value1
Codemasters Dirt 3 Plugin 2.0.0.1
SimTools plugin for Codemasters Dirt 3
  1. jjanu
    jjanu LiveForSim Gold Contributor
    Multimedia
    Québec
    643Coins
    Guys, when you look at the following settings for my 4 axis, would you recommend any change? Is it ok to put 100% for Roll although this DOF is shared with sway? Should I put 50 for each instead? I also increased the Main Level intensity to 100 % in Game Manager to have stronger force. Thx
    50039 50040
    152,373Coins
    +11,076 / 56 / -2
    As I already pointed out Axis Assigments of 200% total are way too high and you need to refine your motion profile following the steps in the already provided link: https://www.xsimulator.net/community/threads/codemasters-dirt-3-plugin.4763/page-3#post-153479
  3. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    I @value1 !!!
    I know, it's a very old game ... but is it possible to hope for an update of the plugin for the Game Vibe support ??? :D
    Thank you!!!
  4. drowhunter
    drowhunter New Member
    - 8Coins
    Does this support simulators like the Yaw VR 2?
    152,373Coins
    +11,076 / 56 / -2
