Cousin of OSW (Open Sim Wheel)
Discussion in 'DIY Motion Simulator Projects' started by Gadget999, Sep 23, 2017.
  1. Vdub180
    Vdub180 Member
    England
    148Coins
    Sorted now I had mixed up to of the wires off the arduino, all working now but have a new problem although the feedback works correctly it feels so week I'm running PH-8M motor off a scooter powered off 2 12v battery's connected in series to put out 24v, for some reason it only works at 4Mhz anything more and I have to reset the ibt 2 controller after a few seconds.
  2. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    What are the specs of the motor?
  3. Vdub180
    Vdub180 Member
    England
    148Coins
    Can't find any specs on the motor all I know is its 24v and its off a scooter the model is PH-8M
  4. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
  5. Gadget999
    12,001Coins
    That is a 0.6 hp motor at 25 amps so it has plenty of power.
    I would imagine you are overheating the ibt2 and it is shutting down.
    Turn ffb down to 50% and see if it takes longer to shut down.
    Are you using the arduino leonardo to control the wheel ?
  6. Vdub180
    Vdub180 Member
    England
    148Coins
    Yes I'm using the arduino board, silly question but if I put it on 20kHz would that improve the motor out on 50% if not what motor would u recommend to get max power out the ibt
  7. Gadget999
    12,001Coins
    which software did you program the board with ?
    is the ibt2 getting hot ?
    does it trip out in both directions ?
    (at 20khz the noise should go)
  8. Vdub180
    Vdub180 Member
    England
    148Coins
    Both directions trip, and I used the directions from the video including links for software
  9. danove_b
    danove_b Active Member
    Sweden
    1,782Coins
    To start with, you can remove one of the batteries. I assume that you have no need of the full speed of the motor.
  10. Vdub180
    Vdub180 Member
    England
    148Coins
    Won't I lose strength then
  11. Vdub180
    Vdub180 Member
    England
    148Coins
    Ok now it runs on 20mhz on 100% but only on 12v power but still week I think I need a stronger motor but no idea what is there any way I can use a stepper with my setup
  12. Vdub180
    Vdub180 Member
    England
    148Coins
    Also no difference in strength between 12 or 24v even tho its a 24v motor, unless I have a dodgy 2nd battery but it does hold a solid 24v when in use so not to sure
  13. Gadget999
    12,001Coins
    i don't believe a stepper motor is suitable for a FFB steering wheel, it is designed to increment the rotation by one step at a time - internally the coils and magnets are designed to pulse rather than rotate so it will always have a cogging effect
    your setup with a dc controller and encoder is more like a servo motor
    the current available is more important than the voltage available - how many amps can your power supply provide ?
    are you brave enough to connect the motor direct to the power supply / battery - this way you can feel how much power the motor has available !
  14. Daguru
    Kitchen installer
    Wales uk
    460Coins
    Motion platform
    Not sure why you keep saying a stepper can’t be used ?
    It has and it works very well with a 13nm nema 34
  15. Gadget999
    12,001Coins
    personally i have not tried one, but i have read reports there is cogging from the people that have built them
    here is a good video explaining the design -
  16. Vdub180
    Vdub180 Member
    England
    148Coins
    When I get home I will connect it to the battery direct and report bk thanks for all ur help, IF the motor has plenty of power when connected to the battery how would I resolve this if the h bridge is not strong enough to pass the current through
  17. Gadget999
    12,001Coins
    use 2 h bridges :)
  18. Vdub180
    Vdub180 Member
    England
    148Coins
    All wired parallel?
  19. Vdub180
    Vdub180 Member
    England
    148Coins
    Ok power of the motor is about the same through the ibt as it is stright on the battery 24v been double the strength of the 12v so look like I need a stronger motor can anybody recommend anything
  20. Gadget999
    12,001Coins
    Try a smaller diameter steering wheel. It will increase the torque
