Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. Nick Moxley
    Hey Milton,
    Ok there's something strange for sure going on, Your stuff appears to work in the Pololu utility fine but for some reason isn't displayed in the Device managed in the same way mine is.
    In regards to the Game Engine not seeing the G2, its being investigated. Bare with us.
    This is what you should see.
  2. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    I agreed with you Nick! i open a Techsupport Case with Pololu to find out if they have an updated Driver for windows 10 for the JRK G2.
  3. Nick Moxley
  4. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Pololu reply with this instructions:
    right-clicking on each entry. selecting "Update Driver Software...", and then selecting "Search automatically for updated driver software"
  5. Nick Moxley
    The Jrk's serial ports might be named "USB Serial Device" in the Device Manager if you plugged the Jrk into a Windows 10 computer before installing its drivers and software. This generally is not a problem, but there is information about how to fix the names in the "Installing Windows drivers and software" section of the user's guide:
    https://www.pololu.com/docs/0J73/3.1
  6. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    I Fix the Ports and now they are showing correctly i rebooted twice to get tested with SimTools but no luck still acting the same way as before, has anyone got it working with new JRK G2?
  7. Nick Moxley
  8. yobuddy
    51,562Coins
    @Milton,
    The GUID of the new devices have changed.
    It's the jrk.dll that needs updated with the GUID.
    Basically, it can't see the new devices yet.
    Nick and I are currently testing a new version now. :thumbs
  9. yobuddy
    51,562Coins
    The new version is now seeing both the older and the new G2 Jrk's! :thumbs
    But nothing is hooked to the Jrk G2 atm for a actual output test.
    That will have to wait till Mr. Moxley has time to hook something up for a test.
    I have a pretty good feeling this one is solved thou. ;)
  10. yobuddy
    51,562Coins
    New Jrk G2 line now conformed working! :cheers
    Updated driver will be in the next release of SimTools.
  11. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    It works thank you so much yobuddy! :grin
  12. Nick Moxley
    Thanks for testing that for me Milton, Appreciate it. hug::cheers
  13. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
    I just update to simtools 2.2.5, I have game data streaming, I have no movement anymore, I entered interface setting from 2.2.0 are they different?
    Should I redo the plug ins I didn't do that yet
    2dof Sm3c arudino win 7 1pc
  14. yobuddy
    51,562Coins
    Nope, not different for a Arduino.
    Should not have to redo the plugins nope.
    Maybe check your interface and axis assignments and go from there buddy.
    Chat soon,
  15. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
    I notice the Max / Min is like 32,567 max and 32,567 min now all categories, my old screen shots they were less then 75 each category, So i will redo the plug ins tonight see if that fixes it, it had also reset all my axis roll,pitch,sway etc to 0 as well after update
  16. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
    i re added the plugin and that fixed it.. thank you
  17. andi75
    andi75 New Member
    Bremen
    - 111Coins
    Hello everybody.
    does version 2.2.5 now work with Pololu jrk g2 24v13?
    Have demo and everything set according to instructions, defies get Output Test not to run.
    With Polulu jrk g2 Utility, motors can be controlled properly.
    Or does not go without a license?
  18. yobuddy
    51,562Coins
    The next version of SimTools will support these new jrk controllers!
    PM me buddy and I'll send you the updated interface.
    Take care man!
    153,986Coins
    +11,162 / 57 / -2
    You use the SimTools Registration app and original license number: https://www.xsimulator.net/community/threads/how-to-register-simtools-2-0.9720/
    You can also look up your SimTools license number, just log into SimTools.us: https://simtools.us/member-login/
    Use the email you purchased the Licenses with, and if you don't have a password, click reset password.
  20. AndreFilipe
    AndreFilipe Andrefly
    businessperson
    Brasil
    - 55Coins
    3DOF, DC motor, SCN6, SimAxe, Arduino, SimforceGT, Motion platform, 6DOF
    Olá pessoal, sou novo aqui e gostaria de saber se você pode me ajudar! Eu estou tentando fazer uma plataforma de movimento para o meu simulador de condores, mas eu gostaria de testar as ferramentas sim que eu tenho a BFF aqui, mas eu gostaria de testar outros softwares! Alguém tem alguma dica para me dar como configurar o condor para funcionar corretamente com as ferramentas sim, que tipo de motor elas me indicam? Estou tentando fazer um teste em pequena escala, é possível? Muito obrigado por ouvir. Peço desculpas pelo inglês porque sou brasileira e estou usando o google tradutor! obrigado!
