Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. vsp19
    vsp19 keep Sim-Racing Gold Contributor
    170Coins
    2DOF, 3DOF, SCN6
    Hello Youbudy
    Thank you for your answer
    Who can do such a Plugin ?
  2. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Hi everyone,
    To upgrade from 2.2 to 2.2.5 which is the best route?
    Is it necessary to back up old files, uninstall 2.2 and install the new 2.2.5, or is it enough to install the new release as ia a pach?
    Thanks for the update and support :thumbs
  3. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    i just installed over the top and have had no problems yet!! game vibe working better than ever:grin:thumbs
  4. ilbiga
    Network Engineer
    103Coins
    Thanks for the feedback!!! :thumbs
  5. yobuddy
    51,518Coins
    Over the top is the way to go!
    • Funny Funny x 2
  6. vsp19
    170Coins
    2DOF, 3DOF, SCN6
    Hello yobuddy
    I use an e-belt tensioner with a SCN
    Unfortunately, I can only use the Half Way of the SCN for belt tightening.
    In order to use more than half way for the brake command surge,
    there should be a possibility to be able to move the initialized middle position.
    So I'm looking for a solution to shift the middle position of a SCN HyperAxis,
    so I have a longer actuator path to one side
    This would require a custom Interface Plugin I'm afraid.
    Can someone please help me to create such a plugin
  7. vsp19
    170Coins
    2DOF, 3DOF, SCN6
    Hello yobuddy
  8. yobuddy
    51,518Coins
    I don't have time at the moment, but I can look into it in a couple of weeks.
    For a simulator setup thou, shifting the center position in software is less than desirable.
    You end up lop-siding the output, where one side is longer than the other.
    So to fix the problem, you just use less of the shorter side of the actuator to make them balance again.
    Loosing length on the actuator.
    Meaning its a ton better to center the actuator on the hardware side of things.
  9. vsp19
    170Coins
    2DOF, 3DOF, SCN6
    Hello Youbudy
    Thank you for your willingness
    I think exactly as a plugin for the e-tightening by SCN increasingly want more.
  10. ilbiga
    Network Engineer
    103Coins
    192.168.255.255 is not a valid ip address. The problem could be this...
  11. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Hello everyone, i just installed Simtools 2.2.5 because i upgrade my JRK motor controllers to the new JRK G2 and for somehow i lost all my preset and the Interface type JRK is not finding the Device number! any one knows how to fix this?
  12. ilbiga
    Network Engineer
    103Coins
    Ciao. Have you tried to see if the "C:\Users\<your user_name>\AppData\Local\SimTools" folder is present?
    All configuration data resides there.
    Check the full path integrity. :thumbs
  13. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Is the new JRK G2 supported by Simtools yet?
  14. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Hello Ilbiga, the folder is not there, here is a picture
  15. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Guys, i am having issues with SimTools 2.2.5 it will not send the commands to the new JRK G2, does anyone has a preset that i can installed?
  16. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    I try to use the "Serial" interface type but it will not work.
  17. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    The "JRK" Interface Type does not find the JRK G2!
    any help will be very well appreciated
  18. Nick Moxley
  19. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Yes, configuration and tuning are done, I can move the motors by changing the Manually set target in the Pololu JRK G2 Configuration Utility.
    Do you have had the new JRK G2 work successfully? can you share your interface preset?
  20. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    YOUTUBE video showing the SimTools 2.2.5 with JRK G2 issue
