Question Not running motor in reverse direction with MM Shield driver
Discussion in 'SimTools DIY Version' started by Prabin Kumar Jha, Mar 5, 2018.
  1. Prabin Kumar Jha
    Prabin Kumar Jha Member
    271Coins
    I removed plug in and unpatched the dirt rally and ran for complete one race and again plugged in and patched it. As my pc is 64 bits so according to instruction, it is patched but there is no response even I put 20% surge and rest 0 in interfacing setting.
    Please find the information I got in hardware setting of dirt rally in /My Game/hardware settings below. This may give some leads.
    <?xml version="1.0" encoding="UTF-8"?>
    -<hardware_settings_config deviceId="0x0166" version="11">
    -<cpu>
    <threadStrategy fileStreamProcessor="1" updateProcessor="1" renderProcessor="0" dataSetMonitorProcessor="0" dvdStorageProcessor="1" forceFeedbackProcessor="1" workerMapFile="system/workerMap2Core.xml"/>
    </cpu>
    -<audio_card>
    <dynamic_range value="high"/>
    <eq value="flat"/>
    <voice_chat enabled="true"/>
    <push_to_talk enabled="true"/>
    </audio_card>
    -<graphics_card firstBoot="true" rating="2">
    <directx forcedx10="false"/>
    <eyefinity osd="" force=""/>
    <stereo enabled="false" convergence="0.5" separation="0.015"/>
    -<resolution multisampling="off" vsync="0" fullscreen="false" aspect="auto" height="682" width="1103">
    <refreshRate rate="60"/>
    </resolution>
    <gamma level="0.8"/>
    </graphics_card>
    <shadows enabled="true" particles="false" maskQuality="0" size="1024"/>
    <advanced_fog enabled="false"/>
    <particles enabled="true" nearFadeBias="0" lowResScalar="4" dynamicRes="true" wind="true"/>
    <weather quality="0"/>
    <crowd enabled="true" detail="2"/>
    <cloth enabled="true" tessellation="true"/>
    <groundcover clutter="false" mode="atoc"/>
    <objects stones="false" maxlod="0" lod="1.0"/>
    <trees maxlod="0" lod="0.75" meshes_in_all_passes="false" meshes="true"/>
    <vehicles lodQuality="1" characterQuality="2"/>
    <track lod="0.6"/>
    <envmap size="256" mindistance="0.0" scaleminsize="1.5" drawallobjects="false" faces="6"/>
    <water detail="1" tessellation="true" drawallobjects="false" scale="8" update="true"/>
    <mirrors enabled="true" height="128" width="384" car_culldist="200.0" car_maxlod="2"/>
    <skidmarks enabled="true"/>
    <dynamic_ambient_occ enabled="true" quality="2"/>
    <dynamic_ambient_occ_soft enabled="false"/>
    <night_lighting shadowSize="1024" onlyHeadlights="false" shadows="false" lights="0" volumes="false"/>
    <textures resolution="1"/>
    <shaders quality="1" low_quality="false"/>
    <anisotropic max="2" min="1"/>
    <physics vehicleDamage="true" environmentalDamage="true"/>
    <input device_type="auto"/>
    <screenshotMode enabled="false"/>
    <aoit enabled="false"/>
    <avsm enabled="false"/>
    <mouse_support enabled="false"/>
    <oculus enabled="true" convergence="1.0" orientationLock="false" verticalOrientation="0.66" overdrive="true" vignette="true" timeWarp="true" chromatic="true" headMovement="true"/>
    -<motion_platform>
    <dbox enabled="true"/>
    <udp enabled="true" delay="1" port="4123" ip="127.0.0.1" extradata="3"/>
    <fanatec enabled="true" ledTrueForGearsFalseForSpeed="true" wheelVibrationScale="1.0" pedalVibrationScale="1.0"/>
    </motion_platform>
    <controls neutralTimeToShift="0.25"/>
    </hardware_settings_config
  2. Prabin Kumar Jha
    271Coins
    Is there is any idea?
    153,866Coins
    +11,152 / 57 / -2
    The correct patch path on 64bit is C:\Users\Your_User_Name\Documents\My Games\DiRT Rally
    Does Game Manager turn blue when Dirt Rally is running?
    Does the top row of the Tuning Center have values when Dirt Rally is running?
    Does SimTools work correctly with Live For Speed, which is free to download here: https://www.lfs.net/downloads
    Please post pictures of your Interface Settings, Axis Assignments, plus Game Manager and Tuning Center while the game is running.
  4. Prabin Kumar Jha
    271Coins
    thanks. I am downloading lfs and let you know the results as suggseted.
  5. Prabin Kumar Jha
    271Coins
    Pls. find reply of above queries:
    1 The correct patch path on 64bit is C:\Users\Your_User_Name\Documents\My Games\DiRT Rally
    2.Does Game Manager turn blue when Dirt Rally is running?
    3.Does the top row of the Tuning Center have values when Dirt Rally is running?
    4. Interfacing setting of game engine:
    Rest for ifs, I will share with you very soon. Pls. comment on the above screenshots.
    153,866Coins
    +11,152 / 57 / -2
    The data is present in the Tuning Center @Prabin Kumar Jha, so the profile may need some work but SimTools is working.
  7. Prabin Kumar Jha
    271Coins
    What kind of profile to be worked. Please brief it. I patched after one complete race game.
    153,866Coins
    +11,152 / 57 / -2
  9. Prabin Kumar Jha
    271Coins
    ok I do this and let you know. Only this may be the way to get response of seat dynamics?
    153,866Coins
    +11,152 / 57 / -2
    I am not sure I understand your question. The link provided goes through the steps for creating and refining a motion profile, it takes time and some practice but gets easier once you get the hang of it.
  11. Prabin Kumar Jha
    271Coins
  12. Prabin Kumar Jha
    271Coins
    I started setting the tuning centre keeping surge 20% and rest zero and I got following information in TC but there is no response in seat play. I am still doing. Please correct me if I am wrong.
  13. noorbeast
    153,866Coins
    +11,152 / 57 / -2
    The TC values, other than sway, look way too high, I have mentioned before that these are the steps to create and refine a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    The data is there in SimTools. Is Output testing working correctly and if so have you created an Axis Assignment for Dirt Rally?
  14. Prabin Kumar Jha
    271Coins
    I kept sway 20% and surge 0% in axis assignment. pls. find the screenshot as follows. PLs. comment. Now I am doing for heave. Still there is no response in motors once connected dirt rally.
    153,866Coins
    +11,152 / 57 / -2
    You need to answer my earlier questions, is Output testing working correctly (motors move) and if so have you created an Axis Assignment for Dirt Rally?
  16. Prabin Kumar Jha
    271Coins
    yes sir, motors work as output testing through slider.
  17. Prabin Kumar Jha
    271Coins
    Pls. find axis allocation for dirt rally and motors move with the help of slider
  18. noorbeast
    153,866Coins
    +11,152 / 57 / -2
    Did you test SimTools with LFS as suggested?
    LFS needs to be run for a couple of laps before patching.
  19. Prabin Kumar Jha
    271Coins
    I downloaded it as you gave the link but having issue with logitech g29 steering wheel setting.
    So I witched to dirty rally again.
    153,866Coins
    +11,152 / 57 / -2
    Use a keyboard if you need to, testing LFS is to try and rule out configuration issues.
