value1
Raceroom Racing Experience Plugin 2.1.0.0
SimTools game plugin for Raceroom Racing Experience
  1. Historiker
    9,205Coins
    Yes, game dash and game vibe work well
  2. value1
    14,236Coins
    Description of GameDash and GameVibe variables added to the plugin description.
  3. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    332Coins
  4. Phil Barnes
    Phil Barnes New Member
    - 104Coins
    I have SimTools and Game Dash - works a treat.
    I don't use SimWind - but I have simulated wind in RRE - and it works a treat..... :)
  5. nighthawkra
    nighthawkra New Member
    usa
    - 29Coins
    i tried looking and sorry if this was already asked, but is there no traction loss support for R3E?
  6. Historiker
    9,205Coins
    Yes, it is set as extra 1
  7. sberns
    sberns Member Gold Contributor
    432Coins
    3DOF, SCN5, Arduino
    Is anyone else getting 5-6 persistent wobbles / oscillations after each upshift / downshift in R3E ? It happens in most cars, but it’s especially prominent in the GT3 cars. I’m getting it with surge (simtools V2) on my DIY Gseat but it’s also happening on my SimX motion rig (SC4 not simtools). I think it’s coming through on the R3E telemetry side rather than due to the plug in but I was wondering if a fix was found?
  8. Historiker
    9,205Coins
    Yes, and the movement seems off lately.
  9. RacingRichie
    RacingRichie Prosimu T1000 3DOF
    IT Consultant
    Europe/Austria
    118Coins
    3DOF, SCN6
    yes, i posted/asked about the same behaviour a few months ago but i think the post was deleted... you can tune them (i think surge) to tone it down with the downside of impacting other movements. People say its rather a problem/behaviour of RRE... no real solution to my knowledge
  10. value1
    14,236Coins
    I'll check, if there's a change in the telemetry data structure.
  11. sberns
    432Coins
    3DOF, SCN5, Arduino
    Thanks guys. Andi chimed in on the thread I started on the sector3 forum and wondered if it was transmission flex coming through. If so, i guess it may require a fix on their end...
  12. value1
    14,236Coins
  13. sberns
    432Coins
    3DOF, SCN5, Arduino
    Amazing! Will test it out and let you know!! Thanks very much :)
  14. sberns
    432Coins
    3DOF, SCN5, Arduino
    Tried it out. Unfortunately, the issue remains. Must be on the R3E side. Thanks again for the update!
  15. schubnel
    schubnel New Member
    france
    85Coins
    3DOF, SCN6
    thank you for this plugin, i have a T 1000 3 dof with traction lost,
    extra 1 don't work with RRE ?
  16. yobuddy
    51,518Coins
  17. schubnel
    schubnel New Member
    france
    85Coins
    3DOF, SCN6
    Yeh many thx, it works perfectly
  18. Ahmad Said
    Ahmad Said New Member Gold Contributor
    Malaysia
    208Coins
    2DOF, 3DOF, SCN5
    Hello, Need a little help on setting up traction loss (extra1). I did this before but had to reformat windows and redo everything. In tuning center, I am having some values from Extra1 when the car is at the pits. THis makes the traction loss wobble back and forth. Below is the screenshot how I set up Axis Assingments. everything works in Output testing the way it should be. Is'nt Extra1 suppose to be dead 0 when the car is not even moving? even when moving in a straight line no?
    153,703Coins
    You likely need to refine the Tuning Center values, do Extra1 by itself, with all other axis turned off, see tips here: https://www.xsimulator.net/community/faq/traction-loss-in-simtools.175/
  20. schubnel
    schubnel New Member
    france
    85Coins
    3DOF, SCN6
    How value you have in tuning center ?
    I have a t 1000 3dof and I have 80 % on axis 3a and the case is not orange for not invert the motion .
    In tuning center : extra 1 is 10 / - 10
