value1
Joystick plugin 2.0.0.1
SimTools plugin to read the joystick values
  1. Csaba
    Csaba New Member
    Hungary
    - 6Coins
    Which version of Vjoy works? I have tried a lot, but could not install.....
  2. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    The latest. But dont forget... only 1 joy conected !! If you have more usb joys OR an xbox controller, OR button box, handbrake, whatever, this plugin dont works.
  3. Csaba
    Csaba New Member
    Hungary
    - 6Coins
    I meant the Vjoy SW: https://sourceforge.net/projects/vjoystick/
    This sw used to merge two or more USB game device, into one. So, you can have, throttle , pedals etc. and still the Generic Joystick plugin will works.
    But I could not install it, on w10.
    @George Dobransky said it is worth to try older versions, but I had no success.....
  4. pierre
    pierre New Member
    102Coins
    hi, same for me with a t16000: roll -32767, heave 24446, yaw -32767, extra3 655.34 these are the values of the tunning center as soon as I launch the pluggin. The value of the pitch is managed by the yaw of my joystick, the value of sway is managed by the pitch of my joystick and the surge value is managed by the roll of my joystick ... please help!
  5. SeatTime
    Thank's @jungletech :thumbs. I have a Hotas/Pedals and other systems plugged in, so this also worked for me. Allowed me to select my Warthog Joystick for Elite - then it came up as the first selection - could not select/find it before that.
  6. paulopsx2
    brasil
    647Coins
    i use hotas g940.. but plugin for this systems are... " brutal ".. too fast movements and no fine adjusts ! you are happy with results?
  7. SeatTime
    My rigs long 6DOF actuators may be helping :)Works beautifully - better then I thought it would :D,( I am on the default Tuning Center settings), especial when I also mapped my G-vest to it as well, so I get a real extended sway and heave, which crushes me into my seat when I pitch up/ and side to side for roll . With the buttkicker running, I don't seem to be really missing that much...:thinkalthough FS2 with my system does feel better with all the DOFs active. So a proper plug-in would obviously be the go for everyone.
    You guys will catch on to this G-system thing one day ;)- Had some old work friends on my rig yesterday and they were blown away (they have been on my rig before the new G-stuff) makes the multi-million dollar sims that they and I have been in feel like toys.
  8. pierre
    pierre New Member
    102Coins
    I find a setting for my 2dof with this pluggin: the roll of my t16000 is surge on simtool and the pitch is sway on simtool. I put 60% per effect for a total of 120 per axis.
    The movements being very brutal I set the surge and the sway at 32768 for the max and -32768 for the min on the tunning center.
    I also added 90% smoothing filter on 2 effects and 2 axis.
    The movements are now bearable! the simulator does not jump in all directions!
    Happy to finally have tame this pluggin.
    thank you all for your work.
  9. jesusete007
    jesusete007 New Member
    VAENCIA
    161Coins
    Hi George!
    Did you find some solution ? Im using Thrustmaster T-Flight -X- Hotas...
  10. Arianus One
    Arianus One Tony Rom
    empleado
    16Coins
    Thank you very much for the plugin, you could improve the following: that does not registyre the return to the central posocion of the stick since this produces a sudden movement every time a pitch or roll is made, a whiplash, for me it would be better not to register the return of the stick to the central position or zero ??? or which parameter of the plugin would have to be touched, download visual net to open the plugin file.
    152,989Coins
    +11,116 / 56 / -2
    Plugins are compiled so you need to source, such as building the plugin from scratch, you can't just modify them: https://www.xsimulator.net/community/faq/how-to-write-a-plugin-for-simtools-api-documentation.131/
    But it sounds like tuning the SimTools plugin settings would help, see @yobuddy's comments here about using Gain and Return in the Axis Allocations: https://www.xsimulator.net/communit...mulator-–-dcs-plugin.4762/page-12#post-154419
  12. Benji85
    Benji85 Member Gold Contributor
    851Coins
    Hey guys I too have a t16000 and my rig is offcenter when I start the plug in. any fixes? trying to get it working foir E.D as the regular plugin doesn't work.
    Many Thanks
  13. paulopsx2
    brasil
    647Coins
    Whats your rig? Other plugins works normally?
  14. Benji85
    851Coins
    2dof dof reality cv rig, yeah all other games work fine- just nothing from ed which is a shame beacuse it's awsome in vr etc and motion ...would be nice :)
  15. paulopsx2
    brasil
    647Coins
    Weir. I use ED plugin on VIVE, 2 dof and simvibe. All works fine.
    see the download session... some plugins are news EXCLUSIVE for VR and other for normal use.
  16. Benji85
    851Coins
    Cool so it does work.. do you use the steam version?
    I use oculus version as its better for cv1 picture quality etc - could that be the problem?
  17. Benji85
    851Coins
    in the main thread staff said it doesn't work anymore and that you need to use some cheat engine thingy and edit stuff.. is that what you did?
  18. paulopsx2
    brasil
    647Coins
    Yes... steam and all dlcs. Its the same version for oculus. You can put telemetry "on" in command line.
  19. Benji85
    851Coins
    I cannot enable telemetry as I have oculus version
  20. paulopsx2
    brasil
    647Coins
