GhostRacer 2DOF
Discussion in 'DIY Motion Simulator Projects' started by GhostRacer, Jul 8, 2016.
  1. MarkusB
    4,215Coins
    Did you manage to solve your current issues?
  2. GhostRacer
    GhostRacer Member
    United Kingdon
    497Coins
    YES YES YES YES
    I have both motors playing nicely together (motor 1 is slightly jerky) but both basically following a lovely sine wave in SMC3utils, I cant tell you how good that feels after sooooooooo many days of tinkering.
    Now to try opening Simtools in the morning
    not sure why with exactly the same settings motor 2 is smooth as silk following all the test outputs but motor 1 is slightly jerky but i'll live with it tonight.
  3. GhostRacer
    GhostRacer Member
    United Kingdon
    497Coins
    currently too scared to open simtools, just in case I break something.......
    motors not connected to rig, but have pretty good movement in SMC3utils
  4. GhostRacer
    GhostRacer Member
    United Kingdon
    497Coins
    in sine wave motor jitters slightly(very slightly) on every change of direction but motor 2 is smooth as silk.
    where should my yellow line be, seems a bit erratic
    153,001Coins
    +11,116 / 56 / -2
    SimTools won't break anything, but does need its own tuning, as per previous advice.
  6. GhostRacer
    GhostRacer Member
    United Kingdon
    497Coins
    I know, I know
    I'm just glad to get this far, silly I know but after banging my head against the wall for a week, if only I had two brain cells instead of one ..............................................now where was I ?
  7. BlazinH
    16,676Coins
    A lot of us use these. You can get them for around $15 to $20 and they're noiseless because they're non-contacting.
    Since you can't reverse the output on hall pots by switching the wires that's why I just say reverse the leads to the motor because that works in either case @MarkusB.
  8. GhostRacer
    GhostRacer Member
    United Kingdon
    497Coins
    we have movement boys and girls in Live for speed...............finally !
    • Winner Winner x 4
  9. MarkusB
    4,215Coins
    Congratulations! Then your next beer will probably be because of joy instead of frustration. :cheers
  10. GhostRacer
    GhostRacer Member
    United Kingdon
    497Coins
    A BIG Thank You to all of you for all your help and patience, got a lot more to do, like learning how to patch Project cars 2..... but yes first beer after getting rig to actually move tasted sweet !
  11. GhostRacer
    GhostRacer Member
    United Kingdon
    497Coins
    Ok chaps getting there in LFS buy still cant work out how to patch Project cars 2, anyway had a great day playing with assignments, cant seem to get roll to work at all, and I have a grumbling motor when idle, motor 1 is behaving beautifully but motor 2 is a bit jerky and growling (very slightly)
    Ghosty
    desperate to drive project cars 2
  12. GhostRacer
    GhostRacer Member
    United Kingdon
    497Coins
    I cant seem to find how to patch project cars 2, trawled trough search, have downloaded patch, but now stuck !!!!!
  13. noorbeast
    153,001Coins
    +11,116 / 56 / -2
    With SimTools closed go to your menu -> SimTools and open SimTools PluginUpdater, then just drag the Project Cars 2 plugin zip file on to that, which installs it.
  14. GhostRacer
    GhostRacer Member
    United Kingdon
    497Coins
  15. JonBakhol
    JonBakhol Active Member
    Netherlands harderwijk
    443Coins
    You also have to activate Shared Memory in PCars itself?
  16. noorbeast
    153,001Coins
    +11,116 / 56 / -2
  17. GhostRacer
    GhostRacer Member
    United Kingdon
    497Coins
    Hi
    Simulator has been working great for a while now but since last nights Steam update my motion is completely off in PCars2 but fine in LFS, do I have to capture min/max again in tuning centre after a Steam update ?
    Cheers
    Ghosty
  18. noorbeast
    153,001Coins
    +11,116 / 56 / -2
    A Steam update should not change anything.
    But do check if a game update may have changed the PC2 in-game settings: https://www.xsimulator.net/community/faq/projectcars.188/
  19. GhostRacer
    GhostRacer Member
    United Kingdon
    497Coins
    deffo got shared memory on, tried removing patch and re installing, not capturing anything in tuning centre, values just stay at zero.
    153,001Coins
    +11,116 / 56 / -2
    Have you tried verifying the integrity of the game files in Steam?
    Also try reinstalling the plugin.
