belt tensioner with a SCN
    Unfortunately, I can only use the Half Way of the SCN for belt tightening.
    In order to use more than half way for the brake command surge,
    there should be a possibility to be able to move the initialized middle position.
    So I'm looking for a solution to shift the middle position of a SCN HyperAxis,
    so I have a longer actuator path to one side
  17. Mu-KwangKim
    South, Korea
    - 689Coins
    @vsp19 With version 2.2.5, the SCN is located exactly in the center.
  18. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,041Coins
    Arduino, 4DOF
    My windows 10 is going nuts with the latest release :
    What have you put in ? :)
    Windows Defender is not happy about it...
  19. yobuddy
    51,105Coins
    Yes, the release probably needs to go thru a round of summiting the release to antivirus companies for exclusions from their virus detectors.
    I had to submit the last release with Windows Defender to get it to play nice.
    So it's just seeing this new release as 'different' or a problem.
    You can either wait for the false detection to update thru their system.
    Or install something better, like AVG free or Avast free.
    Both would do a much better job of protecting you online IMO.
    Take care,
  20. yobuddy
    51,105Coins
    This would require a custom Interface Plugin I'm afraid.
